Projects The "Band Aid" Model A on deuce rails project...
Discussion in 'Traditional Hot Rods' started by ratamahata, Oct 7, 2020.
  1. ratamahata
    ratamahata
    from Argentina
    Hey guys... New project in the New Shop... I'm working with a friend... Another friend... (Not the talented metalshaping guy)
    We join forces to get some work done for some clients.
    We make a deuce frame table for reproduce 32 rails (intended to sell the frames) The frame in the picture is a reproduction frame (handmade by my old metalshaping friend) The jig es also for make all the welding, mock up the axles, the engine Etc
    The new reproduction frames are plasma cuted in one section... The idea is make the reveal and welding all the plates in the jig. (Jig was made with an NOS 32 frame)
    Moving to the model A on deuce rails... Front axle is a 4" dropped original Studebaker... Needs to modify for a buggy spring.
    Engine is a Mercury 53' flathead
    7.50 and 6.00 steelies
    We need to determinated a lot of things too...
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Enviado desde mi Mi A1 mediante Tapatalk
  2. chop job
    chop job
    from Wisconsin
    Awesome start to a COOL hot rod.
    Stogy likes this.
  3. ratamahata
    ratamahata
    from Argentina
    Thanks... I hope so! We have a long road to learn and finish him!!!
    kadillackid, Stogy and chop job like this.
  4. panhead_pete
    panhead_pete
    More Argentinian Gold! :)
    kadillackid, Stogy and ratamahata like this.
  5. ratamahata
    ratamahata
    from Argentina
    Rear sub-rails on the body was taken apart sometime ago... This particular project was expected to sit on a modify model A Ford frame with a kick up at the rear from previous owner...
    Today I made some mods on the width of the rails because I don't want to pinch the rails... I put some spacers and gave less overall width to the frame.
    Rear sub-rails and wheel wells were a mess...They had some poor patch panels and a lot of rust, so I'll try to removing all...
    Tomorrow I made some mods on the front to make the body sit flats on the 32 rails and make a little mock up.[​IMG][​IMG][​IMG][​IMG][​IMG]
  6. ratamahata
    ratamahata
    from Argentina
    And Jack the ripper came!
  7. Kiwi 4d
    Kiwi 4d
    Man ,I am subscribed to this thread . You have some of the coolest builds . Watching with interest.
    kadillackid, Hank56, Stogy and 3 others like this.
  8. ratamahata
    ratamahata
    from Argentina
    Thanks [emoji106]
    kadillackid likes this.
  9. ratamahata
    ratamahata
    from Argentina
    Next... Going to sandblasted all the body... Take me some time but I manage to remove the gas tank... Previous owner was cut the bolts that attached the gas tank with the firewall
    kadillackid and Stogy like this.
  10. brEad
    brEad
    Looks like a cool project. I’m subscribed to follow the rest of the build.
  11. ratamahata
    ratamahata
    from Argentina
    Working on the cowl mini channel before sandblasting... It's great to work like this because it's easy to move and positioning the cowl best for measure and cut!![​IMG][​IMG][​IMG][​IMG]
    kadillackid, Stogy, Jet96 and 4 others like this.
  12. Outback
    Outback
    from NE Vic
    Very cool, i look forward to seeing this come together!
  13. ratamahata
    ratamahata
    from Argentina
    Today I remove the door panels... It's better for sandblasting and repairs...[​IMG][​IMG][​IMG][​IMG]
  14. ratamahata
    ratamahata
    from Argentina
    I'm working on a 33' 3W chevy too...[​IMG]
  15. brady1929
    brady1929
    Cool roadster.
    Stogy likes this.
  16. ratamahata
    ratamahata
    from Argentina
  17. 30tudor
    30tudor
    The body and subrails are in good condition, sheetmetal looks original, you have better material to work with then I do for that roadster. It must have spent quite a while under cover down there in the tropics. Looking forward.
    Stogy, ratamahata and Outback like this.
  18. ratamahata
    ratamahata
    from Argentina
    Yeah... In general the condition is good for an 80 years body... Have some pitting in the sub-rails and corrosion too...The right quarter it's seems was crack and welding sometime in the past... but still have a deep punch in there.
    I'll need to take care of the trunk lid... It's in bad shape...
    Stogy likes this.
  19. ratamahata
    ratamahata
    from Argentina
    More surgery... Removing sub-rail form quarter panel[​IMG][​IMG][​IMG][​IMG][​IMG]
    kidcampbell71, brEad and Stogy like this.
  20. Stogy
    Stogy
    Great Stuff @ratamahata...I remember both of these from past posts in other Threads...you still have them...and it's time...that's great...I look forward to your adventures with this and the Bowtie Coupe...
    ratamahata likes this.
  21. ratamahata
    ratamahata
    from Argentina
    Ready to sandblast[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  22. wheeldog57
    wheeldog57
    Wow, your quarter panels still had the attaching points to the subrails, I'm jealous.
    Great project bro, keep up the great work
  23. ratamahata
    ratamahata
    from Argentina
    Taking off some rude bolts and welding the piece of the cake... [​IMG][​IMG]
  24. You really get into your work. You have no problem getting to the bottom of the job. Good luck on your build, you have a good start.
    Stogy likes this.
  25. AHotRod
    AHotRod
    You got a rough one to revive .... I'll follow along with you.
  26. ratamahata
    ratamahata
    from Argentina
    The first pieces sandblasted and painted with the wash primer...
    I decide to save the front rails because there were a guide for me to know we're the cowl and quarters were attached with the rivets... They are extremely pitting by corrosion but I think I can make some patches and saved.[​IMG][​IMG][​IMG][​IMG][​IMG]
  27. ratamahata
    ratamahata
    from Argentina
    Hey Guys... Some random pictures[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Stogy, Departed, brEad and 3 others like this.
  28. brEad
    brEad
    Good to see you’re making some progress!
    ratamahata, Stogy and loudbang like this.
  29. redoxide
    redoxide
    Waiting with baited breath for you to do the B posts .. :)
  30. doubleduece
    doubleduece
    Nice thread.
    I'll be tuned in.
