Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. The windshield stanchion you have pictured is for a standard roadster. If you doors sag at the rear, put shims at under the bottom of the cowl next to the door jamb. That is what we had to do for my first roadster.
    Woogeroo, Stogy, J.Ukrop and 2 others like this.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    "Joey, looks like you got some tires!" That's a great thing to hear in the middle of the work day. I now have the fronts, and I'm waiting on the rear tires, tubes and the rim strips. The trim rings were provided by Charlie at North Palm Speed.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    One of the most fun parts of building this car is digging up San Francisco hot rodding history. I spotted these jack stands on Craigslist a couple months ago and tonight I finally got them. I bought them from a gentleman named Nick who lives in the Monterey Heights neighborhood. The story goes that back in the 1950s and early-'60s he was a member of the Pitmen (?) car club here in San Francisco. In those days, he drove a heavily channeled, pink Deuce roadster with a 59AB flathead. I asked him if he had any photos and he shook his head. "We just didn't take a lot of pictures of stuff back then." He does, however, still have a 1953 Studebaker. I wasn't able to see it on this trip. Maybe some other time?
    He said the jack stands are made from 1932 Ford axle bells. He cut them with a torch, welded on the handles and had them sandblasted with full intent of painting them. "As you can see, that never happened," he said. "Instead, I put them right into service!" Surface rust aside, I think they'll be a good addition to my shop.
  4. Tim
    Tim
    from KCMO
    Great progress! I always like seeing my car up on some axle tube jack stands. Just something about it makes it feel even more like a time warp.
    and the ones @porkn****** has are tall enough that we can easily fit our fat heads under my low cars lol.
    On the LED note if people are still thinking about that, Costco has good a killer deal every once in a while and they’re like $13 or something. Maybe less. They’ve got pull chains and you can daisy chain multiples together as well. I always buy a few when they go on sale.
    Dannerr, Big mike 1968, lewk and 8 others like this.
  5. davidvillajr
    davidvillajr
    It's a moral imperative!
    Big mike 1968, loudbang and Stogy like this.
  6. 41 GMC K-18
    41 GMC K-18
    Hey Joey.
    Did you get the PM I sent to you?
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Yes! I've been caught up in a lot of things editorially, but I'll get back to you tomorrow!
    catdad49 and 41 GMC K-18 like this.
  8. Early Ford axle tubes were the things to use way back then. They stood up well, and don't fail you when it is important not to fail. Plus, on a good solid concrete floor, they can hold a lot of weight.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
  10. Leon Sandcastle
    Leon Sandcastle
    winduptoy and J.Ukrop like this.
  11. jim snow
    jim snow
  12. sloppy jalopies
    sloppy jalopies
    just got a lesson in tire mounting... those new tires wrapped in plastic won't open enough to make an air seal when mounting them tubeless... so put a tube in it without a rim, pump it up big and let it set for a few days... tube on the shelf, waiting on a 165 75R 15"...'51 ford car rim...
  13. Much as I enjoy a high skill build of a killer car, something about this thread just warms my heart. Of course I am not saying your car is not killer.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Good info for sure. I talked to the tire shop who have been working with hot rods since the 1960s and they recommended tubes and rim strips for them. I'm taking that route.
    Thank you. I'm just working to build the most straightforward early hot rod and learning along the way. Some days are certainly easier than others!
    ct1932ford, catdad49, Tim and 5 others like this.
  15. gimpyshotrods
    gimpyshotrods
    @J.Ukrop, second week of November I will be moving into my new shop space. That will unearth all of the trapped items that I have in storage. I will dig out the juice backing plates, and see if I have any other goodies that will fit your project.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Yesterday was a full and very fun day. On Friday night, I could hardly sleep because I was so excited to wake up early and work on my car. Does that ever happen to you guys?
    First and foremost, I rolled it out of the garage and fired it up. It started easily and sounded good. Next, I got everything in position to test all five '35 Ford wire wheels for runout. Safety measures included a swept driveway, jack stands (4x), wheel chocks, jack in position under the axle and two friends nearby. Before working, I leaned on it pretty hard and it did not budge. With that sorted out, I proceeded.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Excellent! Can't wait. Thank you!
    Outback likes this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The verdict on the wheels? Out of the five, three seemed to be good according to my primitive measuring system. One appeared to be okay-ish and one was bad. Interestingly enough, the worst one was one of the original paint ones. That's just the way it goes.
    So do I have a full set? Hard to say. I'm going to go down to Andy's Tires and Wheels in South San Francisco on Monday morning. They handle all the rolling stock for Roy Brizio's builds and they know their stuff. I'm really hoping that I'll be able to use them. If not, I'm back on the hunt.
    With the wheel off, I decided to take a look at the brakes just for fun. It's no surprise, but they've seen better days. I was surprised to see yellow shoes. Were these stock or an early aftermarket replacement? Either way, it became immediately clear why the braking left a bit to be desired.
    Once I get the wheel situation sorted, I'll clean and sand everything. I'll mic the drums to see if they're within spec, and then I think I'm going to buy new brake shoes all around.
    catdad49, Tim, Outback and 6 others like this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Finally, I took this photo just because I though the car looked nice sitting there in my driveway. It got lots of attention from the neighbors yesterday—that's for sure! IMG_1106.jpg
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Oh, I almost forgot the most important part! You know I had to do a quick mockup with the new tires and the windshield. IMG_1101.jpg
  21. carothersbs
    carothersbs
    That’s awesome
    Thank you.
    Brian C.
    Reno NV
    chryslerfan55 and J.Ukrop like this.
  22. Hotrodmyk
    Hotrodmyk
    @J.Ukrop Those appear to be aftermarket "bonded" brake linings. The original ones are a woven, riveted type. The bonded material is too hard and doesn't work as well. (too much pedal effort) Check out a Model A vendor such as Brattons or, closer yet, Sacramento Vintage. They can help out.
    catdad49, loudbang and chryslerfan55 like this.
  23. pprather
    pprather
  24. Leon Sandcastle
    Leon Sandcastle
    Any upgrades to steering and brakes? I might have missed that part.
    Sent from my SM-N960U using The H.A.M.B. mobile app
  25. gimpyshotrods
    gimpyshotrods
    When you say bad, how bad? How far off was each?
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Three seemed to be within 1/8th of an inch as measured by the lip and have no major wobble. The inner portions seemed straight and true. One has a slightly wavy lip and the last one seemed pretty lopsided. Like 1/4-inch or more. I’ve only done this with motorcycle wheels so this is pretty new to me. As mentioned earlier, these will be installed with tubes.
    catdad49 and chryslerfan55 like this.
  27. pprather
    pprather
    Sometimes that wavy lip can be improved with a tire iron and a hammer.
  28. gimpyshotrods
    gimpyshotrods
    One of these can be of help, too: https://www.speedwaymotors.com/Speedway-Steel-Wheel-Rim-Repair-Wrench-Tool,2691.html
    At $20.99, it is pretty easy on the wallet.
  29. Outback
    Outback
    from NE Vic, Oz
    Put the best ones on the front. As has been said rims can be straightened - to a point. Love your build!
    chryslerfan55, catdad49 and J.Ukrop like this.
  30. captain scarlet
    captain scarlet
    from Detroit
    Very cool ride [emoji41]
    J.Ukrop likes this.
