Projects French Winter project /'32 roadster
Discussion in 'Traditional Hot Rods' started by will karshapers, Oct 19, 2020.
  1. will karshapers
    will karshapers
    Hi all
    I found my Winter project
    I bought a 32 châssis with 9" Ford rear axle and a dago drop I-beam on the front
    '42 Ford spindle with full '40 Ford brake
    4 16" Ford 40 wheels
    Fiber gl*** roadster '32 body
    I have my 303 rocket with tri power intake and a 3 speed trans of corvette '58
  2. will karshapers
    will karshapers
    L'***emblage fusée et trans
    Avec un kit d'adaptateurs de transmission
  3. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Great start to a great build!!!!!!
  4. will karshapers
    will karshapers
    For the front end i will want a braided frame look like "rolling Bones "
    But I don't know if i do a cl***ic front end (leaf above I-beam ) or a suicide front end
    Anyone know what is the distance between the firewall and the I-beam on "rolling Bones" frame look like the '32 roadster 232 ?
  5. will karshapers
    will karshapers
    What IBeam size they use ? 46" or 48"
  6. Fordors
    Fordors
    From what I have seen they tend to use original Ford axles. The early beam axles are 50 1/2” and the ‘37 tube axles that they also prefer are 48 1/2 inches.
    will karshapers likes this.
  7. sloppy jalopies
    sloppy jalopies
    IMO... find out what your local rules are before you cut anything off the original frame...
    now is the time !
    years ago a buddy's brother said when in France he couldn't legally change the tire size, front or rear...
    best of luck to you...
  8. will karshapers
    will karshapers
    Hahaha !! I don't Make my choice with the law
    Legal or illégal, i does any one care
    Thanks for your caution
  9. will karshapers
    will karshapers
    I see the article on rolling Bones châssis
    I know they use a 109,5 wheels base but I don't know where they position the front member compared the firewall
  10. Max Gearhead
    Max Gearhead
    from Wisconsin
  11. will karshapers
    will karshapers
    Certaines pièces arrivent avant le 2e verrouillage en France
    Boîte de direction et colonne Ford F1 48/52
    Volant Ford 40
    Fusée Olds 303 side motor mount
    mgtstumpy likes this.
  12. FlatJan
    FlatJan
    Si t' as pas le droit tu prends la gauche :D
    Bonne continuation..
  13. Sandgroper
    Sandgroper
    Looks like a good start. Looking forward to watching it come together.
