Projects 1950 ford
Discussion in 'The Hokey Ass Message Board' started by Tom A Anderson, Oct 29, 2020.
  1. Tom A Anderson
    Tom A Anderson
    Thanks for accepting me 1950 been in storage 30 yrs
    PoTaToTrUcK, slv63 and Budget36 like this.
  2. brady1929
    brady1929
    Good luck with your project and Welcome.
  3. harpo1313
    harpo1313
    from wareham,ma
    Looks like a good traveler in its day.
  4. warhorseracing
    warhorseracing
    from cameron wv
    Looks like a good candidate. Be sure to check on the wiring. My 51 almost caught fire under the dash with the old original wiring. The cloth and rubber was falling off in big chunks. Reber can get you a replacement better than new with fuses in either 6 or 12 Volt. Put your location in your profile so we know what region of the world you are from.
    lothiandon1940 likes this.
  5. J. A. Miller
    J. A. Miller
    from Central NY
    Welcome to the HAMB. What are your plans for the 50?
  6. Texas Webb
    Texas Webb
  7. Tom A Anderson
    Tom A Anderson
    I want to put a 50 Mercury engine I'm it.thanks for the tip on the wiring
    warhorseracing likes this.
  8. flatford39
    flatford39
    If you have a good block in it now then all you need is the Merc 4" crank. Blocks are getting hard to find that aren't cracked.
  9. Great car. I am a little bit biased though. :) I second the wiring comment. I bought a '50 last year this time that was all original and drove it on the trailer to bring it home. The wiring was a fire hazard. That was about the first thing I did.
  10. WB69
    WB69
    from Kansas
    Welcome aboard.
  11. brokedownbiker
    brokedownbiker
    I ended up ripping the whole harness out of my '51 and replacing it with a harness from Rebel Wiring. The original was brittle with lots of exposed wires; every time I reached up under the dash and brushed against wires the insulation fell like snow off the wires.
  12. 19Fordy
    19Fordy
    Merc block and 8BA block are the same. If your current block is good just get the Merc crank , rods and pistons.
    If your current engine is in good condition, you might want to just rebuild it to stock specs to have a nice reliable driver. You won't notice any difference by just installing a Merc crank. Get some good flathead engine books and do your research before you spend tons of dough.
  13. flathead4d
    flathead4d
    Also check out. The ford barn.com and shoebox ford.com
  14. Tom A Anderson
    Tom A Anderson
    Here is the motor to swap good running out of a 50 Merc
  15. D type
    D type
    Looks like a great project --- Have fun and stay safe !
  16. Greg Rogers
    Greg Rogers
    That thing looks so cool- love that top compartment!!!
  17. CME1
    CME1
    Is that the standard air cleaner and carb for a 1951 Merc engine in your post #14 ? The air cleaner looks really heavy on the carb. Any way your 1950 Ford look's like a COOL project !
  18. jchev1953
    jchev1953
    Good luck that car topper reminds me of the ones my dad rented from u haul for the annual trip to the jersey shore
    Sent from my SM-G950U using The H.A.M.B. mobile app
  19. dan c
    dan c
    you were lucky to find a solid one in minnesota! welcome and don't be afraid to ask questions. check facebook; there are some sites that will help!
