Projects 26-27 Model T coupe ??
Discussion in 'The Hokey Ass Message Board' started by 48stude, Oct 6, 2020.
  1. 48stude
    48stude
    I'm going to check out a 26-27 T coupe body. It's missing the drivers door. I'm thinking that I read somewhere that 28-29 Model A truck doors are the same. Is this true or did I dream it? Thanks , Bill
  2. A Boner
    A Boner
    Think so. Did you also dream about finding a good one.
    Budget36 likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    They make cool hot rods, I loved the one Mark Moriarty picked up a while back. HRP
    exterminator and Jalopy Joker like this.
  4. 48stude
    48stude
    I did have that dream , but then I woke up:p:D I'll post some pics if I buy it. Bill
  5. 48stude
    48stude
    I like Mark's car ! This car is my inspiration at the moment
  6. Jalopy Joker
    Jalopy Joker
    exterminator likes this.
  7. chop job
    chop job
    from Wisconsin
    To answer your question 48 stude it is true 28 29 truck doors are the same as 27 coupe doors.
    48stude likes this.
  8. manyolcars
    manyolcars
    try Model T Haven for a door
    48stude likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    The Model T coupe that Boyd built was a good looking car. HRP
  10. Corn Fed
    Corn Fed
    I think the 26-7 Tudor sedan has the same door except for the hinges.
    48stude likes this.
  11. hotrodjack33
    hotrodjack33
    Yes you are correct 1928/29 trucks, A and AA
    including panel delivery doors will fit 1926/27 coupes but you must modify the door hinges to fit the T .
    48stude likes this.
  12. verde742
    verde742
    IS THERE ANY WAY A PERSON COULD TILT THIS BODY LIKE A FUNNY CAR ? LIFTING AT FIREWALL?. Or like the ORANGE CRATE?
    PICTURE DETAILS? ANYBODY..?[​IMG]
  13. goldmountain
    goldmountain
    Check out Flathead Dave's ad in the cl***ifieds. He has doors for sale.
    48stude likes this.
  14. HOTRODPRIMER
    HOTRODPRIMER
  15. Dick Stevens
    Dick Stevens
  16. HOTRODPRIMER
    HOTRODPRIMER
    ****, the link should work now. HRP
    Dick Stevens likes this.
  17. fiftyv8
    fiftyv8
    from CO & WA
    T coupe doors are physically the same as those on the T Tudor and the A closed cab pickup.
    However, the hinges will vary depending on whether it is a 26 or 27.
    The hinges on an A pickup are usually similar to the 27, but pin size is larger in the A.
    The other variation can be the latch, 2 that I know of, but either can be made to fit. One is set in a rectangular impression in the door and the has one curved shape side that from memory slides inside the door.
    Maybe somebody can help me out with that scenario.
    The garnish trim from a 26 is likely to be different, but either years should fit.
    It is just more of a chore to match stuff up with what the other door has.
    As a guide a 26 T coupe should have metal internal trim/support around the rear and quarter windows compared to a 27 which is most likely to have wood in these areas.
    If your coupe has hinges missing you will be wise to confirm the configuration you seek from the opposite side hinge that you already have.
    Generally the lower hinges are the same with respect to mounting, but I have found 3 variations of top pillar side hinges in my travels. Not too difficult to make fit, but if the correct item is available obviously that would be less work.
    Hinges are 26 finger style, 27 cup style and A pickup cup style.
    Check some pic's I have attached just to confuse you some more.
    Have fun.
    MMM1693, AndersF and 48stude like this.
  18. Rick Coast
    Rick Coast
    I have a 26 that I rake chopped the top 3 inches. the doors and deck lids are hard to find and when you do you expect to pay a lot. I love the t coupes, a piece of hot rod American history .
    48stude likes this.
  19. 48stude
    48stude
    Thanks Russ, Great information! I really appreciate it! Bill
    fiftyv8 likes this.
  20. fiftyv8
    fiftyv8
    from CO & WA
    You are welcome Bill.
    Correction to my earlier statement about 27 and A pickup hinge pins, the T I believe has the larger diameter and the pillar side scroll that holds the pin is rolled slightly larger, so it is important to know what you are looking for if you seriously want to have everything matching.
    MMM1693 and AndersF like this.
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have the door that you are looking for. It is also listed in the HAMB cl***ifieds
    PM me for pics and info.
    Yes the 28-29 doors are the same.
    Brookville Roadster sells them for $1300.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  22. A Boner
    A Boner
    Cool T coupe from the “Hooked on T Buckets Podcast”#15.
    48stude likes this.
  23. Dr_X
    Dr_X
