Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. paul55
    paul55
    from michigan
  2. GEBHARD
    GEBHARD
    from TX...
    Thanks!
  3. paul55
    paul55
    from michigan
  4. Great thread, glad I found it!
    ('31 AE Independence)
    Fern 54, tb33anda3rd and TFoch like this.
  5. GEBHARD
    GEBHARD
    from TX...
    Just found this on youtube :)
    Fern 54, TFoch, stingbean and 2 others like this.
  6. flatmotor40
    flatmotor40
    from georgia
    Can you adjust door gaps by bending the hinges on a 35 Standard.Need to get top of door up more to get it from hitting B piller
    Bowtie Coupe likes this.
  7. tb33anda3rd
    tb33anda3rd
    how does the front edge of the door align with cowl?
  8. paul55
    paul55
    from michigan
    Need to shim the body. If the doors need to go up, loosen the first three body bolts. Put the necessary shim thickness on the second one back, then pull the cowl all the way down. Then go back to the third body bolt and most likely will need approx. the same thickness as the second body bolt. You don't want to pull the third one back down too much, as it widens the gap at the rear of the door towards the rocker. If it needs to go up a tad, start with 1/4" shim. 3/8" if door dragging pretty good.
  9. flatmotor40
    flatmotor40
    from georgia
    I haven't been in shop for 6mo because wife and I have been under weather.But this is an on going problem.Tried shims under frame to no avail.You can put a bottle jack on back of door and jack door up to get lined up with the reveals and tack A piller in and let jack down and door goes way back down again.The frame is bolted to the bottom body plate.One mor think I need the measurment from outside of quarter panel to quarter panel at bottom Of door opening at the B piller.I'm going to try to puss firewall back a little with a port power it seems to push door up in place.I have replace all wood with metal by using the wood as a pattern.Thanks for help.I will try to make a pic if I feel good the next couple days
  10. killbilly
    killbilly
    Bill {Uncleandy}...sorry i missed your post back in June...I am in Schererville ...thanks Phillip
  11. paul55
    paul55
    from michigan
    If you put, say a 3/8" shim between the wood sill and frame(second bolt back), and take all shims out at the front firewall bolt and then pull it down to the frame, it will raise the door and close the gap at the rear of the door. You have to loosen the first 3 bolts completely, as the 3rd bolt back will require a new, thicker shim.
    Fern 54, tb33anda3rd and Bowtie Coupe like this.
  12. flatmotor40
    flatmotor40
    from georgia
    Paul I think I found something yesterday the firewall at the bottom has a "l"brkt and I put it where it is suppose to be so I took it out and used a portpower to push the bottom of firewall backward and it raised the door up like it suppose to.I think that was binding it up.I made all metal pieces by the wood dim and they were exact size and transfered hole form the top to the new metal base.So all holes should line up but it didn't.Maybe today I will tack weld it in and see how it stays.That is the long piece that you bolt frame to.Still need the measurement of the outside of 1/4 panel at bottom of door so I can make sure to get width right.I braced it before I took flor out but you know how it still moves Thanks for help
  13. Chuck Craig
    Chuck Craig
    from Ocala FL
    I would not do this if I understand the question. You can adjust the gap at the top rear of the door by adjusting the frame/body mounts. Loosen the first mount (located under the rear hood latch opening, and then loosed the second body/frame mount (located at the b pillar). Insert a shim (this will or could take a few different sizes) under the wooden portion of the main sill just in front of the b pillar mount location then tighten the front mound down first, then the b pillar. This should raise the back of the door. You could also have some bad wood in the main sill or in the a pillar. Open the door and lift up on the rear to see if you have movement. Depending of the movement this process may or may not work, because if the wood is bad, you must replace it so that the door is solid mounted and the body is not sagging on the main sill. There is a GM Fisher body manual that gives instructions on how to do this. I see in later post that you have replaced some of the wood with metal. So not sure that all the alignment is set. If anything moved as you were replacing the wood you may have to reset some of your welds. The main sill (runs under the body, sits on top of the frame is very important in getting the alignment of the doors, cowl and hood and can change the deck lid.
  14. flatmotor40
    flatmotor40
    from georgia
    Thanks the main sill was rotten as always so I made a new metal by copping the wood on as I did for all the wood.I think I have to do the doors first with all the latchs and see where it goes from there.Don't have too much time now to work on it because of heath problems.Buit I will not quit this is my 5th car to build by myself.But with the 40 on my pic did a full frame rotisserie and made all new floors but the A piller and B piller stayed complete because rocker was good not like Chevy's they let the rockers loose with nails.But that is why we do these things.Thanks
  15. GEBHARD
    GEBHARD
    from TX...
  16. chev34ute
    chev34ute
    Hey Guys.
    I only just discovered this thread today, so I have been looking through all the posts. This is the pile of panels, I picked up two years ago. It comprised of a cut up 29 Truck cowl, single door and a 28 Tourer rear door. E3F1B743-6999-4117-8132-BB53DA26640D.jpeg 5B585D0F-D152-4D87-BE41-1875796EF039.jpeg
  17. chev34ute
    chev34ute
    I will be fabricating everything from the cowl back into a closed pickup cab including the doors out of new steel . I am not worried about the task but the biggest challenge will be recreating the lower part of the cowl that is missing. I will be using these mid thirties Chev truck doors as a pattern for the new ones. These doors are actually for closed cab trucks and extremely rare, but look similar to the 27/28/29 truck doors. 2D5E442C-0139-4123-A1DE-57CB3A86B401.jpeg
    Bowtie Coupe, Fern 54, TFoch and 2 others like this.
  18. chev34ute
    chev34ute
    Here is the start of the cab. I have been using sheets of MDF as patterns for the sheet metal.
    Bowtie Coupe, Fern 54, TFoch and 4 others like this.
  19. Six Ball
    Six Ball
    from Nevada
    It looks like a great start to me. That kind of metal work is just magic to me. Keep us up on your progress. Years ago I hauled most of a '27 pickup cab home. Other than a few bullet holes it wasn't bad. I don't know if I have any of it left or not. I found another one in an old dump in a Ghost town but when I went back to get it I found it rolled into a ball by a bulldozer.
  20. fordflambe
    fordflambe
    My "wayback machine" found this one (Aug-1976) of my 31' Coach as I was giving my younger brother his first ride in it.
    And then it came apart for lipstick ...................
    Then after a couple of decades on the road.................
  21. IMG_1747.jpg Just stumbled across this while searching for other stuff. I'll be spending the next few hours reading all of it. I recently rescued a 36 Chevy 5 window coupe that was a g***er in the 60s. Parked and left to rot in 1970 when the track closed. The ch***is is squared away and now I'm looking for tips on replacing the wood framework that went between the ch***is & the floor. I'm leaning towards 1x3 rectangular steel for the sides and probably 1x1 or 1x2 cross bracing. Any help would be hugely appreciated.
    biggeorge, Fern 54, PBRmeASAP and 3 others like this.
  22. PBRmeASAP
    PBRmeASAP
    more pics please
  23. Six Ball
    Six Ball
    from Nevada
    biggeorge likes this.
  24. Not much to see so far body wise but here she is. Floors are pretty much non-existent and the wood is bad also. 111999229_1001595963608052_9211414049108110050_o.jpg 110823541_1001595983608050_5087637599647601030_o.jpg IMG_0957.jpg IMG_0979.jpg
    Torkwrench, biggeorge, TFoch and 6 others like this.
  25. She's a rough old girl. When I got it it still had stock front brakes and the guy I bought it from thought it had a Ford 9" rear. Turned out to be a 58 Olds rear with welded spiders and 5.38 gears. The rear tires were old bias ply Redlines that were date coded 1970 mounted on 15x10 Aluminum slots. IMG_0960.jpg IMG_1022.jpg
    Torkwrench, biggeorge, TFoch and 9 others like this.
  26. Anybody know for sure if 33 chev 4 door ,front doors ,will fit 5 window coupe ?
    Can somebody provide some measurements of a 5 window door ?
    Thanks
  27. rtomss, Fern 54 and biggeorge like this.
  28. just wondering if any one knows if mad mike 3434 is still part of the hamb he seemed to have a lot of 34 chev info thanks
  29. Dick Stevens
    Dick Stevens
    He doesn't appear to be, he was last seen in April 2019 and when trying to pull up his profile it just shows up as "ERROR", so he is apparently no longer a member
  30. I thought he had possibly changed to mad mike 34 35 but couldn't find anything
    but I do **** at navigating the site so far
    thanks for the reply ****
    While I'm on here I am in need of a 34 master rad shell
    apparently I have a 33 if anyone needs one
    have yet to figure out how to post a parts wanted add
