History Identify this mystery 1950s Sports Car?
Discussion in 'Traditional Hot Rods' started by inliner2318, Oct 7, 2020.
  1. inliner2318
    inliner2318
    from Tyler, TX
    Anybody know the history behind this sports car? Looks to be early 50s??? I’m sure it ran a flattie with a 39 trans?
    cactus1, Squablow, Terraizer and 5 others like this.
  2. 51504bat
    51504bat
    The cowl looks like it could be a modified MGTD but the frame doesn't look like a MG. Back in the '50's flathead 60's were swapped into MGTD's for more speed. Other than that I've got nothing.
    Elcohaulic and 1934coupe like this.
  3. inliner2318
    inliner2318
    from Tyler, TX
    Looks too well built to be a home job.
    Kinda like a Kurtis Kraft sports car?
    But, the cowl is unique and the doors slope down.
    kidcampbell71 likes this.
  4. TCTND
    TCTND
    If it has an SCCA race history it would be very cool (and worth more) to see it restored to original rather than just made into a toy. Lots of "specials" were built and vintage racers love them when they turn up.
  5. The37Kid
    The37Kid
    STEP ONE with vintage race cars or the remains of one: Do some research, were was it from, were did it race? Is the cowl aluminum? Track down anyone that has any knowledge of it. I found out the history of two cars and one engine AFTER I sold them, not a happy feeling. Bob
  6. scrap metal 48
    scrap metal 48
    Doubt it was a flathead as it looks to have side engine mounts...
  7. Budget36
    Budget36
    The cowl doesn’t look homemade, but with the skills of some it would not surprise me. The frame looks very well crafted. The arcs look like a factory job. All the evenly spaced holes look like it was set up well to hold the rest of everything down. That cowl does look familiar, but not being a guy who knows much about stuff like this, I’d suggest instead of a “what’s this” , change to “can you ID this cowl/ch***is race car”.
    Might peak the interest of some others
    kidcampbell71 and The37Kid like this.
  8. inliner2318
    inliner2318
    from Tyler, TX
    51504bat... agreed that the cowl looks like a early 50s
    MGTD. but, there’s a hump in the middle? Maybe to clear the carbs?
    the rails appear to be an early car maybe Chevy or Mopar? The trans mount looks like a ford 3 speed and the engine mounts are forward like a ford. Not on the side as mentioned.
    probably just a home built 1950s sports car?
    Budget36... I’ll change the ***le to spark more interest.
  9. rustydusty
    rustydusty
    Can't identify your car, but here is one my brother owns that is running and driving with its original flat head and Lincoln Zephyr transmission. 20200913_160542.jpg 20200920_094609.jpg
    catdad49, cactus1, 30tudor and 14 others like this.
  10. gnichols
    gnichols
    from Tampa, FL
    dana barlow likes this.
  11. redo32
    redo32
    This car is smaller than you first think. The wheels are 12" midget race car based on Model T 6 bolt hubs. The rearend resembles a Crosley but has 5 bolt instead of 4 bolt torque tube flange. I think the body and belly pan are custom built aluminum. The frame rails are similar to '40's midget also. Here's a pic showing the wheels and similar frame rails.
  12. 51504bat
    51504bat
    Maybe a Singer? But still no explanation for the hump in the middle. singer2.jpg singer1.jpg
    KiWinUS likes this.
  13. fleetside66
    fleetside66
    The gauges might give you a hint, but they can't really be seen from the pictures you supplied. Any better shots of that?
  14. 42merc
    42merc
    I see it as a home built, maybe with a little help with the aluminum.
    I see a 6 spline driveshaft cobbled to the pinion, early Ford trans mount & flat head motor mounts. Pictures are not clear, but maybe a Ford tube axle on the front.
    Frame rails appear to be a stock configuration pinched at the cowl, with home built cross members.
  15. scrap metal 48
    scrap metal 48
    The Allard had the same style cowl and different engines were used.....
  16. BamaMav
    BamaMav
    from Berry, AL
    Don't know what it is, but it's cool! Did you get the hood with it?
  17. inliner2318
    inliner2318
    from Tyler, TX
  18. SR100
    SR100
    As Red032 said, this is smaller than it appears. If those fronts are 400/12, they're 20 inches high. Eyeballing the car based on that, I'm guessing the wheelbase to be 80", give or take. An MG TC, which is a fairly small car, is 94". The cowl is probably not a production piece. I've never seen a production cowl where there weren't doors that came up to, or at least near, the cowl. Probably a G-Modified or H-modified sports car.
    The37Kid and redo32 like this.
  19. SR100
    SR100
  20. 56sedandelivery
    56sedandelivery
    That's an early CORVETTE!!! Well, it does have early Corvette tail lights, and maybe rear bumperettes. I am Butch/56sedandelivery.
  21. Man I'd buy the **** out of that if it was closer!
  22. The37Kid
    The37Kid
  23. The history of that sporty little thing is FUN !!!!
    Someone, at some point fad a lotta fun with that little nibbler !
  24. Budget36
    Budget36
    Dang I'm glad the kids are grown up, Reno isn't that far!
  25. sdluck
    sdluck
  26. inliner2318
    inliner2318
    from Tyler, TX
    I guess some one picked it up.
  27. Torana68
    Torana68
    from Australia
    someone probably told him it was an early Corvette and worth brazillians.
    inliner2318 likes this.
