Technical Carter AFB 9605s Carb & PCV connection
Discussion in 'The Hokey Ass Message Board' started by ken bogren, Jul 23, 2018.
  1. ken bogren
    ken bogren
    I've spent several hours looking for this info and haven't found it.
    The current PCV system on the Ford 460 in my 61 f100 is strange to say the least. Whoever built the system just ran a hose from each valve cover to a small tube weled onto the exhaust pipe. That may be goofy, but it hasn't seemed to make a difference in riving the truck.
    But time to see what it takes to do it right. Theres a plug/bolt in the back of the caRB AND I'm wondering if that is where the PCV line should connect? Here's a photo.
    There's a spcer under the carb that has a hole in it, directly under the plug/bolt. Could that be a connection point? If so, it doesn't seem to be threaded, and it's blocked, so how to make a connection.
    In this photo towards the left there is a sort of tab with a number stamped in it ... 8529, not sure what that indicates.
    I have an inexpensive air cleaner on the truck that has what is apparently a connection point for the PCV line, just dumps inside the filter, no baffles etc.
  2. ken bogren
    ken bogren
    Here's a photo of the front of the carb. There is a number stamped in the lower left 2509 9605s P1110189a.jpg
  3. ken bogren
    ken bogren
    Just to show the current arrangement
  4. jimmy six
    jimmy six
    Stick that hose u show coming out of the rear of the valve cove to the fitting directly under the words Carter AFB. There is something stuck in now. The other valve cover hose will go to the air cleaner between the filter and carb intake.
  5. ken bogren
    ken bogren
    Thanks. That's simple enough!
  6. jimmy six
    jimmy six
    If it were mine (I personally like the Carters) I'd take it off, stand it on a 4x4 and waste a can or 2 of Brake Clean on it. I bet it will clean up nice; use a small paint brush between cans... good luck
  7. squirrel
    I generally use carb cleaner on carbs, and brake cleaner on brakes...but, whatever :)
    2OLD2FAST, dirty old man and hendelec like this.
  8. ken bogren
    ken bogren
    OK, I worked out the PCV stuff, the connection on the p***enger side went well. On the drivers side I bought a breather cap with a built in PCV valve and connected to the bottom of the air cleaner. so far, so good.
    But this can't be good.
    This is the old connection on the drivers side valve cover.
    Yes that's the brake master cylinder in direct contact with the vent tube fitting.
    You can't even get the fitting out without unbolting the valve cover and sliding it up out from under the MC.
  9. ken bogren
    ken bogren
    Here's a closer look
    Not enough room to slip a piece of paper in between.
    This brings me to wonder why these tall valve covers were used. It looks like (from what I see online) that stock valve covers would be as much of an issue.
    So anyone know what function, beyond looks, that these tall valve covers serve.
    If they aren't needed I'll just replace them with the stock style.
  10. squirrel
    you should only have one PCV valve, on one side of the engine, and a breather on the other side of the engine.
  11. ken bogren
    ken bogren
    Yeah, I know that, I'm trying to clean up the mess that the PO installed. Are you saying the fitting in the last image is a PCV ? On the p***enger side it's just line to the tube on the carb like jummy six suggested
  12. squirrel
    take it out and look at it....sure looks like a PCV valve from the outside.
  13. ken bogren
    ken bogren
    Which leads me back to the question about the valve covers.
    Is there a functional need for "tall" covers as opposed to the stock style? If not and since I have to remove the drivers side cover to get that pcv fitting out I'm thinking about swithing to the stock style/height.
  14. saltflats
    saltflats
    from Missouri
    Just swap sides with the valve covers, then your pcv and breather will be in the front.
    Tall valve covers are needed sometime, if you change to roller rocker arms.
  15. ken bogren
    ken bogren
    Thanks saltflats. swapping sides would give me a little clearance under the master cylinder.
  16. DannyBrent28Sedan
    DannyBrent28Sedan
    Edelbrock Performer carbs and Carter AFB's are basically the same. The front middle port is for PCV suction. The front p***enger side port is for distributor vacuum advance and the front driver side port is for automatic transmission. If you have power brakes, the booster line goes to the threaded port at the rear. Look online for this manual: carter_afb_rebuild_manual.pdf. Also there are some great diagnostic videos from Edelbrock on youtube.
    Fresh air on my Carter AFB Compe***ion 9504s comes from a port on the choke side at the top rim of the carb, a line runs from that to the p***enger side valve cover to provide fresh air to the crankcase.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    While there are "usual" sources for vacuum , as long as the vacuum supply is adequate , it really doesn't matter where you source it ,if it comes from before the port runners . The OP could use either of the possible taps in the rear of the carb or spacer ..
