Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    The top rail was tacked with mig and welded with tig.
    So far, with the exception of tacking and spot welding, all the welding on the body of this car has been with tig.
    I've had this machine for close to twenty years and am just now forcing myself to learn how to use it.
  2. lake_harley
    lake_harley
    That's what I thought, thinking that MIG would be somewhat easier while trying to position a part to tack it. I believe I've said it before, but your entire build is nicely done and inspiring as to what can be done with skill and plenty of patience.
    Lynn
    Kreepea_1, The 39 guy, Stogy and 2 others like this.
  3. Paul
    Paul
    Editor
    Outriggers to floor framework..
    PXL_20201024_212652157.jpg PXL_20201024_213818859.jpg PXL_20201024_214632390.jpg PXL_20201024_221114409.jpg PXL_20201024_234843099.jpg PXL_20201024_235313111.jpg
  4. vtwhead
    vtwhead
    Awesome work Paul. You keep me motivated!
    Stogy, loudbang and Paul like this.
  5. RodStRace
    RodStRace
    A couple of things:
    I always wondered why those areas between the outside of the frame rails and the body weren't opened up to allow for little storage cubbyholes. They would end up catching anything rolling across the floor, but Ts never have enough space... even a pocket for paperwork, gl***es/goggles and a soft hat would be useful.
    Are you considering moving the battery box forward enough so it's between the floor bracing? Maybe it's the angle, but it looks like the rear of the battery is going to catch on the frame.
    As always, these are just observations, not criticizing your fine work.
    EDIT: thanks for the replies!
    Not even enough for one of these by the seat?
    https://www.****ies.com/tool-bags/small-wrench-/-tool-organizer-roll/57007BD++AL.html
  6. Paul
    Paul
    Editor
    It is the camera angle, there is just enough room to access the battery through a door in the floor.
    AHotRod, chryslerfan55, Tman and 9 others like this.
  7. Paul
    Paul
    Editor
    And I have considered doors to access the "rocker" areas.. there is just enough room for a 1/2" wrench in one and a 9/16" in the other on each side.
  8. Paul
    Paul
    Editor
    Teaser picture..
    bct, bchctybob, 51box and 14 others like this.
  9. The 39 guy
    The 39 guy
    Looks like this will be one of the sturdiest ( structurally sound ) T's I have seen . I am enjoying your build!
    Stogy, OFT, loudbang and 3 others like this.
  10. Paul
    Paul
    Editor
    ok, backing up a few days..
    worked on front corners
    PXL_20201029_200212074.jpg PXL_20201029_200218014.jpg PXL_20201029_200143036.jpg PXL_20201029_200202898.jpg PXL_20201029_200155318.jpg PXL_20201029_220846810.jpg
    Just Gary, bchctybob, AHotRod and 9 others like this.
  11. Paul
    Paul
    Editor
    welded the floor framework to the body
    and bolted the body to the frame
    PXL_20201030_002633905.jpg PXL_20201030_185957714.jpg PXL_20201030_185951757.jpg PXL_20201030_010453955.jpg PXL_20201030_011604611.jpg PXL_20201030_190335104.jpg PXL_20201030_214754839.jpg
  12. Stogy
    Stogy
    Man you're good @Paul...;)
    loudbang, OFT and Paul like this.
  13. Paul
    Paul
    Editor
    rolled it outside to turn it around to work on the p***enger side
    PXL_20201030_215507347.jpg PXL_20201030_220033351.jpg PXL_20201030_222058251.jpg
    bchctybob, cactus1, AHotRod and 12 others like this.
  14. Paul
    Paul
    Editor
    working on door jambs and body bracing
    bchctybob, cactus1, AHotRod and 11 others like this.
  15. Paul
    Paul
    Editor
    checking seating location..
    yes, I still fit.. barely
    bchctybob, cactus1, 51box and 13 others like this.
  16. AndersF
    AndersF
    Really nice work on the body and the floor webbing.
    And the overall stance is spot on.
    bchctybob, brEad, loudbang and 3 others like this.
  17. Paul
    Paul
    Editor
    Door slam'n
    bct, AHotRod, chryslerfan55 and 6 others like this.
  18. 30tudor
    30tudor
    Very stout construction on all the sub frame and interior, good use of some square tubing.
    loudbang, Stogy and Paul like this.
  19. Paul
    Paul
    Editor
    Lowering the turtle deck, it really bugged me how high it sat, means redoing the notch over the upper shock mounts, but ya gotta do what ya gotta do..
    Jrs50, AHotRod, El Hueso and 7 others like this.
  20. Dick Stevens
    Dick Stevens
    Glad to see that you are making that change, it didn't look right to me either!
  21. Stogy
    Stogy
    Great resonance and a big proud smile I'll bet...:D
    Damn near jumped out of my chair...:eek:
  22. Paul
    Paul
    Editor
    Moving turtle shock notches up 1-1/2"
    To lower deck like amount
    Sheet metal rough in done both sides.
    Stogy, bchctybob, AHotRod and 11 others like this.
  23. jebbesen
    jebbesen
    from Winona, MN
    You really do nice work! Lowering the deck was the right move in my opinion. I always like the tires to stand up higher than the trunk on the turtle deck T's. Maybe because I spent so much time looking at pics of Iskys car when I was younger. Its kinda the standard against which all T's are judged in my mind:)
    OFT and loudbang like this.
  24. Paul
    Paul
    Editor
    Thanks, the 8.20-16 is right flush with the top, the alternate (right now) L78-15 is just a skosh below.
    You can see the big dirt tires a few posts back,
    Here's the street (still relatively big) tires..
    This is essentially no load
    Stogy, triumph 1, bchctybob and 18 others like this.
  25. Paul
    Paul
    Editor
    Working on the body,
    getting rid of weld warp highs and lows.
    PXL_20201114_004502773.jpg PXL_20201114_004509478.jpg PXL_20201114_004521272.jpg PXL_20201114_004529646.jpg
    Stogy, El Hueso, The 39 guy and 8 others like this.
  26. Paul
    Paul
    Editor
    Working it slowly with fire, water, wood and steel.
    Oil canning is gone,
    only needs a little love to smooth things out.
    bchctybob, Stogy, patmanta and 4 others like this.
  27. AHotRod
    AHotRod
    Excellant work Paul ... but I except that from you after 21 years.
  28. Paul
    Paul
    Editor
    Trying a slightly different technique shrinking this time.
    I used to do it all with heat, hammer and dolly and wet rag.
    This time I bought a small wood mallet and put a slight crown on one face and made a wood dolly of rock hard maple.
    Heat the area that needs shrinking then
    using either the wood hammer and dolly
    or steel hammer and wood dolly
    or wood hammer and steel dolly
    I get a lot more control of the metal
    and a lot less work hardening.
    The plastic hammer and steel dolly works great on cool steel too.
    Then finally smooth it out gently with hammer on dolly.
    My tendency before was to work too much hammer on dolly and end up not only work hardening but stretching the area back some.
    I was fighting myself.
    This approach is much more gentle and works so much better.
  29. Tim
    Tim
    from KCMO
    Awesome, that’s great information as well
    Stogy, loudbang and OFT like this.
  30. grumpy gaby 2
    grumpy gaby 2
    Paul Great info. I've got a 26 Chevy roadster body that will have to have several areas along the bottom replaced. Will try your method!
    Stogy and loudbang like this.
