Hot Rods Tired of homogenized hotrods
Discussion in 'The Hokey Ass Message Board' started by onekoolkat1950, Dec 24, 2015.
  1. Stogy
    Stogy
    :rolleyes:...A Hambers Hotrod...can't recall his Handle...I will update...;)
    That would be Hamber @Harrison's...do you still have this or has it moved on? It was probably a pretty quick package being so light...
    Credit to Photographer, Owner
    A Boner, brady1929, GEBHARD and 2 others like this.
  2. Stogy
    Stogy
    :rolleyes:...Street Legal and getting ready to Rock N' Roll...
  3. ratamahata
    ratamahata
    from Argentina
    This car intrigues me. The photo appeared on the HAMB, posted by the owner's son, identifying the date as 1951 in Santa Ana, and noting that the car had a top-mounted blower on its flathead. That looks like an early Y-manifold of the kind that Weiand once made. It is a chopped '36 coupe with a '40 Ford deluxe hood, and innovative front sheet metal work. Does anyone recognize it? (FB post by David Sorenson)
    Look at the hood... Very long for a Ford coupe? Maybe more adequate for a Lincoln?[​IMG]
    Enviado desde mi Mi A1 mediante Tapatalk
  4. j hansen
    j hansen
    Stogy and ratamahata like this.
  5. Stogy
    Stogy
    @ratamahata, that wild 36 is way over the top and a slam dunk for the theme of the Thread.... @j hansen additional thanks for pulling those details out of the depths of Hamb...I'm looking at the unusual scoop at the front and thinking is there one of those front mounted superchargers and wondering if its an intake...Rat already noted that it may have a Blower on top of the engine noting the high stepping Y 2 into 1...
    Only 4 posts for @flathead60...Lets hope he chimes in and shares some more details as this is one unusual Hotrod...and any more pics and stories he might have to share...
    I always say many Hambers have really cool stuff to share...To all you Hambers that have had family, friends or otherwise there is no better place to share these rarities that molded the Hotrod/Custom movement...Great stuff Hambers...;)
    ratamahata likes this.
  6. Stogy
    Stogy
    :rolleyes:...It's Mr Hotrod...Hope all is well with you Gene...;)
    OLLIN, brady1929, GEBHARD and 5 others like this.
  7. Stogy
    Stogy
    :rolleyes:...Art of Hotrod
  8. ratamahata
    ratamahata
    from Argentina
    Stolen pictures from the FB post... Look at that front, maybe that barrel form sheet metal is hidding a front blower?[​IMG][​IMG]
    Jet96 and Stogy like this.
  9. Stogy
    Stogy
    That must be what it is as it looks off the the side of the center of the hood which rules out a grille which I initially thought...​
  10. Stogy
    Stogy
    :rolleyes:...nice inspired...I sure hope there's rubber seals on the fwd edge of the doors...
    knucklenutz, patmanta, brEad and 2 others like this.
  11. ratamahata
    ratamahata
    from Argentina
    Otto Ryssman's Crosley fuel coupe, early days at Santa Ana. Otto was an accomplished hot rodder who raced at both the lakes and the drags. He was an innovator who understood the meaning of weight reduction, so while other compe***ors were mostly using Ford bodies, Otto went to the lighter Crosley. Performance mattered to Otto more than looks, so the body damage on this car was never fixed. It looked crude but it won. Otto went on to run a dragster, first with flathead, and later, Chrysler power. Unfortunately the Chrysler dragster blew a clutch at Santa Ana, with the fragments killing a spectator who was sitting on one of the logs bordering the drag strip (Kent Lentz witnessed the carnage). Otto wound up in court and after a lot of legal expenses, he left hot rodding. This photo is from the American Hot Rod Foundation, where I go daily for some of the best hot rod information out there. Thanks again, David Steele, for all you do to keep memories alive. FB_IMG_1603385469426.jpeg
    Sent from my Mi A1 using The H.A.M.B. mobile app
    AHotRod, Six Ball, Jet96 and 3 others like this.
  12. Stogy
    Stogy
    :rolleyes:...I believe those are cycle tires up front which were used a fair bit back in the good Ole days and the Vented side hood panels work well on the Model A's and B's...
    OLLIN, AHotRod, A Boner and 13 others like this.
  13. Spex84
    Spex84
    from Canada
    I can't see how it would have both a front-mounted blower and top-mounted carbs.
    More likely is the car has a Graham supercharger with a slingshot adapter, and that weird front sheetmetal was a creative way to fill the hole created by removing the stock grille without having to form compound curves.
    Six Ball, Stogy and lurker mick like this.
  14. Stogy
    Stogy
    :rolleyes:...these windshields look great on many roadsters but there is some intense metal work to pull it off and heck might as well join the tank to the body while your at it eh!...and check out the hinges...awesome work...
    OLLIN, adam401, brady1929 and 6 others like this.
  15. Stogy
    Stogy
    AHotRod, ct1932ford, hfh and 4 others like this.
  16. Stogy
    Stogy
    Glenno_64, AHotRod, deadbeat and 8 others like this.
  17. Stogy
    Stogy
    I don't think that half rounded opening is centered to the hood...perhaps that was an intake for air for something under the hood before the carbs were added on top of the engine...
    brady1929 likes this.
  18. Stogy
    Stogy
    Is this NZ?...They are pretty adventurous in HotRod/Custom much as The East and West Coast is... @Kiwi Kev's ongoing thread on NZ has I suspect some of the best of what is a connected movement...Wherever the Big How Many was there Then...in the Hamb Era went Hotrod/Custom Happened...Good Times...
    The is it a 38 and 9 Truck Grilles are a nice edition to a Hotrod...I think that Bannister Bros A is a priceless work of Art that did the Dry Lakes at 140 or so ...I think...I think it needs a drop in the front and perhaps a front axle reposition but it is a Fat to Fat so they really could compliment each other
    brady1929 and Jet96 like this.
  19. GEBHARD
    GEBHARD
    from TX...
    anthony myrick likes this.
  20. Stogy
    Stogy
    There's another pic in this Thread of a double wheeled racer. It may be that one coming out of a Garage looking pretty sinister...Big Racer...​
    brady1929, anthony myrick and GEBHARD like this.
  21. Jet96
    Jet96
    from WY
    @Stogy -I think so, I found another photo...
  22. Speed Gems
    Speed Gems
    Here's a color image of the car taken from another thread
    OLLIN, AHotRod, N.Ozols and 9 others like this.
  23. Stogy
    Stogy
    :rolleyes:...A Winner and his Roaring Roadster and M is for Marty...;)
    AHotRod, A Boner, Six Ball and 5 others like this.
  24. Stogy
    Stogy
    :rolleyes:...Something tells me this fella had to lay the seat back a bit to fit in this Hammered beast...
  25. Stogy
    Stogy
    :rolleyes:...Evidently Pickups are indeed Hotrods...and may in fact whoop your Hotrod ***...:D
    AHotRod, uncleandy 65, Jet96 and 4 others like this.
  26. Stogy
    Stogy
    :rolleyes:...this may have been the Inspiration for the nose on Jake Jacob's Coupe...
    Or Did he happen to pick a cool grille up at a swap meet?...;)
    This pic gives me the feeling it was the ex's pic...but certainly a notable Hotrod with Dry Lakes dirt in its seams...
  27. Stogy
    Stogy
    AHotRod, Jet96, uncleandy 65 and 4 others like this.
  28. Stogy
    Stogy
    :rolleyes:...rough around the edges but largely reflective of the big picture...
    patmanta, AHotRod, Jet96 and 5 others like this.
