Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. AHotRod
    AHotRod
    Great job Gary, hurry up and get this bad boy done, I'm really getting old Pal ;)
  2. nitrobrother
    nitrobrother
    What an awesome build, full of '60s nuances, and an extra-credit Spinal Tap reference!
    A couple of things: That scoop is cosmic, what about extending the rib from the top of the grill shell to the scoop to the cowl to the roof to the...you get the idea, for her pleasure! Secondly, when you make those fibergl*** mold thangs, if you have a larger area than what a t-shirt could cover (although that's unimaginable for my t-shirts) head to Bed Bath and Beyond for some t-shirt material sheets. LOTS of expansive material for your fibergl*** fantasies.
    Go man go!
    Stogy, shortypu, D-Russ and 10 others like this.
  3. catdad49
    catdad49
    Lookin’ mighty Fine, Gary! (Insert engine noises)
    mad mikey, Dino 64, Just Gary and 2 others like this.
  4. gonzo
    gonzo
    Very clean work. Great job.
  5. Just Gary
    Just Gary
    Thanks, fellas. :)
  6. TFoch
    TFoch
    Nice work! Looking great!
  7. mad mikey
    mad mikey
    You have great talent in making these one off parts. Very impressive Gary. I love this car!:);):cool:
  8. AHotRod
    AHotRod
    Tic-Toc-Tic-Toc-Tic-Toc ........... 14 years buddy, let's pick up the pace.... I'm on social security now
  9. neilswheels
    neilswheels
    from England
    Good things come to those who wait. My 40 has been 15 years now...
  10. Just Gary
    Just Gary
    Here ya go, @AHotRod . :)
    I tried this cool little 9"x4" dish Superior 500 wheel on the right, but the steering effort was too "arm-strong", so switched to the 12" Grant on the left. Both are mint and came from Craigslist.
    Stock top mount. A new column provides fresh horn wiring while it's straight, skinny 1.75" OD looks old.
    Bottom mount is a copy of @Dino 64 's.
    It's a 1.75 ID exhaust tube/clamp combo, welded to a plate that's screwed to the stock firewall's threaded holes.
    I'd cut out that part of the firewall earlier in the build, naively ***uming major mods. After mockup, I tacked it right back where Henry Ford intended.:rolleyes:
    Toe-in is roughly ~1/8" with this gauge that @burnedoutoldmechanic gave me while cleaning his garage. If anyone nearby wants to borrow it, PM me.
    This car *insists* on Stewart Warner gauges.
    New SW speedos' bad reviews annoyed me, so I got a rebuilt one off EBay. Pretty sure the date code ID's it as Studebaker Hawk from Jan '56?
    Puke tank made from s**** metal pieces.
    It plus the radiator, fan & shroud will be understated satin black later, per https://www.jalopyjournal.com/?p=6937
    Two "do-overs" (out of several :mad:) worth mentioning:
    1) I replaced the bi**et Thermostat housing with a chrome Mopar unit & can't believe you guys didn't razz me for that faux pas. Where's @Germ when ya need him???
    2) Despite repeated measuring, the driveshaft spun scarily close to the rear floor, so I extended the tunnel farther back for more clearance.
    Ironically, the tunnel's height also stiffened the rear floorboard.
  11. AHotRod
    AHotRod
    Alright Gary :)
    Fire-it-up and take me for a ride buddy !!!
    Stogy, mad mikey, Dino 64 and 3 others like this.
  12. nitrobrother
    nitrobrother
    Any holiday magic to share? Didja whittle an engine block out of spare aluminum, or weld fly wings together to make a crossmember, or sumpin'?
    brEad, Stogy, Dino 64 and 3 others like this.
  13. Just Gary
    Just Gary
    Nahh. I'm deciding where to attach some COTS (commercial-off-t******lf) P&J front shocks & mounts,
    then install these things: :)
    Joe Blow, 19Eddy30, catdad49 and 9 others like this.
  14. Dino 64
    Dino 64
    from Virginia
    Great job on that column mount, I really think that is just a perfect design :rolleyes:
    Seriously, you out did me on that one !;):)
  15. mad mikey
    mad mikey
    Very nice Gary. I like the steering wheel a lot. Cool headlights also.:):cool:
    loudbang, Just Gary and Dino 64 like this.
  16. Just Gary
    Just Gary
    For shock absorber length at ride height, I aimed for ~60% compression (bump) stroke & ~40% extension (rebound).
    https://www.cach***isworks.com/Attachments/Instructions/899-031-226_drag.pdf
    I measured my shocks' compressed & extended lengths & made a "dummy" shock from 1" square tube & washers. Its length equals the 60% of extended stroke length.
    It also aligned the two plates while t******* & tacking them, preventing weld sparks from damaging the spiffy new chrome.:)
    *Real* '60's race cars often used the smallest legal headlights mounted up high, like @-Brent- 's street/strip coupe; but I'm a ****er for low stockers, like @da34guy 's Deuces.:cool:
    After some eyeball engineering, the headlight bar got butchered:
    I didn't think my little Lincoln 140 penetrated enough, so drilled/tapped a #25/0.150"/10-24 hole through the center and threaded in a SS machine screw...
    ...then cut off its head, plug-welded the ends, & ground/filed everything smooth.
    Ninety-three-year-old fluted lenses, rings, conduit & housings with new CW Moss/Vintique guts.
    Not a fan of the amber turn bulbs but will withhold judgement for now.
    ~1/2" gap between shocks & headlights.
    I think the conduit will penetrate the grille shell sides (like stock) but am waiting for warmer weather to dis***emble it & drill new holes.
    Stripped down & low.:)
  17. mad mikey
    mad mikey
    I like the headlights low, looks more menacing . It looks like we have the same front shocks Gary.;)
    Just Gary, chevy57dude, Stogy and 2 others like this.
  18. Roothawg
    Roothawg
    Nice work Gary. The shock mock up is a great idea. I'll have to steal that.
    chevy57dude, loudbang and Just Gary like this.
  19. catdad49
    catdad49
    Adding to the "Look"!
  20. Kan Kustom
    Kan Kustom
    Love the headlight stands you fabricated and the lights are perfect.
  21. Dino 64
    Dino 64
    from Virginia
    Nice job Gary, you’re starting to dial in the nasty !
    Lookin good:D:D
  22. AHotRod
    AHotRod
    I love it Gary
  23. brianf31
    brianf31
  24. 47streetrodder
    47streetrodder
    Well thought out build. That last picture from the front is just wicked. I agree that the low mount headlights look perfect.
  25. Hitchhiker
    Hitchhiker
  26. loudbang
    Is it registered yet? Better make up a bar with higher light position and swap it in when you go get it registered. :rolleyes:
  27. neilswheels
    neilswheels
    from England
    That front view is perfect,really cool looking car.
    chevy57dude, Just Gary and loudbang like this.
  28. Just Gary
    Just Gary
    Appreciate the compliments, guys.:)
  29. gonzo
    gonzo
    Man that exhaust is so mean!
  30. Tim
    Tim
    from KCMO
