Projects 1949 Shoebox Ranchero Build
Discussion in 'Traditional Customs' started by jakesbackyard, Nov 28, 2018.
Hinge covers??
Poll closed Sep 29, 2021.
  1. Left
    35 vote(s)
    89.7%
  2. Right
    4 vote(s)
    10.3%
  1.
    bchctybob, loudbang and brEad like this.
  2. jakesbackyard
    jakesbackyard
    from ND
    thanks much. I’m at 25” and just shy of 90 degrees so I’m going to squeeze them together and add a bar across the top. Great information and should help.
    bchctybob, loudbang and Pist-n-Broke like this.
  3. I've learned that this top of the U bracket is the best place to adjust the actual Hood side gap. I'm not sure there is a specific perfect number for the Top of the U bracket. Before locking in on that I would have the Hood mounted and squared to the Cowell with a good gap there. Then add the fenders and make the Gap you want. Raising and lowering the mount point of the Core support will make the Hood itself change both gap and angle at the Cowell. Moving the fenders on the inner fenders just changes the profile from door edge to hood latch point. I noticed it looks like a hand crafted inner fender panel on your Right side and a Factory one on the Left. Could give you a little extra work in making it all come together.
    loudbang and kidcampbell71 like this.
  4. jakesbackyard
    jakesbackyard
    from ND
    Making panels fit on almost any car is a major undertaking. I’ve been doing it for so long that it usually gets done pretty well. Just nice to know some of the quirks of a certain model. Last time I had anything to do with a shoebox Ford was 1967. All the panels are originals from 4 different cars. I cut the inside of the air tube off the right side so I can mount the battery on the right side for the SBF. Thanks for the insights.
  5. jakesbackyard
    jakesbackyard
    from ND
    Fenders mocked up and fit. A little more tweaking and welding and they’ll get sprayed with epoxy...starting to look like a car...
    6DE53946-9DC1-49E5-B465-0DAB507FC17D.jpeg 1DA19840-7ADF-48BC-8A7C-0D02DEB95757.jpeg
    Jigger, j-jock, bchctybob and 15 others like this.
  6. I'm not a singer: transpose "it's beginning to look at lot like Christmas" into it's beginning to look like a hot rod. :)
    loudbang and jakesbackyard like this.
  7. Looking good! Getting closer. :) I wonder who makes an interior kit for a '49 Ranchero? :D
    Atwater Mike and loudbang like this.
  8. desotot
    desotot
    Looking good, nicer than a ute.
  9. jakesbackyard
    jakesbackyard
    from ND
    I know a guy...haha...
    Jigger, Atwater Mike, brEad and 2 others like this.
  10. jakesbackyard
    jakesbackyard
    from ND
    Front end in epoxy, together and aligned pretty well...now to work on the bed interior...
    08C6E9FA-A9E1-4E03-B6C4-34B117B3CC42.jpeg C29E6B26-F2F8-4890-AE0F-1FF653ECFF5F.jpeg 5437F195-FB54-4989-ADA2-2C8F4438C9BF.jpeg ADE331FC-F1C7-46B4-8B1B-496E713737EE.jpeg 823C41CF-FCDA-4862-8E87-C9E33CBF2EAE.jpeg
    Jigger, Baumi, TFoch and 22 others like this.
  11. Looks great, Jake! Shop looks nice and tidy too.
    Baumi, Randall and loudbang like this.
  12. jakesbackyard
    jakesbackyard
    from ND
    Thank you. My shop was a disaster yesterday. Took down my makeshift booth after priming the hood yesterday and spent all morning today cleaning and putting things away before I put the hood on this afternoon.
    brEad, bchctybob and loudbang like this.
  13. I so love progress. :)
  14. jakesbackyard
    jakesbackyard
    from ND
    Box pretty much done. Still needs tailgate cables and it’ll get a coat of bed liner when the body is in final primer. Time to do a bunch of body work and mudding...
    9B3FE177-3FB7-4EEE-9FCB-022069E111B4.jpeg 737F9260-B258-4BF1-926B-FEDCF77B5CA6.jpeg A4929445-34D5-41C2-B7C4-0C6967F92B8F.jpeg 5B242EC6-B45B-4BE1-A9CB-2747CE5D2E04.jpeg 51AD06C0-A7C7-419F-B782-B54EA1356C01.jpeg
    Jigger, Baumi, j-jock and 20 others like this.
  15. 1-SHOT
    1-SHOT
    from Denton
    Love the license plate. HENRY SHOULD HAVE DONE IT
  16. warhorseracing
    warhorseracing
    from cameron wv
    Are the plans to use the plywood as templates and do the entire bed in metal? IMO that would be the way they came from the factory and you do have the skills. Either way it is a beautiful example of what should have been.
  17. jakesbackyard
    jakesbackyard
    from ND
    Thank you. It will remain the way it is with a coat of black bed liner.
  18. K13
    K13
    Looks great Jake.
  19. kevinrevin
    kevinrevin
    from East Texas
    I was expecting to see the bed floor amd sides from a donor pickup, like a Ranger, but the bedliner painted over that wood should look ok too.
  20. Fabber McGee
    Fabber McGee
    I built a flat bed for my 75 Ford 4 x 4 and decked it with 1 and 1/8 tongue and groove plywood. Then had it sprayed with 2 part urethane bed liner. That stuff is tough. After hauling about anything you can name on that deck for 15 years, the coating is still perfect. Road spray has finally rotted the wood from underneath in a couple places, but I'm starting to thing the coating can not be damaged. It is nearly 3/16 thick and no wood grain shows through, just has a nice pebbled surface. I think it's an excellent choice for the shoebox.
    They could have also made it a smooth finish, but said it would be too slick to stand up on. Pebble finish was made by fogging the top coat from several feet away.
  21. Dick Stevens
    Dick Stevens
    Are you going to be able to coat the bottom side too? It would be a shame to have the deck rot on this great build!
  22. jakesbackyard
    jakesbackyard
    from ND
    It’s treated. I’m sure it will outlast me. Lol.
    Randall, loudbang and warhorseracing like this.
  23. Dick Stevens
    Dick Stevens
    I certainly hope that you and the deck last a long, long time!
  24. RealOG
    RealOG
    from FRANCE
    Work is incredible
  25. jakesbackyard
    jakesbackyard
    from ND
    Thank you. The plate is not legal (too many characters). A friend made it. I’ve got thoughts in the same vein for a legal one. Always thinking...
  26. Peanut 1959
    Peanut 1959
  27. Dick Stevens
    Dick Stevens
  28. ND14ME NOJSTME NOTAUTE
    brEad, RMONTY and loudbang like this.
