Technical 48-52 Ford F1 Gasser
Discussion in 'The Hokey Ass Message Board' started by Joshs Customs, Oct 28, 2020.
  1. Joshs Customs
    Joshs Customs
    Thanks, That will make a lot easier to set it up. Weather its an official "G***er" or not, I don't care and, I'm not worried. I rather be building in my garage then being a key board skeptic.
  2. Joshs Customs
    Joshs Customs
    Per Wikipedia...
    https://en.wikipedia.org/wiki/G***er_(car)
    A g***er is a type of hot rod originating on the dragstrips of the United States in the late 1950s and continued until the early 1970s.[1][2] In the days before Pro Stock, the A/Gas cars were the fastest stock-appearing racers around.[3]
    G***ers are based on closed body production models from the 1930s to mid-1960s, which have been stripped of extraneous weight and jacked up using a beam axle or tubular axle to provide better weight distribution on acceleration (beam axles are also lighter than an independent front suspension), though a raised stock front suspension is common as well. Common weight reduction techniques include fibergl*** body panels, stripped interiors, and Plexiglas windows (sometimes color tinted).
    And this continues on. I'm not going to post it all here. The link is above, you can read for yourself.
    Primered Forever and Jibs like this.
  3. earlymopar
    earlymopar
  4. hotroddon
    hotroddon
    ^^ And once again a modern build that has nothing to do with what gas cl*** cars were, and are. SMH
    badshifter and Nitroholic like this.
  5. 8flat
    8flat
    Last month I was looking into the option of better heads for mine, I have a set of 781 oval port heads that I was going to use. I read that you need to block off a small water jacket to use these gen4 heads on a gen5 block. FelPro makes a special gasket for doing just that. Then I talked to a machinist about it, he told me they have not had good luck with this option, sometimes they leak, and in a few places there isn't as much deck surface-to-head area to give a good seal for the head gasket. He said I'd be light years ahead by simply buying good aluminum heads that are made for our gen5 block. A little pricey, but worth it. Food for thought. I've read where some other guys have said it worked fine for them though.
  6. 8flat
    8flat
    So I'm honestly trying to understand your argument here. Pickups should not be built as a g***er? Or they can, but only if they're willys pickups since that is what was the most common truck in the time period? Or that we shouldn't use the term g***er as a name for a style?
    moparboy440 likes this.
  7. moparboy440
    moparboy440
    from Finland
    Pickups made great g***ers and not all were Willys!
    EVL401, slayer and 8flat like this.
  8. badshifter
    badshifter
    Now a B/FX truck is a g***er?
    Rules must be different in Finland.
  9. RmK57
    RmK57
    In this watered down world of g***ers it's close enough. It has a straight axle don't it?
  10. badshifter
    badshifter
    Everything you guys are building is great. For you. But they aren’t G***ers.
    You are on the HAMB, a website dedicated to preserving and embracing Hot Rod and Custom history from a very specific time period. Rewriting history by calling everything a G***er is not the end of the world, but it dilutes history and truth. Important to some of us.
    Post away and say what you want. But the truth is you are building “G***er Inspired” “Street Freak Inspired” “Things you think are cool inspired” “Drag Race Inspired”.
    It’s semantics and I think it’s important.
    I wasn’t rude, and I didn’t knock the OPs project. Nor did I say trucks can’t be g***ers.
    X38 likes this.
  11. nochop
    nochop
    from norcal
    Yankton? My avatar came from Hudson
  12. X38
    X38
    Yes.
  13. earlymopar
    earlymopar
    That was my fault given that I accidently dropped the picture in question into the wrong thread.
