Hot Rods Who has drilled their Chassis Engineering Axle?
Discussion in 'The Hokey Ass Message Board' started by Barbarian, Oct 29, 2020.
  1. Barbarian
    Barbarian
    from New Jersey
    Who here has drilled their ch***is engineering axle? I'm getting prepared but the CE stamped dead in the center is throwing off my pattern layout. I've read on here a bunch have drilled out these axles, can you show pictures how you went around the CE, through the CE, filled the CE, etc. Plan is to go with either 13, 7/8" holes spaced 3" apart on center OR 17, 7/8" holes spaced 2" apart on center.
  2. DDDenny
  3. silent rick
    silent rick
    none of my CE axles have had a stamp in it. is yours a new one since pete & jakes took them over? is it still forged?
    pprather likes this.
  4. continentaljohn
    continentaljohn
    Ch***ie Engineering’s axles are great looking and no need to drill it and none of mine have any marking on them . What I like about them is they look like a 1932 heavy axle but with a 2.250 wishbone mounting
    Montana1 and pprather like this.
  5. krylon32
    krylon32
    from Nebraska
    Over the years I had dozens of CE axles drilled with no problems. I never had a logo in the center of any of the axles. Do you have one of the CE style forged axles from P&J's. I've never seen one but they may have put their logo in the middle. I've also had some P&J cast axles drilled and I had them smooth the logo out of the center of the axle for an uninterrupted line of holes. I'd go with the 2 inch spacing.
  6. Barbarian
    Barbarian
    from New Jersey
    Here’s what mine looks like. I believe it’s forged? I didn’t know CE made an axle that was not forged?
  7. I have both stamped and non stamped both bought before Heidts bought the co.
  8. flamedabone
    flamedabone
    If the logo is only on one side, flip it towards the rear and drill it how you want. That logo is not very prominent, you could probably drill it how you want and no one would even notice if a hole was in the middle of the logo. Unless you are super ****, which some folks are.
    -Abone.
  9. lostone
    lostone
    from kansas
    Show a pic from the top in order to see the parting line that runs down the center top of the axle.
    If its cast I sure wouldn't be drilling holes in it personally...
    5window likes this.
  10. I have a CE axle ,forged & marked CE on one side. I mounted it with logo on the back, (the
    axle does not know front or back) & never had a problem with it. I did not drill it but painted
    one side of the web red just as decoration . It has been on my 34 Ford Pickup for 20 years. It
    is a great product & I hated to see CE close their doors.
    Montana1 likes this.
  11. Barbarian
    Barbarian
    from New Jersey
  12. Barbarian
    Barbarian
    from New Jersey
    When I balance it on one end and hit it with a hammer it has a ring to it. Not forever ringing, but not a thunk. I thought this was the tell tale sign it was forged? I ***ociated the lack of an 'ever lasting ring' to the fact that spindles are still attached and potentially buffering the sound a bit.
  13. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    That's forged. A forging will have a wide ground area from the parting line of the dies. A cast part will have a very narrow parting line from the mold so consequently the ground area will be narrow.
  14. Barbarian
    Barbarian
    from New Jersey
    Well to add more to this - I just got off the phone with Jason from P&J and got a history lesson.
    This is for sure a forged axle, made by CE up until the late 90s. Prior to the CE, the tooling for this axle was owned by Vintage Ch***is Works. Those axles have a VCW in the top right corner. There was a time period where CE was forging these axles but with a VCW in the top right corner. They later changed the tooling to have a CE logo in the center. CE later sold the tooling to P&J for this axle from them. P&J forged axles with the superbell logo in the center use the exact same tooling as the CE axle with the CE in the center, but they changed out the tooling to show the superbell logo. Other tell tale is the CE forged is 47" kingpin to kingpin and uses a 30" spring.
    Other fun fact, P&J forged axles are manufactured in the same facility in Ohio as the CE axles were once forged.
    warbird1, pprather and silent rick like this.
  15. And there is a good history lesson for all of us that may be concerned about cast versus forged. I was at an auction last Saturday and they had a pair of aftermarket round spindles in the auction. They were without steering arms, and the radius at the back of the spindles had a very narrow parting line. I p***ed on them as I felt that they were cast spindles, and I wouldn't want cast spindles on my roadster.
  16. krylon32
    krylon32
    from Nebraska
    I forgot, CE did stamp their logo on one side. Guess I'm getting old?
  17. DDDenny
    I would say if you have a Ch***is Engineering axle regardless of mfg date you should feel fortunate.
    I don't recall exactly what year I got mine (nearly 20 years ago) but it was after they had their tooling repaired and I know that I waited nearly a year after ordering.
    I'm sure they got tired of my phone calls.
  18. Marty Strode
    Marty Strode
    Wasn't the CE axle, from the old VCW, Vintage Ch***is Works tooling ? IMG_5098.JPG
  19. I drilled one with 13 1" holes right close to 1-1/2" apart. Did it in a milling machine. A little time consuming but satisfying.
  20. continentaljohn
    continentaljohn
    Both my CE axles have no markings but one is chrome. I have had both for over 25 years so maybe before they were marked . I also know that at one time they were forged in the norther IL area. The factory is slipping my memory . We seen a few of the axles over the years at the local swaps unmachined /no holes . They also had no markings and the best aftermarket axle on the maket that you can buy then
  21. Roothawg
    Roothawg
    I drilled the one in the Produce truck., no markings on mine.
  22. bchctybob
    bchctybob
    After reading all the axle info here on the H.A.M.B. I’m not drilling anymore axles. I was already getting a little burned out on the holes-in-everything look and the California streets and highways are getting worse and worse. I’m not messin’ with ‘em anymore.
    5window, pprather and Budget36 like this.
  23. X38
    X38
    Yes, same axle.
  24. Fordors
    Fordors
    @continentaljohn I had heard that John Deere did the forgings for CE but it seemed odd, at least to me, that JD would have an in house forge shop. Decades ago, maybe, but now not so much. I think it might have been a shop that did forgings for Deere.
    pprather and continentaljohn like this.
  25. continentaljohn
    continentaljohn
    @Fordors yes that is also what I heard . At one of the first Hunnert Car Pile-up a guy that worked at the place had a number of them to sell, none had any matching done to them.
  26. 5window
    5window
    I've got to vote with the "a bit tired of holes and louvers in every conceivable space" crowd. I like that axle the way that it is. Your car, but you could be different and buck the trend.
    continentaljohn likes this.
  27. I drilled mine back in 2007. The truck had 36,000 miles on it when I sold it last year. Worked flawless. Where I live the roads resemble an off road compe***ion. :)
