History Anyone have any info on this 40 coupe
Discussion in 'Traditional Hot Rods' started by biltx77, Jan 2, 2014.
  1. lothiandon1940
    lothiandon1940
    I'm not a fan of seeing '40 Coupes get all "body modified" like this, since their proportions were dead on perfect to begin with. That said, there have been a few over the yrs. that were pretty damn cool when done this way and since the car has already been done you kinda owe it to the car to return it to its "glory". I hate to say it but those tailights are sorta growing on me (gulp).
  2. amen!
  3. okiedokie
    okiedokie
    from Ok
    I agree!
  4. My $.02.
    I have said for a long time that the car tells you what it wants to be. You just need to listen.
    Now that you have pix, your car is telling you exactly what it should be. Stick with the theme, and put yourself in the shoes of the guy that built it. Follow his lead. NOBODY today has the balls to chop a 40. You got one, done apparently very well.
    Just finish the car the way it's going. Round off the bottoms of the fenders, NO running boards, wheels from the 80's, simple interior, maybe a 351 Cleaveland, 4 speed trans, and drive the wheels off.
    You will never see anything like it at cruise-ins or shows.
    Good luck, wish I had found it first!
  5. lothiandon1940
    lothiandon1940
    The car evokes some memories of Cushenberry's El Matador though not quite as radical. You might want to seek out some photos of it for inspiration or maybe someone with better computer skills than myself will post some. I guess even die-hard '40 Coupe purists would agree that the El Matador was the high water mark for "radically customized" '40 Ford Coupes.
    seb fontana likes this.
  6. speedyb
    speedyb
    from socal
    I like it, give it some horsepower, greens good!
  7. Sounds like a plan!
    I agree with whats suggested earlier, skirts, running boards and the obvious rims and tires + lowered...
    Doug Rice version
    dearjose, Carter and kidcampbell71 like this.
  8. Rem
    Rem
    I love the Rice '40 (above), and that's probably the way I would head, but your one's original green look has a lot going for it. Chrome reverse rims - absolutely.
  9. ram-rod
    ram-rod
    I was going to say, "Get the colour right, and this car will be a hit"... then I saw the green photos ... that's the way forward right there. ...
  10. Catdaddyo
    Catdaddyo
    Like the taillights but I am a big fan of running boards too. I like the car and as the gentleman above said " nobody's going to chop a 40 ford now adays"
    6sally6 likes this.
  11. 00 MACK
    00 MACK
    The car was awesome in green exactly as it was the day the pics were taken!
  12. PKap
    PKap
    from Alberta
    I like it too, never did understand why people didn't cut up 40s more as I really don't like them stock. The nice thing about your budget plans are that the car is going to be a blast to drive around, and not an art project that you can't touch. Hopefully it's not all filler and you can turn it around easily. Good luck
  13. Torkwrench
    Torkwrench
  14. biltx77
    biltx77
    from Nor Cal
    Thanks Ron, That is exactly what I was looking for. In finished form the car looks absolutely rippin. I have a few projects that are taking precedence but I think that the history of this piece of art are pushing towards reincarnation. Any Idea what was motivating it in the day. I'll have to see what kind of time I have to invest in the next few months. Rest ***ured that this piece of rolling art, and I use that phrase loosely ( a good friend of mine refers to most amazing mechanical things as " Just a buncha parts" ) will be a complete buncha rubber burnin, oil churnin, metal twistin, gas swillin runnin buncha parts. And every time I break it it'll come back a little bit better.
    EVL401 and kidcampbell71 like this.
  15. socal34
    socal34
    Looks like a green 40 that showed up at Kevins Hamburgers in Reseda Ca. in the 80s. Was told it was owned by one of the Shielb boys from Earl Shielb painting, only was told.
    Good luck on the car
  16. 1blown57
    1blown57
    from Florida
    Yeah Hollywood Knights ...I hear "CALIFONIA DREAMIMNG" paint it Tony Nancy yellow .watch the movie .......
  17. 1blown57
    1blown57
    from Florida
    Just kidding about the Yellow !
  18. fortynut
    fortynut
    I like it. The tail lights spoil the lines of the rear fenders but then again a mole on a woman's face was considered ***y (in the fourteenth or was it the fifteenth century?). I'm sure that took some getting used to and in a clench wasn't noticed, like you won't driving down the pike. I had a Forty very similar to this one in high school. It didn't have the chop but was channeled over the frame with no running boards, and sat low as a squashed toad on the road. Painted a luscious turquoise, with only accents of chrome, and no bumpers, it was more rod than custom and the builder or builders had done all they could to make it lean and mean. Needless to say, I have wished a million times I still had it with the same yearning I have for a favorite Teddy Bear I had at age five; something you grow attached to and suffer when life takes it away. It went from Flathead powered to an Oldsmobile and never burped, except when it spit out drive train parts, like transmissions, driveshafts and Woodruff keys in the hubs. You have taken possession of something that does not need changing so much as refining, and are, unbelievably, the caretaker of a very special car. Don't change it radically or it will no longer have 'a history', and if you don't like it as it is, sell it to someone who does and buy what you want. Whatever the case, don't listen to the novices who have no idea what it means to own a real treasure, as the photograph of it in its glory implies; no one in their right mind would whack around a Faberge egg so it was more like a real egg, the whole point being it was meant to look the way it does. What happens to historic cars as a result of someone with an 'idea borders on the criminal. Paint, upholstery, and whatever minor body work it needs and Bob's Your Uncle.
  19. volvobrynk
    volvobrynk
    from Denmark
    This is such a nice car! There are so few well done chopped forty coupés, so please save this one!
    An Respect the original build enough to only fix broken.
    The green color would be so awesome.
    Is it the same car as the green, or was there 2 almost ideentical forty coupés out there?
  20. James D
    James D
    That´s a really cool looking Kustom Rod from back in the days. The El Matador vibe is very strong. I´d amp up the sixties look of it with some chrome nerf bars, WW piecrust slicks on the back on chrome steel wheels and you´ll have a fantastic period looking car. The dark green colour is spot on. Love it!
    kidcampbell71 likes this.
  21. biltx77
    biltx77
    from Nor Cal
    It is the actual car, license plate and all. The body of the car has the same green still on it under that yellow. But the hood and front fenders don't. Maybe it was hit at some time and someone tried to put it back together like it was. The front fenders don't have that bad *** lip around them either.
    My plans are to throw some laquer on it, put the engine in, wire it up and drive it for a while.
  22. fab32
    fab32
    Now you're talking. Be sure to post pictures and report progress as you bring her back. If it were mine I couldn't rest until I had it exactly like it was built and in green. This coming from a guy that absolutely thinks green is the worst color possible for a car. OK for $100 bills..........just NOT a car. This one is telling us it wants go green once again.:cool:
    Frank
  23. biltx77
    biltx77
    from Nor Cal
    Been busy for quite a while with family and many other time consuming pursuits. So havent been around much.
    I have finished a few small projects on the 40 and am lining up some time to get it finished up.
    Brakes and steering are finished.
    Applied a coat of O.G. green with the help of my son, hes loving the project.
    Picked up a set of Ken's equipment racing rear wheels and halibrand front runners.
    Installed a new firewall and trans tunnel.
    Rebuilding the trans and hooking up an vintage sbc.
    Check out the workmanship on the garnish moldings, cut, weld, chrome. We dont need no grinding we're a welder.. haha
    Here's a couple of progress pics. 20190407_205552.jpg 20200516_195653.jpg 20200516_183357.jpg 20200522_212417.jpg 20181222_122450.jpg
    If I find the time I'll start a build thread.
    EVL401, 40FORDPU, GEBHARD and 6 others like this.
  24. biltx77
    biltx77
    from Nor Cal
    I know how much you guys love old racing wheels, so here are the rears. Ken's racing equipment mfg. 15x12 20200513_195247.jpg
  25. 6sally6
    6sally6
    ^^^^^^^ Me too!
    It needs running boards....stroked out Windsor engine.......snotty cam..Torque Thrust rims.....fat tarz!
    6sally6
  26. chevyfordman
    chevyfordman
    I really like the car but I don't like the mags. Do you think it would look neater with full hubcaps? But I have faith that you will make it look good in the end, no matter what wheel you use.
  27. biltx77
    biltx77
    from Nor Cal
    Go for an early 60's vibe is what the parts on hand are telling me. Those rears were made in the bay area for only a couple of years in the early 60's. They fit perfect in the wheel wells and put 13in of rubber on the ground. I've got an old chevy dz 302 motor with the factory road race cam sitting in the corner. The cross ram would look pretty good topping that off. It's got the potential to handle fairly well once I get things dialed in a bit.
    It's got much more of a rod feel to it. But stance and wheels are pretty easy to change once it's up and running.
    bowie and LOST ANGEL like this.
  28. GEBHARD
    GEBHARD
    from TX...
  29. spudz
    spudz
    Any updates?
    Shaun1162 likes this.
  30. Shaun1162
    Shaun1162
    Funky, but awesome! I hope ya got some more updates for us??
