Hot Rods The ALTERED thread
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 3, 2016.
  1. loudbang
    Yea I wondered abut the Swamp Rat Jr. myself. :cool:
  2. Mark Hinds
    Mark Hinds
    from pomona ca
    OK Hamber, need a little help. Found a thread on the HAMB called Pontiac Oldsmobile rear ends. Putting a 1962 Posi unit in the project. Flange bolts all line up, but can't get the third member flange to seat on the housing. It was mentioned in the thread that a 62 third member would fit into a 58 axel housing with a little modification. The only thing I see keeping the third member from seating is some little flats that are in the way of the bearing caps. Any info will keep me moving forward. PA180156.JPG PA180157.JPG PA180158.JPG PA180157.JPG PA180158.JPG
    chryslerfan55, Deuces and loudbang like this.
  3. Mike VV
    Mike VV
    from SoCal
    One big bit of info that you missed telling us...
    How far are these tabs holding the casting from the housing ?
    .06", .13", .25" ?
    Sounds like a little hand grinding and a good cleaning is in order.
    Mike
  4. loudbang
  5. Mark Hinds
    Mark Hinds
    from pomona ca
    Sorry Mike, it's less than .250. What i'm look for is where to grind and is that all that is necessary for the modification mentioned in the thread. I've put felt marker on the case but not able to giggle the third member to get any shinny spots, it a snug fit. That third member ain't lite and my old back is having trouble getting it up and down. Thanks for the response Mike, Hambers are the best people.
    mad mikey, chryslerfan55 and loudbang like this.
  6. saltflats
    saltflats
    from Missouri
    Put some clay in the housing to check for contact problems.
    mad mikey and loudbang like this.
  7. bchctybob
    bchctybob
    I would try the clay or maybe put some masking tape on the suspected areas, that heavy third member should mess up the tape where there is interference.
    You might also call Fabcraft and ask them what other issues you might encounter. I’m sure they’ve done plenty of them.
  8. butch27
    butch27
    I use brite "play-dough" $1.00 store
    mad mikey, Mark Hinds and loudbang like this.
  9. Mark Hinds
    Mark Hinds
    from pomona ca
    Off to hobby lobby for some clay, Thanks Flats.
    loudbang and saltflats like this.
  10. Mark Hinds
    Mark Hinds
    from pomona ca
    For anyone dealing with a 58 Chrysler 9.3 housing and putting a later 9.3 in, just remove those little tabs, about .150 in four places, and the third member slides right in.. Happy camper today.....
  11. loudbang
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I wonder - is there any significance to the "jr" designation on this and other cars (I'm thinking of Nancy's "22jr" in particular)? I don't remember any cl*** designation containing a "JR" in poring over my old rule books.
    Or is it somewhat akin to the old champ cars that usually contained the word "...Special"?
  13. Stogy
    Stogy
    Hmmm I guess that was before that infamous Blowout that's been shared many many times...
  14. Dean Lowe
    Dean Lowe
    Maybe, maybe not. Jim ran the car after he found another short block.
  15. loudbang
    posted by 40ragtopdown in traditional images
  16. swade41
    swade41
    from Buffalo,NY
  17. Mark Hinds
    Mark Hinds
    from pomona ca
  18. swade41
    swade41
    from Buffalo,NY
    Yes someone got a nice piece, although that front axle is a little thin for me
  19. swade41
    swade41
    from Buffalo,NY
  20. loudbang
  21. mohead1
    mohead1
    Gammz, chryslerfan55 and loudbang like this.
  22. mohead1
    mohead1
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think its pretty unusual for a vintage race car to be found with its powerplant intact and in place. At least it looks that way on the outside. Most of the time engines blow up, partnerships dissolve, engines get sold off, etc., etc. The first thing I would want to do is dis***emble the engine and blower , freshen it up as required and fire it up! You can work on the restoration of the car later.
  24. bchctybob
    bchctybob
    Man, I wish I had found that Bantam!!
    mad mikey, swade41 and loudbang like this.
  25. swade41
    swade41
    from Buffalo,NY
    It was up in Michigan and my truck was acting up, or I would've bought it, I'm pretty sure someone bought it for $3500
    It was center steer and the whole body lifted like a funny car, the guy was listing it for his boss which was rebuilding it after he purchased it, but ran out of know how and got frustrated. It actually lasted over a day on marketplace and I was just watching it slip away with my broken *** truck in the driveway.
    https://www.facebook.com/marketplace/item/2056979097673616/
    Screenshot_20201026-213039_Facebook.jpg Screenshot_20201026-213108_Facebook.jpg
  26. swade41
    swade41
    from Buffalo,NY
    Another marketplace offering, I think this one was in the $8500 range, wouldn't p*** current tech and offered as a cackle car if I remember right.
  27. loudbang
  28. loudbang
  29. loudbang
  30. slayer
    slayer
    Here is a picture of the Fiat as it appears today. Magnum racing Fiat @ '11 pileup.JPG
