Projects 1940 ford coupe build
Discussion in 'Traditional Hot Rods' started by newredporch, Jan 9, 2019.
  1. newredporch
    newredporch
    from pittsburgh
    Worked on the rear floors and made some extensions for the vertical braces. Trying to get things tightened up for the rotisserie.
  2. joel
    joel
    R you going to put a small rear seat or jump seats in there?
  3. newredporch
    newredporch
    from pittsburgh
    I don’t have the jump seats. I will probably go without for now
  4. newredporch
    newredporch
    from pittsburgh
    I want to mock the car up before I put it on the rotisserie. This is the first time that I have ever seen the coupe with this many parts on it. This is where things start to get exciting.
    roddering, AHotRod, TigerFan and 12 others like this.
  5. X38
    X38
    You're not kidding man, that is exciting.
    newredporch likes this.
  6. okiedokie
    okiedokie
    from Ok
    Exciting I guess, great work.
  7. two couped up
    two couped up
    from pa.
    Looks great, lots of work but well worth the effort. Its time for me to get back to work on my project.
  8. newredporch
    newredporch
    from pittsburgh
    4606724D-8401-49AB-88BC-43A8A87AD40D.jpeg 07A511D9-1A0C-4293-A237-C71FDFF5B66F.jpeg
    Pulled the body off the frame. I think I’m ready for the rotisserie
    Kage, AHotRod, brEad and 7 others like this.
  9. newredporch
    newredporch
    from pittsburgh
    I accomplished this between paying jobs today D70E6CBC-E5A1-4780-8271-153C0547CB51.jpeg 86311EFC-EDEA-4A2E-864C-EFE9B44620F9.jpeg
    Chucky, Kage, AHotRod and 9 others like this.
  10. birdman1
    birdman1
    I'm working on my 1937 coupe also. Condition is like your
  11. poco
    poco
    from oklahoma
    You want 39 doors on your 40 and i want 40 doors on my 39.
  12. fordcoupeguy
    fordcoupeguy
    39 -40 Coupes have always been my fav. One of the best looking cars ever made.
  13. LOU WELLS
    LOU WELLS
    from IDAHO
    Thanks For Saving That Coupe... 0433c6_36c7ca59f11946c0993d856daadca5b2_jpg_srz_368_251_75_22_0_50_1_20_0.jpg Appreciated...
  14. neilswheels
    neilswheels
    from England
    Great progress. Is the body held to the rotiserrie by the 4 bolts, two in the front floor/cowl and two in the tool tray? Did you use big washers/spreaders on the inside to spread the load when the body is rolled sideways? Only asking as I'm looking at doing similar with my sedan
  15. newredporch
    newredporch
    from pittsburgh
    yes it’s held on with those 4 bolts. I searched the Internet for a picture and could not really get a good look. The front is straight forward. The rear I used a 1x3 tubing between the tool tray bolts. I bolted it (the 3” way) down through the tool tray, through the 3” tubing and then into the rotisserie arm. The 3” tube spaces the mounting area down so that it barely touches the outer body. I was just like you, it didn’t seem like it would be enough. It’s working just fine. The doors even open and close ok.
    beater40 and tub1 like this.
  16. newredporch
    newredporch
    from pittsburgh
  17. newredporch
    newredporch
    from pittsburgh
    I just picked up a set of original jump seats for the car. They were not in the budget but when do you ever see a set?
    32SEDAN and brEad like this.
  18. newredporch
    newredporch
    from pittsburgh
    I think I’m finally finished with the underside. Spent the day blasting and finished welding everything up. Tomorrow I’m going to epoxy prime it. Man, that was a lot of work. BBAD7C33-CF8A-48A0-B9AE-E7F5EA232DC5.jpeg F6E222A6-0A15-4199-99FA-3C58EFDB0A67.jpeg B0C664CD-8914-4092-978A-E37CC49A2EE3.jpeg 9C4ED53F-4F48-43BE-8311-2DA86EAD2C90.jpeg A9EC3A6D-619E-4955-BD77-4A78F3B41F3B.jpeg
    Chucky, Kage, Kan Kustom and 10 others like this.
  19. joel
    joel
    I did my coupe body like that and every now and then I still find a tiny pile of sand, mostly in the trunk area. I still think you're doing it right .
  20. newredporch
    newredporch
    from pittsburgh
    6F35EFC2-69C6-40D9-AF61-DDE77DB2031A.jpeg 084022B4-4F67-48F7-B8F9-C5C578862BB5.jpeg I’m going to turn my attention to the drive and ch***is. I picked up a 153 tooth bell housing from a friend and I have a 10” 14 spline clutch disc coming from Speedway in a couple days. I put everything in the bell to see how it shakes down. Looks like it will need a little cut off of the input shaft. Most people say about 1/4 inch. Thinking about going with a cable clutch linkage. Have any of you guys tried it with my type of arrangement?
    Kage, AHotRod, 32SEDAN and 3 others like this.
  21. The 39 guy
    The 39 guy
    My memory is very foggy (40 some years ago)on this issue but I remember pinning the clutch peddle to the shaft that both the clutch and brake peddle are on . Then I either made a bushing or just reamed out the peddle mount enough to allow the peddle shaft to rotate. Then I put a fitting on the inside end of the shaft to install a rod to actuate the clutch. It was very simple and worked without a hitch for the few years I drove my first Forty with SB Chevy and Chevy 3 speed.
  22. newredporch
    newredporch
    from pittsburgh
    I understand what you are saying. Isn’t this how a 1939 pedal ***embly works?
  23. The 39 guy
    The 39 guy
    I am not certain, on that. I traded off my 39 pedal ***embly years ago . I wish I hadn't done that. I know that the shaft on the 40 pedal ***embly has to be pushed out of the bracket with a hydraulic press.
  24. neilswheels
    neilswheels
    from England
    I racked my brain for a simple rod or cable install on mine, but couldnt figure it out, so went with hydraulic master and a push slave. Still not 100 percent sure its going to work, but I based it on the stuff Novak sells, and they've been doing it for a while. Be interesting to see what you come up with, simple mechanical stuff is much easier to fix if it fails on you.
    The 39 guy likes this.
  25. krylon32
    krylon32
    from Nebraska
    I've done a couple customer ch***is with the bell housing and trans combo you have. I ran the clutch with a Willwood puller slave and the 40 pedal ***embly from P&J. The pedals need a little tweaking but when done everything worked good. I agree mechanical is better but sometimes difficult to get to work?
  26. The 39 guy
    The 39 guy
    That mechanical system I used must have been simple.....otherwise I certainly couldn't figured it out back in the late 70's.... I am challenged by simple bell crank ( geometry problems). Somebody with a good memory should be able to step up here and recall what they did back in the day. I hope.
  27. newredporch
    newredporch
    from pittsburgh
    A machinists friend stopped in today. He is going to push the pin out and machine the housing and put a bushing in. He will replace the shaft with a longer one and it should all look and operate like the 1939 ***embly. Sounds simple enough. Thanks for your advice! I almost went the cable route. Glad you chimed in. I will send pictures when I get it back.
    Atwater Mike and brEad like this.
  28. The 39 guy
    The 39 guy
  29. TigerFan
    TigerFan
    from Athens, GA
    When you get your pedal arrangement figured out, please show pictures.
    This is a great build. Thanks for sharing it.
  30. newredporch
    newredporch
    from pittsburgh
    Finally got the chance to get back to the build. I decided to address the rear of the frame. I had rust issues between sandwiched areas in the back and figured it would be a good idea to strip down the rear area and sand blast. I’m going to box the rails after they are all cleaned up. C232342B-1BBD-42B7-B04A-430B23A5076F.jpeg
