Projects 53 customline
Discussion in 'Traditional Customs' started by Ferdyeight, Mar 2, 2020.
  1. Rocky
    Rocky
    Classified Editor
    Cool history on a good looking 53. I've always wanted a "spaceship" 52-54 but always end up with either shuboxes or 55 fords.
    54delray, loudbang and chryslerfan55 like this.
  2. JeffB2 and loudbang like this.
  3. Ferdyeight
    Ferdyeight
    Got my new rear end from my uncle, its a grenada rear with 2.75 gears. Hoping it will work behind the AOD and hoping the pinion length is gonna be OK so I dont have to buy a new driveshaft.. but i got a new speedo cable and gear and now I can see how fast I'm goin! 20200902_172910.jpeg
    Sent from my SM-G975U using The H.A.M.B. mobile app
    Toms Dogs, chryslerfan55 and loudbang like this.
  4. Ferdyeight
    Ferdyeight
    And i have to fix this setup somehow. May have to wait till winter when the car goes to my dads where I have access to a lift to do the floor pans, driveshaft tunnel, rockers and front door patches. And hopefully I can con my dad and uncles to re align the front sheetmetal and get the body gaps somewhere close to respectable.. 20200902_163430.jpeg 20200902_163442.jpeg
  5. Ferdyeight
    Ferdyeight
    Picked up some arm rests the other day, and got em installed yesterday. Got an early falcon center console on the way as well. IMG_20200916_180753_966.jpeg
  6. Ferdyeight
    Ferdyeight
    Also: if anyone has the piece of chrome im missing off the garnish moulding id be interested!
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Looks like someone wacked off the original transmission cross member and replaced it with angle iron. This is a '53 with a 302/AOD using a Butch's 15" swap kit https://butchscoolstuff.com/52-53-ford-car-15-sb-ford-engine-transmission-mount-kit-2501cpb/ It only required some redrilling for the mount. Second picture is from the rear. AOD 2.jpg
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Different angle from the rear shown here. If you can locate a drive shaft from a 1982-86 Crown Vic it may bolt right up,I used one in my '54 with a 302 &AOD just changed the rear U-joint to bolt up to the stock rear.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is another view of the '53 stock cross member with AOD The next picture is my '54 with the 1986 Crown Vic drive shaft. AOD53.jpg
  10. Nice 53! Mine is a Mainline, and I also have a 302 in it. But I went off the rails and kept the 3 on the tree with a top loader and homemade shift linkage to keep the original steering column. Made exhaust routing fun. I also put the camber kit in with dropped springs and spindles. Getting the camber right is a pain. I left my air dam off..
  11. Ferdyeight
    Ferdyeight
    Looks like a lot cleaner of a setup than what I currently have, im going to have to look for an original trans crossmember to fix mine.. is it possible to pull your trans out without pulling the engine with the setup you have? I need to put a new trans in my car, and I would hate to pull the motor too.
  12. Ferdyeight
    Ferdyeight
  13. loudbang likes this.
  14. Ferdyeight
    Ferdyeight
    Thanks! I had to take all the bikes out of the garage to clean up and figured I'd get a couple cool pics.
  15. Ferdyeight
    Ferdyeight
    Anyone out there got a grille bullet delete, or a stock automatic column they'd let go for a 53? I'm lookin to get rid of the floor shift and clean up the front end a little bit.. D0C2EBCF-4A5E-49AF-A6EB-6B0E049B5C27.jpeg
  16. Zax
    Zax
    There was a bullet delete in the for sale section yesterday, but it sold pretty quick. Any chance it was you that bought it?
  17. Ferdyeight
    Ferdyeight
    Negative. I was buyer 2 in line for it from what I hear. I have seen 2 for sale in the past few months but haven't been able to get one.
  18. Zax
    Zax
    I'll keep an eye out for you.
    Ferdyeight and loudbang like this.
  19. Ferdyeight
    Ferdyeight
    Thank you! I appreciate it!!
  20. Ferdyeight
    Ferdyeight
    Playing with grille ideas right now... may have to widen this 55 olds grille I picked up.. 20201012_164513.jpeg 20201012_171951.jpeg 20201012_173441.jpeg
  21. Ferdyeight
    Ferdyeight
    Anybody out there got a 55 olds grille they'd be willing to part with?
    54delray likes this.
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    Contact this guy for a transmission cross member https://www.facebook.com/watch/?v=347866255934591 You are also better off to pull the engine and transmission as a unit and do the install it is not uncommon to have an issue getting the AOD torque converter seated properly it is much easier with the engine and transmission out of the car. You can find some great videos on youtube to help get that converter in right. Also when you reinstall the engine and transmission as a unit it will help you to know where to redrill the new mount holes in the replacement cross member like you see in the pictures above.
  23. Ferdyeight
    Ferdyeight
    Sounds good to me! I appreciate you lookin out! I will contact him as soon as I free up some fun money and see about the crossmember and a few other things!
    Update: got the front bumper pulled in 3" last night. Olds grille is just set in for the moment. 20201015_174554.jpeg
  24. JeffB2
    JeffB2
    from Phoenix,AZ
    Maybe that open space at the grille ends might be a good place for fog lights,I remember that Bay area and Delta fog when I ran routes back there. ;):D Lots of style to choose from that might be right diameter.https://www.google.com/search?q=rou...ECBgQBA&biw=1343&bih=648#imgrc=5M7vrqXwh_QoZM
  25. Ferdyeight
    Ferdyeight
    I'm actually going to widen this grille about 14" and V it a little to fit the front of the car. Im hoping to use the oval openings in the grille for turn signals.
  26. Ferdyeight
    Ferdyeight
    Not much new going on, waiting on parts and such. But I mocked up my falcon center console finally. 20201028_073522.jpeg
  27. Elcohaulic
    Elcohaulic
    Those Ford interiors were always so elegant..
  28. Ferdyeight
    Ferdyeight
    There's a lot of cool parts avalible to mix and match from the 60s fords. Im using galaxie arm rests up front, falcon arm rests in the rear, falcon console and thunderbird bucket seats. Im hoping it will all pull together and look elegant in the end..
  29. Elcohaulic
    Elcohaulic
    That will look so nice... Dont forget the reeevvvvbbbb lol..
  30. Ferdyeight
    Ferdyeight
    This poor 61 T bird gave its rear end for the cause tonight. Found the car not too far away on Craigslist and lucked out! T bird was trashed as far as I can see. But if anyone needs parts, its on the Sacramento CL under 61 thunderbird. 20210108_164209.jpeg 20210108_173354.jpeg
    brEad, chryslerfan55 and loudbang like this.
