  1. 40ragtopdown
    40ragtopdown
  2. loudbang
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. 40ragtopdown
    40ragtopdown
  6. 40ragtopdown
    40ragtopdown
  7. Deuces
    Deuces
  8. Fabber McGee
    Fabber McGee
    Interesting axle, can't quite get my head wrapped around it.
  9. wicarnut
    wicarnut
  10. wicarnut
    wicarnut
  11. wicarnut
    wicarnut
  12. XXL__
    XXL__
    Looks like crudest possible turning mechanism... "straight" axle with center pivot. Sort of like 4 wheel trailers of old, but with a little caster added in for moving it at speed. Probably a very sketchy ride at speed.
    /2 cents from my armchair
  13. I believe the front axle is one of Chassis Research's " better " ideas.
  14. swifty
    swifty
    Did you get a feature in Cool Cars, Square Rollbars ?? You were defying the norm as that was the time of mini-bikes, go-carts and musclecars.
  15. X38
    X38
    I see two modern - as in current - photos above.:rolleyes:
    lurker mick and Jalopy Joker like this.
  16. Fabber McGee
    Fabber McGee
    In that case, what would be the purpose of the spindles having king pins and being connected with a tie rod? Also, the radius rod that shows on the right side of the axle appears to be clamped solidly with no provision for allowing the axle to swivel. I don't get it.
    Circle track cars used to lead with the right front tire to help them turn left, but no more than an inch or so as I recall. With no suspension it wouldn't be very effective on a circle track and obviously it's not a circle track chassis.
  17. loveoftiki
    loveoftiki
    from Livonia,Mi
    F00E8FDD-524F-456D-B84C-A86AA81ADCAD.jpeg Lakewood California 1953.....
    MO_JUNK, deadbeat, alfin32 and 8 others like this.
  18. 40ragtopdown
    40ragtopdown
  19. 40ragtopdown
    40ragtopdown
  20. 40ragtopdown
    40ragtopdown
  21. 40ragtopdown
    40ragtopdown
  22. silent rick
    silent rick
    they're all moving out. they heard a hot rodder was moving in
    65pacecar, loudbang, Thor1 and 4 others like this.
  23. 31Apickup
    31Apickup
  24. gene-koning
    gene-koning
    We had this old bicycle laying around and thought.... Then the tech guy wouldn't let us run it. We had to weld it up and add regular steering.
  25. Fordors
    Fordors
    The above screenshot is from a PDF that @54popular posted 7 years ago, it shows that the axle was in fact suspended and had conventional steering.
  26. Fabber McGee
    Fabber McGee
    That's cool, I can't make out the suspension in that picture. Is it a single coil spring in the center?
  27. wicarnut
    wicarnut
  28. 296ardun
    296ardun
    It is an early Chassis Research axle suspended by a rubber biscuit inside the vertical tube. NHRA later banned it, insisting on a traditional transverse spring. I had one and had to convert it with a CAE front axle. This is Lloyd Scott's "Sleeprocker Special," which he built after moving to Washington from California. Scott built the original "Bustlebomb" twin engine dragster when in California.
  29. 296ardun
    296ardun
  30. loudbang
