Hot Rods Wrong wishbone
Discussion in 'The Hokey Ass Message Board' started by woodsnwater, Oct 22, 2020.
  1. woodsnwater
    woodsnwater
    from North Al.
    I've got a good dropped model A axle, 2-1/4 boss and a good 36 wishbone, made for 2" boss. What is the best way to make these two fit together?
    I've cut the spring in front mounts off already and there seems to be a lot of meat left on the upper, spring perch side of the bone. Plenty to take a 1/4" out.
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Either mill the axle perch bosses down to 2 inch or change wishbones. I wouldn't mill the bones.
  3. xix32
    xix32
    Mill an 1/8" off each side of the axle. Or why not use a model "A" wishbone ?
    Automotive Stud and woodsnwater like this.
  4. woodsnwater
    woodsnwater
    from North Al.
    I don't have a mill so this is going to be done with a band saw or a grinder, or both. The reason I was going to cut the bones is because the axle is worth more. But y'all are right, the axle would be easier.
  5. woodsnwater
    woodsnwater
    from North Al.
    Look how thick the 36 is up top.
    31Apickup likes this.
  6. I am sure someone in Alabama owns a mill
  7. Andy
    Andy
    Cut the bottom lug off, assemble, weld the lug back on.
    They weld really nice.
    woodsnwater likes this.
  8. 1946caddy
    1946caddy
    from washington
    Weld the end of the Model A wishbone on the end of the 36 wishbone and adjust you caster at the same time.
    bchctybob and woodsnwater like this.
  9. Crankhole
    Crankhole
    Find the correct bones.
    lewk, Automotive Stud and woodsnwater like this.
  10. Cut it all off the top part as this is only thicker because of the canter lever for the spring mount, this will let the perch bolt have more of the shaft in contact with the axle and make sure the perch bolts are not loose in the axle. JW
  11. woodsnwater
    woodsnwater
    from North Al.
    Thanks to all who replied, I took the bones to a friend that has a mill. I hate to ask for help like that but I was afraid I wouldn't be happy with the results if I did it.
    26 T Ford RPU and Hollywood-East like this.
  12. Automotive Stud
    Automotive Stud
    I'd sell the bones you have and buy a model A wishbone. You'd probably come out money ahead.
  13. gimpyshotrods
    gimpyshotrods
    I tossed my bones in the mill, took off 1/16th off the bottom, and 3/16th off the top.
    It took longer to set up than to do it.
  14. Get the right wishbone and be done with it is the easiest way.
    You can get yolks for the A and swap them out or you can mill the axle. But unless I was married to the '36 wishbone i would just find the right one and run with it.
  15. krylon32
    krylon32
    from Nebraska
    Wouldn't going to a 37-40 wishbone be easier? I've used them on several customer chassis with no problems.
  16. I think this is largely about using what ya got, making it work and learning something instead of too hard why try. JW
    Fordors and woodsnwater like this.
  17. Open up the wishbones, I made my '35/'36 wishbone outside smaller to fit a lower shock mount (and a AA perch bolt).
    gimpyshotrods and woodsnwater like this.
  18. Atwater Mike
    Atwater Mike
    Glad to hear you got the axle milled. Some of the responses were making me nervous...:eek::D
  19. Using the right wishbone makes you nervous? :eek:
    sorry I just could not resist. :D:p:D:D:D:D
  20. gimpyshotrods
    gimpyshotrods
    He said he took the bones to someone with a mill, not the axle.
