Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Boneyard51
    Boneyard51
    Given a choice of too loose or too tight, I’ll take too tight. I have seen oil filters come loose, I have seen oil filters leak! Although difficult I have never seen an oil filter I could not get off! I have a whole armoda of things to get filters off!
    Just my experiences!
    Bones
  2. 1971BB427
    1971BB427
    from Oregon
    Since I build my cars alone, and never have a helping hand I often have to figure out how to do something alone. Recently I was installing all the gl*** in my '39 Chevy and thought I really needed a second person for this part. But couldn't get any help, so I decided to try it alone. Before starting I went on Fleabay and for $9 I ordered a cheap gl*** suction cup tool. I figured I could hold the gl***, and pull out on it while pulling the weatherstrip in.
    So the tool held great, but the small clothesline rope didn't work for ****! Having lots of small stranded electrical wire around, I figured it might slip the weatherstrip easier. So I cut a 8' piece and put it in the rubber channel. Pulled the gl*** in place, shot some soapy water on it, and the window literally almost fell in place as I pulled the wire! Took me all of 60 seconds by myself to put the rear window in!
  3. olscrounger
    olscrounger
    ^^^ excellent--have used one of those for years-makes gl*** install much easier.
  4. Paulz
    Paulz
    You can also find those vacuum handles in the bathroom aisle in a lot of stores sold as shower grab handles.
  5. Truck64
    Truck64
    from Ioway
    I choose "just right". No leaks, no runs, no errors. So much time wasted, cleaning up mistakes by stupid ****ers. Too loose, too tight, whatever.
  6. turdmagnet
    turdmagnet
    Agree with a thin film of grease over oil. Another thing an old mechanic showed me when I was a pain in his *** was to wipe a bit of grease on the new filter threads before you screw it on. Maybe it works maybe it doesn't, but this with the 3/4 turn after gasket contact has always worked for me. $0.02
    Sent from my SM-T560NU using The H.A.M.B. mobile app
    thintin, loudbang and alanp561 like this.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    I put a Fumoto valve in everything. Makes draining the oil quick and easy.
    ekimneirbo, papacub and loudbang like this.
  8. swade41
    swade41
    from Buffalo,NY
    When dismantling your Holley carb (or any carb) for a rebuild use your heat gun around the gasket areas to soften the hard stuck gaskets and they'll come apart much easier. It'll also make it easier to s****e the gaskets, in the same fashion dropping small parts with stuck gaskets in a gl*** of hot water will almost make the gaskets just fall off.
  9. Gizzy
    Gizzy
    from N.W,Ohio
    Me too....I use a lot of tape
  10. Six Ball
    Six Ball
    from Nevada
    I had a car taped and ready to paint when life stepped in and it sat for more than a year. My tip is don't do that! :mad:
  11. LAROKE
    LAROKE
    I work alone as well. I used ratchet straps to help me with the new windshield on my '55 chevy 1st Series truck.
    Elcohaulic, Gizzy, LowKat and 9 others like this.
  12. Six Ball
    Six Ball
    from Nevada
    Battery Charger I just found this out.
    We all know that the newer electronic chargers won't charge a completely dead battery. I had one this morning. I didn't want to connect it to another battery because they are all in other cars and it would be hard to get one close enough to hook up. I turned the charger to the boost/start mode and it charged the battery enough to work on the regular charge mode. Maybe you guys already knew this but I didn't.
  13. atch
    atch
    It's been mentioned in about a hundred other posts on here, but apparently not in this thread. Or at least I didn't find it by searching.
    When needing to find a radiator hose for your hot rod you're putting together and just now have the engine and radiator in place, a preheater hose is a really good way to make up a template. Stretch and bend into the shape you need and take it with you to the parts house. You probably have a favorite old time parts house that will let you look through their wall of racks holding dozens (hundreds?) of hoses 'til you come up with what you need.
    Works infinitely better than a coat hanger or welding rod bent into shape.
    The one I use is a NAPA 819-1127. It's 1 1/2" diameter so is a really close approximation for most radiator hoses. It's compressed to minimum length (about 8") for packaging but says it's 18" long. I've never stretched it out all the way to verify though.
    A free aside: while the fellas come and go at my local NAPA store there's a lady that's been there for a long time. She probably knows as much as all the guys put together. When I go in I always browse around the racks 'til I see she's finishing up with a customer and make sure I get her to wait on me.
  14. blowby
    blowby
    from Nicasio Ca
    I had tried to fit LED bulbs in drop lights before but they always bottomed out before making contact. Recently found some, at the dollar store no less, that don't have that wide base part. New life for old drop light. 20201031_090711_resized.jpg
  15. LowKat
    LowKat
    I dropped my old style drop light and broke the frosted gl*** on the LED conversion bulb. Now it's really bright.
    Ford52PU, redzula, Phoenix24 and 5 others like this.
  16. rln31455
    rln31455
    I save the plastic lids from coffee cans. They make nice mixing boards for epoxy like J B weld or even a little body filler. Just throw them out when done.
  17. blue 49
    blue 49
    from Iowa
    ^^^ Another nice mixing board is a car dealer plastic license plates. A friend's shop was once the detail shop for a used car dealer and they left behind a load of them. I grabbed a half dozen to take home and before my friend could put the rest away, his son pitched them.
    Gary
  18. 56don
    56don
    I kept my old door gl*** out of my pickup truck to mix body filler on. Its perfectly flat and easy to clean up after the filler hardens, I just s****e it off with a razor blade. Easy peezy.
  19. chevy57dude
    chevy57dude
    Carpet installation -
    To find that bolt hole after you lay carpet: heat an awl with a torch and push through. Shifter boot screws, seat belt bolts, etc. Seems to minimize ''runs''.
    X-cpe, Boneyard51, Bugguts and 6 others like this.
  20. Departed
    Departed
    from Canada
    if you have a nut that's catching or bad threads that jams. Hit around the nut with a hammer (or whatever is closest) and it'll fix the threads and smooth them out again.
  21. fyrffytr1
    fyrffytr1
    Here's something that might save someone else a heartache. Don't be too lazy to move you car out of the shop to get tools needed for a job. I thought I could get a miter saw out between my project 50 Pontiac and my finished 67 GTO. Guess which car I hit?!!! A 1 1/2" scratch cost $1,507.50 to repair. Luckily Hagerty Insurance covers stupidity and they cut me a check for the full amount. Car is in the shop now.
    Six Ball, loudbang and Boneyard51 like this.
  22. 56don
    56don
    Yeah, thats Murphy's law. I have experienced it several times..:(
    loudbang and Six Ball like this.
  23. Six Ball
    Six Ball
    from Nevada
    Sometimes I think I work in Murphy's Garage. :(:D
  24. fyrffytr1
    fyrffytr1
    I think I own a Murphy's franchise garage!
    loudbang, Six Ball and seb fontana like this.
  25. Coggles
    Coggles
    Oooo that’s a great idea. I have a weird mystery piece of gl*** that is a window for something that was in my Hudson when I bought it. I was trying to figure out what to do with it.
  26. dmikulec
    dmikulec
    Old thrift store muffin tins and bread pans are great for storing parts and can usually be found for less than a buck a pop. And it supports a good cause to boot.
  27. iwanaflattie
    iwanaflattie
    If I have the space..I move frames like this
    If your wire in your welding machine likes to bird nest,build something like this and you wont have that problem
  28. mgtstumpy
    mgtstumpy
    You never have enough off floor storage so shelves are a must. Use every available wall space (Above head and within safe reach), then there's less to trip over on the floor. Also power outlets and access to them as well! The only proviso is that you need to get organised!
    Old 2-bay shed
    - Shelves across rear wall and 1/2 way down each side. It's amazing how many boxes you can fit and what they can hold.
    New 3-bay shed - Shelves across back wall and down each side wall again in addition to 2 x panels of 4-shelf racking. I also use heavy garden hooks for hanging panels and components etc on the walls. That hoods now hanging on the wall as that was move-in time.
  29. Mart
    Mart
    Re the mig wire birds nest.. On mine there is a spring on the central hub that provides a drag to keep a tension on the wire. In the pic above a spring could be fitted between the nut and washer. That might help somewhat.
    Mart.
    redzula and loudbang like this.
  30. blowby
    blowby
    from Nicasio Ca
    After 6 decades on earth I finally just learned the right way to coil extension cords, the 'over under method'. Sure wish they would have taught this in school instead of those useless subjects like reading and writing. ;)
    https://www.premiumbeat.com/blog/wrap-cables-cords-rope/
