Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. Chief 64
    Chief 64
    I really like the first gear on my 53. It is really short and it gets into second before I am even across the intersection. But after that it just slowly gets up to speed.
    Also I like you take your dog in your car, cool dog!
    chryslerfan55, loudbang and PhilA like this.
  2. PhilA
    PhilA
    It is very short, especially so with the low ratio rear end. I must've set things up halfway right, this morning I stamped my foot down from a standstill and left an 11 down the street. That was surprising, didn't think it had it in it!
  3. PhilA
    PhilA
    Adjusted the wiring and now I can run a 2-pin blinker relay.
    Borrowed the one from my other OT car and now I have working turn signals again.
    MUNDSTER, loudbang and brEad like this.
  4. PhilA
    PhilA
    It's an everyday car, parked up at work.
    Phil
  5. PhilA
    PhilA
    110mph wind took the roof off a good part of the garage. What a mess.
    Phil
  6. Johnboy34
    Johnboy34
    from Seattle,Wa
    loudbang, PhilA and TrailerTrashToo like this.
  7. Chief 64
    Chief 64
    Well that ****s... is everyone okay? And if so, then my next question is, is the Pontiac okay?
  8. PhilA
    PhilA
    Yeah everybody is safe, the house didn't take any damage and the car remains intact. I'm glad I decided to put all the boards up on the door, because without, they'd have blown in onto the car.
  9. Glad to hear that everyone is ok. The damage to the garage is unfortunate, for sure, but you and your family are very lucky all the same.
    Mike
    chryslerfan55, PhilA and loudbang like this.
  10. Ford52PU
    Ford52PU
    from PA
    so sorry to see the damage. Glad that you and your family are safe and the car is also.
  11. PhilA
    PhilA
    Wrangled that up onto the roof and nailed it down. Not perfect but it'll do for now
    Secured the other piece that was loose.
    Need to get some 2x2's and some more tin. Half of the roof is in the next street, according to my neighbor.
    Phil
  12. patsurf
    patsurf
    well,the good thing is that who's ever yard it IS in--will help you move it!!
  13. PhilA
    PhilA
    I am led to believe it's in the drainage ditch of the school parking lot.
    So, I need to go tidy that up tomorrow
  14. PhilA
    PhilA
    This is progress.
    Fixed the garage doors, got everything secured. Little more cleanup tomorrow
    chryslerfan55, brEad, i.rant and 3 others like this.
  15. PhilA
    PhilA
    Got back to the least broken pieces, picked up and am recycling the least junk bits of wood back into the lean-to for the lawnmower (where I'm stood taking that photo), will get new to redo the workshop roof.
    Took the car out and gave it a wash. That cheered me up a little.
    Phil
  16. brEad
    brEad
    Glad you, your family, and the car came through okay!
    PhilA, TrailerTrashToo and loudbang like this.
  17. PhilA
    PhilA
    Had a jaunt into town to clear my mind and also pick up some roofing nails.
    Phil
  18. 50 Merc Man
    50 Merc Man
  19. PhilA
    PhilA
    Thank you. It's a good 50/50 car. Looks great at 50 feet, or at 50 mph!
    I need to reset the valve lash now it's done nearly 700 miles, and a few other odds and ends. It's been fun to drive about in though, lots of smiles and waves.
    Phil
  20. PhilA
    PhilA
    Finished building the roof frame. Got the first sheet of metal on, too. Ran out of light and too many mosquitoes tonight to carry on. I ache all over!
    Phil
  21. PhilA
    PhilA
    I would like a nail gun right about now. This is hard work.
    Phil
  22. greybeard360
    greybeard360
    Self drilling screws and a drill..... Much easier.
    Woogeroo, loudbang and PhilA like this.
  23. PhilA
    PhilA
    Yes and no; this is a planned thing. The frame is all screwed together now, the tin held down with nails (each with a neoprene seal). The nails are the weak link, if another storm gets so bad that it decides to take the roof, I'm hoping it only takes the tin and not the frame too. The previous builder used nails for everything so the roof tore up the frame with it.
    Repairing the frame plus putting new tin takes time. New tin is quick to fix in comparison.
  24. PhilA
    PhilA
    Alrighty, that's that pretty much done. Hopefully regular programming will resume soon.
    Phil
  25. PhilA
    PhilA
    Went grab a chocolate malt.
    Phil
  26. PhilA
    PhilA
    Had a bit of time and inclination last night so I set my headlight aim a little better than it was against the remains of my garden fence.
    High beam is a bit more useful now.
    I stopped at the store and bought a new oil pressure warning light switch, the old one failed closed so the light wouldn't go off.
    Spilled some oil doing that- that's 400 miles, I think it's due a change. Diesel oil is great for the zinc and such in it but really scours the soot off the inside of the engine.
    I have a pair of the correct model (but in 12V) horns now. They need a bit of TLC, so I bought a can of black enamel for them. I'll also have to build another bracket for them too.
    Phil
  27. vtwhead
    vtwhead
    Phil what brand of oil is that and what weight? That is some nasty looking oil after 400 miles:rolleyes:
  28. PhilA
    PhilA
    Traveler brand 30W. I don't think this engine saw routine oil changes in the past. The detergents in the oil are scouring it clean. The next few changes are going to be the same but it should clean up eventually.
    Is not causing any excess oil consumption, the valve guides have all been cleaned and the rings and pistons are recent. It's just pulling a lot of dirt out.
    I'm doing many changes in short time, cheap oil works for that without being a dent in the pocket book.
    Phil
    Woogeroo, X38, chryslerfan55 and 4 others like this.
  29. PhilA
    PhilA
    Little metalwork tonight. The lid off one of the new horns, rubbed back. A few dents present.
    Bash bash bash
    Better. Wiped down.
    First coat of black. Got full of dust typically so that'll get a rub down and repeat once the paint is hard.
    Cleaned the horn itself up. The face of the trumpets and the round lid are the most visible parts so they recieved a little extra care.
    Bottom cleaned up and painted, drying.
    Enough for tonight,I think.
    Phil
  30. PhilA
    PhilA
    There's one done. Other one needs doing now!
    Phil
