Hot Rods Any experience running a Crietz 2x4 sbc manifold ??
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Oct 30, 2020.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok, I am considering switching out the man a fre on my corvette and have several different options. An L79 intake, a C4B Edelbrock, A Weiand WCV 327 2x4 and a 2x4 Crietz, the Crietz seems to be the lowest profile of all of them and there are clearance issues on early vettes. I have a pair of 625 cfm Afbs and wonder how that would be on the street. The Crietz is pretty wide open inside with just a couple of small dividers. There isn’t anything wrong with the man a fre but I just want to try something different.
    3AD7E44F-6206-4C69-A993-1CA420C1E9E3.jpeg 03B87A20-669D-4A99-9570-D7AD6EAF378D.jpeg F7818461-B2B9-42D8-A38F-F7789754E9F1.jpeg 91ACB84B-B5BB-44F2-B623-2ADDCDD09BBC.jpeg 36B099F5-A180-4387-BC00-A1836585611E.jpeg
    Paul, Desoto291Hemi, timbow33 and 3 others like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    This is the car for those that don’t know, 11:1 350, solid cam, 4 speed with 3.55 gears
    8993C075-07F7-4FE8-9779-DDD28FC93354.jpeg 4A531201-8E72-4E45-B1F4-854C28783591.jpeg 25149254-D64F-4302-8B9C-A91DB2C6718F.jpeg 97A1C8C5-E72A-4E3F-A5D8-66CC0D1ED434.jpeg
  3. Never2low
    Never2low
    You had me wondering what an abc manifold was.:D
    Thought I was going to learn about something new.
    Deuces and kadillackid like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    fat fingered the keys... all fixed now
  5. Fordors
    Fordors
    20FC24EF-D86E-4F23-9CB2-317AFB8B9FAC.jpeg The Creitz always looked to me like it was designed to be a universal, fits ‘em all. I’ve seen 2x4, 3x2 and blower manifolds all from the same casting and I wondered about the performance of the carbureted manifolds with the huge plenum and no individual runners.
    My choice would hands down be the C4B, but I don’t know if it would fit. Maybe a ‘62 air cleaner would help.
  6. lothiandon1940
    lothiandon1940
    I'm no expert, but I feel with the Creitz you might suffer some loss of low-end torque.
  7. Open plenum manifolds work better at high rpm. I can tell you that the afb's are too large for driving on the street. If you disabled the secondaries, that might work well. You will loose a little torque at lower rpm with an open plenum, also.
    caprockfabshop and Deuces like this.
  8. catdad49
    catdad49
    Mark, had the same engine combo in my ‘64 Vette Coupe. 3.70 gears, close ratio Muncie with a Z-28 intake, but had to run a small diameter air cleaner. Low end suffered a bit, but at 3 grand........Fun!
    Deuces likes this.
  9. bobkatrods
    bobkatrods
    from aledo tx
    I have ran that exact manifold on my vette years ago,,,still have the manifold,,I used the 625 afb also,,my motor was 337 CI with 4 speed,, A lot of carb for the street as mentioned ,but you can make them work with some good tuning,,,I don't think you have enough motor to really notice a big diff in the low end torque..JMO
    AHotRod likes this.
  10. belair
    belair
    Not exactly OT, but I have a Creitz 3x2. It performed ok, but there are better 3x2 manifolds out there. I would imagine the same is true of the 2x4. If you're going mainly for looks, one will look pretty much like another to most folks. How it performs and what you want it to do are something else altogether. FWIW, I don't think you can beat the Man-A-Fre for looks.
  11. ididntdoit1960
    ididntdoit1960
    from Western MA
    catdad49, Deuces and lothiandon1940 like this.
  12. bchctybob
    bchctybob
    Can't hurt to try it. I'd dig up a couple of 3721 300 hp/327 Carters or at least a pair of 500 cfm Carter/Edelbrocks though.
  13. brigrat
    brigrat
    from Wa.St.
    So someone offered you a ridiculous amount of money for the Man-A Free?
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    no, just want try something different for a while
  15. jimmy six
    jimmy six
    If you found a couple of 400 cfm it would be more drivable on the street. A friend had an open dual quad on another GM engine and I ran and worked really well
    as direct linkage. It looks great and may perform similar to the Man-a-fre. I would keep it if your not pleased with it.
  16. brigrat
    brigrat
    from Wa.St.
    To me the dual 4's look more appropriate under any pre '63 Vette hood. I even like them better than the FI look. Buy another hood, cut a hole in it, shave the Creitz for a blower and than you don't have to worry about hood clearances!
    Anything is possible, I gave up looking for a Creitz tripower and made my own, here's a dual 4 Creitz I modified for try power. Probably to tall for a Vette but could be shaved down a bit.
    DSCF9818.JPG DSCF9819.JPG DSCF9820.JPG DSCF9821.JPG DSCF9822.JPG DSCF9824.JPG DSCF9825.JPG
    jimmy six, belair, catdad49 and 4 others like this.
  17. Nailhead Jason
    Nailhead Jason
    Wish I had kept mine. Sold it on here a few years ago. I think it may have been @brigrat above that bought it.
    Moriarity likes this.
  18. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^ That's the one Jason^^^^^^^^^^^^^^^^^^
    The hole thing looks a little to sanitary after I finished it, think I will ruff up the plate below carbs and the shiny carb spacers to make it look more traditional.
  19. Mike VV
    Mike VV
    from SoCal
    While I've ever run one, or even seen one in real life, cept for the photos above...
    A bit of a wall hanger.
    No air/fuel directional control...anywhere. Well, there is a little bit of a center divider, but even it's not full length.
    There IS...a reason no one makes or runs a manifold like that today..! Not really even a good blower manifold start with no directional control at the runner-cyl. head interface.
    Mike
    Moriarity and blowby like this.
  20. Have you considered a gM dual quad intake? It would fit the hood. I just happen know know where a “less than perfect” one is. Prime for polishing!
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    there is one thing that kinda makes me want to try it. The Horne 4x2 on the Caddy engine in my 40 is completely wide open inside and that car runs beautifully. Maybe it is a completely different thing? I just think I may try it and see, It is only gaskets and time if it doesn't work out....
  22. Fordors
    Fordors
    My post was strictly an opinion, I have no experience with a Creitz, so if you are willing to give it a try I say go for it!
    Deuces, Moriarity and lothiandon1940 like this.
  23. timbow33
    timbow33
    Do you still have the Man-A-Fre? Will buy it.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    the man a fre is still on the vette and will probably stay there....
    Deuces likes this.
  25. brigrat
    brigrat
    from Wa.St.
    For some reason Moriaity sold me a set of BBC V/C's, probably the only thing he ever got rid of in his life! To autograph them was extra!
    belair and Moriarity like this.
  26. @Moriarity did you ever try out the Creitz on anything?
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    sorry man, no I never did.... yet
  28. Ok thanks for the reply. I turned a friend onto one for sale locally for a car he’s building as it looks like a pretty complete and neat piece!
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    They are completely open inside and that probably makes bottom end power suffer some....
    lothiandon1940 and cactus1 like this.
  30. Tim
    Tim
    from KCMO
    A well tuned man a fre has such a great response that I feel like you’d immediately know weather swapping the the 2x4 was a good idea or not
    Dan Timberlake likes this.
