Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    Thanks Mart! Hope you're doin' well!!
  2. sloppy jalopies
    sloppy jalopies
    from the pix it looks like you used a '28-'29 subfloor... tudor as the heavy rear crossrail has a L-R bow to it... the '30-'31 coupe has an almost flat one... don't bow your lower panel to match it... get the correct crossrail… sorry they are $300 new...
  3. Piewagn
    Piewagn
    Whole section on last page about the subframe and the mods I did. Rear coupe subrail on it's way!:D:D
  4. Mart
    Mart
    Tell me a bit more about the shrink disc...
    jeffkau and loudbang like this.
  5. Piewagn
    Piewagn
    It uses heat from friction......
    Here's a video, quality is a little poor, but you'll get the basics.
  6. Piewagn
    Piewagn
    Brought this crown back too with the help of the shrink disk.....caved in with a crease down half the length....just a little tweaking with the slap file and it’ll be ready for a thin swipe of filler.....have a great weekend fellas!!! IMG_0354.JPG
  7. koolbeans
    koolbeans
    Nice....very clean....not many miles on that puppy....
  8. Piewagn
    Piewagn
    Yay!!!! Aaron.....you are the man! It finally came and I could not be happier with it!! Thanks man....you came through!
    I’m splicing in the wood over the door....money saved will go towards other things needed for the project. Old skids all over the place, so I made up a piece using the old one as a template....it’s offset and I’m going to dowel it.....thanks for stoppin’ by fellas!!! IMG_0366.JPG IMG_0365.JPG
  9. Piewagn
    Piewagn
    Hey man! There you are! Just took a little prodding.....:D:D That Ardun sounds ******** awesome! Car looks awesome too! Good to see ya here!
    ps.....make sure you keep an eye on that steering column oil level.....:D:D
    kidcampbell71, koolbeans and loudbang like this.
  10. Aaron D.
    Aaron D.
    Glad it finally came in and you're happy with it.:):)
    Piewagn and loudbang like this.
  11. Piewagn
    Piewagn
    Tomorrow I do a mock up of the body to see where I need to go to finish up the subframe.....
    brEad and loudbang like this.
  12. koolbeans
    koolbeans
    Thanks. Lots of stuff got in the way. That's a real funny. Good friend diligently helping noticed oil running down the column. Of course he acknowledged on start up that the oil pressure was good, but the steering column was leaking oil. Had a hard time convincing him that the column had no oil and it was coming from the gage line directly above. We had a great laugh.
    Your ride is dynomite!!! Love watching it coming together. Love the yellow too.
    A great hobby.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  13. Piewagn
    Piewagn
    Worked on the subframe tonight.....got the measurements I need for cutting and stretching.... IMG_0374.JPG IMG_0375.JPG IMG_0373.JPG IMG_0378.JPG IMG_0382.JPG
  14. Piewagn
    Piewagn
  15. Piewagn
    Piewagn
    Need some tweaking...but you get the idea......happy Friday Eve!!!
    simplestone, brEad and loudbang like this.
  16. Piewagn
    Piewagn
    Need to do the rear extensions and then finish up all the welding....
    Got it right on.... IMG_0389.JPG IMG_0393.JPG IMG_0394.JPG IMG_0395.JPG IMG_0396.JPG
  17. Piewagn
    Piewagn
    Rear subframe extensions....will be installing them today.....I’ll be able to start ***embly of the body and install all my patch panels! IMG_0402.JPG
    loudbang, Aaron D. and Black Fifty like this.
  18. Piewagn
    Piewagn
    I now have a subframe with needed dimensions for a coupe! Need to finish up the welding and grinding.....then it’s time for body ***embly!! IMG_0404.JPG IMG_0405.JPG
  19. Piewagn
    Piewagn
    I’m ready to ***emble....screw it....any tweaks can be made during ***embly.....I need to move forward for my sanity if nothing else!!! IMG_0412.JPG
    Vic Walter, brEad and loudbang like this.
  20. brEad
    brEad
    Looks good from here (for all that that is worth - LOL)!
    loudbang and Piewagn like this.
  21. Piewagn
    Piewagn
    Thank you kind Sir! I may have to tweak a little where the wheel wells mount......I'll be good though!
  22. Piewagn
    Piewagn
    Got some sheet metal work done tonight.....and got my ****py rusted gas tank cut off.....moving forward! Thanks fellas! IMG_0423.JPG IMG_0424.JPG IMG_0425.JPG
  23. Piewagn
    Piewagn
    More sheet metal work! The floor drops off, that’s why the gap towards the rear.....I’m starting ***embly of the body tomorrow......any other work can be done after it’s together! There’s light at the end of the tunnel! Thanks for hangin’ with me fellas!! IMG_0427.JPG
  24. Piewagn
    Piewagn
    Got some tweaking to do.....but it’s not coming apart again! IMG_0430.JPG IMG_0432.JPG
  25. Aaron D.
    Aaron D.
    That looks nice.
  26. Piewagn
    Piewagn
    Thanks Aaron! I still have the quarter ends to install as well. I was a little long on the subframe, so I had to cut it down 3/4". I still need to square up the right rear corner. Onward and upward!
    brEad, loudbang and Aaron D. like this.
  27. loudbang
    Looks like a car again :rolleyes:
    Piewagn likes this.
  28. Mart
    Mart
    Looking great!
  29. Piewagn
    Piewagn
    Yep!......and I'm just a little jazzed!! Thanks LB!
  30. Piewagn
    Piewagn
    Hey Mart!! Thanks for poppin' in! How's things on your side? Keepin' busy?
