Projects Dagel's 29 Model A SDN from junk and castoffs
Discussion in 'Traditional Hot Rods' started by Gasser1, Mar 20, 2018.
  1. [​IMG][​IMG][​IMG]
    I could not find the rims I wanted 4.5”x15” 5on5 lug pattern so I took a set of 6” wide and cut them down.
    Changed from bags to coil overs
    hendelec and OFT like this.
  2. [​IMG][​IMG]
    There were a bunch of changes done away with the 2x4 rails and use 32 rails instead
    [​IMG][​IMG]
    It was a lot more work but it look better setting over the 32 rails 4”
    I’m wind up with 5.5” ground clearance
    Here it’s at ride heights but the tire are 3” off the ground
    Coil over bracket are mounted a little different but it fits
    I will have 3 master cylinder 2 for brakes 1 for the clutch
    Not my favorite location but you have to have a battery only have a 1” bump to make it work
    Everything I am doing is to keep ever inch of interior room I’m 6’1” and 359# so room is nessary [​IMG]
    Bottom Veiw of battery box
  3. [​IMG]need to find a match to this seat I think Chevy van middle seat.
    It fits and more importantly I fit comfortably. Will do a little reshaping and new covers
    brEad, OFT and Kiwi 4d like this.
  4. That seat is a good fit, hard to do in these
    OFT and Just Gary like this.
    Tires sure make a difference
    3 lever shifter
    1 lever 1&reverse
    2 lever 2&3
    3 lever overdrive
    Just Gary and OFT like this.
  6. [​IMG]https://uploads.tapatalk-cdn.com/20201008/0c4d1fb97a0f6e7076cefd5215
    Getting the steering linkage and gear box worked out
    1d38dc.jpg[​IMG][​IMG]
    Everything is a fight at this point working on the steer column
    brEad, OFT and hendelec like this.
  7. [​IMG]
    The gear box and steering linkage is done.
    Few more day it’s all coming apart for finish work
  8. i had some fender well exit headers made for a pickup .see in my avatar. and they look good stuck out a little farther then I liked. and lets admit it not very practical.
    so figured I would just run the cast iron one that worked till i mounted the gear box .
    so now its either:
    custom build headers very time consuming
    a set of lake pipes. easy to build and $169
    or a set of cast iron ram manifolds $390
    looking like a set of lake pipes. seen on ebay set of lake pips for sbc are only $100 wonder if i could cut the flange off and make them work on a yblock?
    Just Gary, hendelec and brEad like this.
  9. I keep chugging along when I can find the time for my stuff. ising a 64-7 mustang tank not my first choice but there cheep. 971DE4AC-ABC1-4487-AF3D-D753EBD22100.jpeg 6D67E18B-E2DE-4560-B523-46C92A2F0AC7.jpeg 9A3F7B82-F017-40D3-92A5-776DF811452A.jpeg BF5BCE9F-2B7E-4C3B-9DB6-7FA5ED43D49C.jpeg 6A1B82E8-9565-4E15-A214-8CA90B3A2D83.jpeg 876124F0-B8F4-49E6-852D-A8389B6FFF3C.jpeg 3AAFA0E4-FBBE-46B8-AFC1-9149E142AB0C.jpeg 90AFE948-4B45-4EC3-8558-84C8A68F2AEB.jpeg 3134F14F-DE4C-4458-A12F-63D00653379B.jpeg A2C6F77A-CA29-42C8-8CAB-0297C93342CB.jpeg ABD7CBAE-7A81-4E9B-A94F-12A7CB458B19.jpeg F7B271CF-503B-488C-80EC-831F27CA90BC.jpeg 4B13DE92-2233-415D-B216-9F77053CB6EA.jpeg
    Just Gary, Nailhead A-V8 and OFT like this.
  10. I did not like the sharp edge on the wheel well so bent some tubing and split it in half to make a bead . Took several hr to weld each side but it dressed it up .
    Along with the ready of the theam of using left overs it looks like the car will be yellow and the bead work green. Not sure I will like it but the paint is a very good quality and best of all it’s free F8A10086-3E01-471A-8CD6-BEB9D7701D21.jpeg F8A10086-3E01-471A-8CD6-BEB9D7701D21.jpeg 0605CE87-A310-46DF-BBB0-A96B62F7FFFB.jpeg 51DF0DE1-06FC-4EBB-A438-3E2C7FD54AD0.jpeg DCDE4BB6-CFE3-4743-B903-B7885FE3042D.jpeg B6B7BA79-6311-4796-9225-CA85AACF3BAC.jpeg A387709C-81E7-41E7-BD1E-9BA1765695F3.jpeg 896B62E9-59FA-4D1B-9DBA-C8CC112D4351.jpeg 29CBAB90-7610-4D46-BFE7-27EC5BABEDE2.jpeg 94FFFCAB-55FE-45A5-AC2A-8A3EDAE84267.jpeg 045F4EC9-8E73-4D71-B871-FA76FA9398B3.jpeg ACD7D9ED-F21D-405B-A8AA-6C6DFBF5B27C.jpeg 0AF6A71D-4BC3-4449-870A-3C3F51B8339B.jpeg
    I always start with dynagl*** or something similar over all welds it does not absorb moisture like bondo does
    9CDFE164-697B-44E2-BE3D-9A3C4445D8CE.jpeg 4937E58F-45D6-43D7-B152-2614D339AADE.jpeg FE704856-49B3-4721-956C-4306063B88CA.jpeg E1C7D14C-8210-4559-8EB2-6F6BF96FF890.jpeg 99EC6D75-7761-44FD-A6B6-E86643AFDEDD.jpeg 3C798A16-54F8-443A-B8B1-E4526305B5CB.jpeg 76470924-472F-4DF2-91C0-655663280699.jpeg E99BFC74-DBE6-4D36-AFFA-935B944ABC00.jpeg EF4CC1DC-264C-43E8-A5DE-A041C6C5ABB6.jpeg 36E4308E-9653-46EC-B67C-AC7C27AEBE46.jpeg 0761413F-FD7D-4B6F-AACD-267A755DB9F0.jpeg DCFB6105-0E67-42AD-874C-2B345EA52FCB.jpeg
    the green is 3 qt I had left from my 59 ford
    D1933811-4BDC-4190-B9DB-6C6DA21DE76D.jpeg 3FE25B6A-EA59-475A-9709-78F59AD7981C.jpeg
    I have 2 gallons of this fulcryl 2 paint so may as well use it
  11. well, this is a large test panel lol.
    not sure about the yellow possibly if the window area was all green it would be better.
    it defiantly would stand out. and the paint is freelol 275554320_1193541294515046_2849451740714644604_n.jpg 275554320_1193541294515046_2849451740714644604_n.jpg 275513779_1192243144644861_1972501453308553288_n(2).jpg 275497973_1192243124644863_2227702990054159003_n.jpg 275497973_1192243124644863_2227702990054159003_n.jpg
    OFT and sloppy jalopies like this.
  12. AmishMike
    AmishMike
    I like yellow - some of them. When u park on gr*** or next to green, to my exes some yellow seems to pick up greenish tint - do not like. I use Caterpillar yellow, close to school bus yellow, both a little darker. To my eyes anyway. & Cat paint is cheap
  13. A Boner
    A Boner
    Go Packers, go!
  14. this is 2 gallons of school bus yellow that got 2 qts of a white mixed in 2.5 gallons total
