Technical ***November 2020 Banger Meet Thread - Shop Time!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2020.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    Everything is cancelled
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. 62pan
    62pan
    Wow, first to check in
    Old Dawg likes this.
  3. noboD
    noboD
    Don't forget to change your clocks.
  4. Binger
    Binger
    from wyoming
    Checking in from Cheyoming. Not much going on around here. I dis***embled the steering box in my roadster and hope to get it rebuilt and put back in soon. I am also going to install a mitchell OD unit on a 30 sedan this month. I will post along progress as I get that job finished. I am also going to install some tube type shocks on this sedan. The car has a 4" drop axle and a different rear spring so I dont think that any of the bolt on shock kits will work. What has everyone been using for shocks and mounts on a full fendered sedan? I imagine I will end up building some sort of mounts for them. some ideas will help me get an idea of what I will need to do.
  5. guitarguy
    guitarguy
    Well, I haven't made any progress, but my machinist has.
    The Model T block has been aligned bored with the new steel main caps for the larger Model A crank and new anchor points made for the babbitt pouring.
  6. Czech’d in
    J
    Retson the Racer likes this.
  7. poshdbs
    poshdbs
    Nothing but frustration going on in my department!
  8. All dressed up & nowhere to go!
    Elizabeth! DO NOT pick your nose!
    Checking in!!! Current situation...
  10. This threads got me.
    poshdbs likes this.
  11. denis4x4
    denis4x4
    from Colorado
    Driving my hot rod A's more then ever this year. Keep masks on the shift levers of both cars.
  12. V4F
    V4F
    from middle ca.
    still fixin the A
  13. burl
    burl
    from Minnesota
    Checking in for the month been picking away at this beater
  14. Star 351
    Star 351
    I've had my a about nearly half a dozen times today it was °24c spring time in aus( °75f) and I'm have problems getting my hopped up banger get up to temp the hottest i saw today after a good run was °60c (°140f)[​IMG][​IMG]
    Shutter Speed, Jet96, waxhead and 2 others like this.
  15. Time for you to invest in a "Pines Winter Front Grill" ;)
    tomkelly88 and KiWinUS like this.
  16. Star 351
    Star 351
    I'm starting to think I may have to, or make an adjustable restrictor for one of the radiator hoses we do sometimes see temps up to °42c (°108f) here during summer
  17. railcarmover
    railcarmover
    Waiting shop line..been too busy running junk around to work on it..
    Shutter Speed and Old Dawg like this.
  18. poshdbs
    poshdbs
    Loving the look of your project and love your patina colored Lab. too! ;)
  19. noboD
    noboD
    Burl, I realize you are early in the project. Are you planning to run a hood? From what I remember from the top iron discussion is your body is a '22. The radiator shell you have is for at least a '24 or newer because of the nickel finish. Problem is they made the radiator taller about '24 so a standard hood may not fit. Without a hood I would keep the tall radiator for more cooling.
  20. Johnny Nitro
    Johnny Nitro
    from Chicago
    All beauts! Nice to see everyone’s projects. Keeps hope alive. Checked!
  21. Dustyp489
    Dustyp489
  22. burl
    burl
    from Minnesota
    no hood on this one will cut the shell down to match the height of the cowl and run a cut down 32 radiator like i have in my 28 keeps the banger plenty cool
  23. burl
    burl
    from Minnesota
    yep he loves going for a ride will need to keep it crusty to match the color of my dog :)
    Shutter Speed, guitarguy and poshdbs like this.
  24. Here we go again. Had some white metal exodus from my favourite Diamond B after twelve years of enthusiastic driving. I don't have the spare coins to get it converted to shell bearings so I dragged out a spare engine to fit in the interim. I'd run it previously for a year or so and knew it didn't knock or overheat but needed boring and the valve train sorting.
    However - stripped it down and found this crack around one of the cam follower bosses.
    So took it off and had the crack laser welded.
    Seems to have fixed it so had it decked and bored 60 thou. Tightened up all the caps to 2 thou bearing clearance and popped in a Stipe cam and a new set of valves and springs. Not quite the chuck in the spare engine plan I originally had. Fingers crossed.
    tomkelly88, Jet96, GuyW and 3 others like this.
  25. burl
    burl
    from Minnesota
    Laser welding works really well.No real haz and minimal distorsion we use it for tooling repair all the time
  26. V4F
    V4F
    from middle ca.
    i ran those when driving truck . pine winter fronts are cool ..........
    Star 351 likes this.
  27. burl
    burl
    from Minnesota
    Working on another banger to volvo 4sp set up.Havent decided to mate to the torque tube or go open drive like i did on my 28 these transmissions work pretty good behind a banger
    Binger, Jet96, rwrj and 3 others like this.
  28. Too bad that trans isnt legal at RPM Nationals, Id like to have something with synchros..
  29. burl
    burl
    from Minnesota
    If you aint cheatin you aint winnin
  30. That's why I'm bored .90 over with a big cam!
    Dustyp489 likes this.
