My new project 1951 Buick
Discussion in 'The Hokey Ass Message Board' started by aw1950, Oct 18, 2010.
  1. BJR
    BJR
    Nice color!
    54delray and aw1950 like this.
  2. Peanut 1959
    Peanut 1959
    If those firewall shots are any indication, it's gonna' look stunning when it's finished!
    aw1950 and 54delray like this.
  3. aw1950
    aw1950
    Yes its a beautiful color for sure . Thanks for the positive vibes man !
    Peanut 1959 likes this.
  4. gatz
    gatz
    Sooooo many great things about this car to look at !
    Certainly admire your top-notch work, aw
    btw, sent you a PM
    aw1950 likes this.
  5. BrerHair
    BrerHair
    Damn Bro! Love it
    aw1950 likes this.
  6. Love the color!
    aw1950 likes this.
  7. aw1950
    aw1950
    Kinda resembles your ford build color doesn't it . Its Mitsubishis' Cl***y Red Pearl 2004 I believe it to be the year . Stay tuned more to come !
  8. aw1950
    aw1950
    IMG_2321.JPG 63200939413__600E8448-1C9E-485D-85E7-30EEB1051EDD.JPG IMG_2325.JPG
    Sooo this happened today , now onto running wiring so I can get err running and put cluster back in . Still out here plugging away.
    loudbang, 40LUV, Peanut 1959 and 5 others like this.
  9. Peanut 1959
    Peanut 1959
    Progress is progress. Keep at it!
    aw1950, loudbang and 54delray like this.
  10. BrerHair
    BrerHair
    Go Andy!
    aw1950 and loudbang like this.
  11. BJR
    BJR
    Looking good. Buicks have great looking dashboards.
  12. aw1950
    aw1950
    A little more detail , steering wheel two toned , and the grill insert cleaned up some
    TomT, Copper Top, Hivolt5.0 and 4 others like this.
  13. aw1950
    aw1950
    Dash complete
  14. aw1950
    aw1950
    Getting at it still , had to notch my trans crossmember for clearance. Without it my exhaust would be susceptible to road rash
  15. aw1950
    aw1950
    She’s a runner now and one side of the exhaust is complete to the differential
  16. aw1950
    aw1950
  17. Looking good! keep up the great work and you'll be cruising in no time.
  18. aw1950
    aw1950
    So I am always making more work for myself , with the divider or without ? [​IMG]
  19. aw1950
    aw1950
    Dropping the exhaust out the side at back of quarter panel . 30 degree flute 3” dump pipe . I might sink it into the body some more yet say another 1/2"!
  20. aw1950
    aw1950
    Getting it knocked out , front end all together , brakes are mounted and plumbed , just gravity bled at the moment. Getting there !
    1biggeorge, TomT, chriseakin and 5 others like this.
  21. BrerHair
    BrerHair
    Go Andy!
    aw1950 likes this.
  22. Cosmo49
    Cosmo49
    KEEP the windshield divider!!!!
  23. aw1950
    aw1950
    IMG_2654.JPG IMG_2655.JPG IMG_2656.JPG IMG_2672.JPG IMG_2673.JPG IMG_2674.JPG
    Not a lot of progress but it is what it is . Needed a way to keep the fingers in tact . That fan spinning without anything around it is a serious safety issue . A shroud will help with cooling as well .
  24. BrerHair
    BrerHair
    You’re killing it. So says a tired old man.
    aw1950 likes this.
  25. aw1950
    aw1950
    Annddd done , now moving on to throttle linkage as the off topic cable is to short to reach to the firewall . Thinking old school bell crank setup , we’ll see !!
    1biggeorge, TomT, Hivolt5.0 and 3 others like this.
  26. aw1950
    aw1950
    Here’s a start , bell crank , throw rod to carb , stanchion that needed 90 degree redirect, will add more pics later . Gotta go for shot #2 . We all know what I am talking about . Get this behind us , geez!!!
  27. aw1950
    aw1950
    IMG_2835.JPG IMG_2836.JPG IMG_2837.JPG 65109778496__B6679BDB-D5DD-48EB-A0D3-2587140D9CF5.JPG IMG_2840.JPG IMG_2842.JPG IMG_2844.JPG IMG_2845.JPG IMG_2846.JPG
    Some progress for the devout followers to the end of’ say . Fitting in the TBird rear seats . Had a 7” void behind the seat backs that required the rear parcel shelf to extend . As you can see I created a floating console and a water fall armrest flowing from the rear parcel shelf . It’s a great grab point to lift yourself out of the back seat as well . It’s strong and sturdy . Will pull my 225 lbs out of there with no deflection . More progress to come , stay tuned !
  28. aw1950
    aw1950
    65791033861__65CEBA8A-B9F0-483F-86F3-270DFC44B8C1.JPG IMG_3019.JPG IMG_3020.JPG IMG_3021.JPG IMG_3026.JPG IMG_3028.JPG IMG_3031.JPG IMG_3032.JPG
    Okay it’s been a while , here is what I am at now . Cutting down the window surrounds and touching up on some welding that was left undone on the door bottom when repaired a while back . First coat of etching primer applied . More to come . Slow and sure .
  29. aw1950
    aw1950
    So, after the last comment above, of the doors in etch primer I was moving the p***enger door around on the panel table , it got away from me , fell to the floor and bent the upper window frame backwards as it landed upside down on the front upper corner. I had to cut the door top off again and reset everything.
    Unplanned weeks of work as I don’t get a lot of time out here .
    Needless to say it was repaired, and I moved onto blocking the door to quarter panel and fine tuning . Was able to get the fender skirt mocked into place as well . I blocked at least a quarter of a gallon of filler off the side fine tuning with more to go .
    Was able to start the final mock up of the rear bumper with a 1950 overider ***embly. I like it a lot better . They need repairs but try and find ones that don’t up here in my neck of the woods!
    That’s it for now , later !
  30. patsurf
    patsurf
    wonderful!!-kind of like a custom merc and hudson combined love child!
    1biggeorge and loudbang like this.
