Technical Removing aluminum head from cast Iron block
Discussion in 'The Hokey Ass Message Board' started by kabinenroller, Nov 4, 2020.
  1. kabinenroller
    kabinenroller
    I am working on a 1937 Fiat Topolino A, I have all the nuts holding the head on the block removed, I had to soak them for a long time until they broke loose. Now I have to remove the head, I briefly tried to use a sharp putty knife between the head and block but I do not want to harm anything.
    Does anyone have any suggestions for safe removal of the aluminum head? There are 10 - 5/16”-24 studs and two 3/8” studs protruding through the aluminum head. (I know there is standard thread on an engine that should be metric, I am not sure why)
    This car is extremely unmolested, no modifications like most Topolino’s have.
    Thanks!
  2. vtx1800
    vtx1800
    If the engine will turn over possibly putting the plugs in and hitting the starter which would apply pressure in different areas as the engine turns over. Just a thought:)
  3. Deuces
    Deuces
    Squirt some wd-40 in the stud holes and let it sit for a couple of hours...
    mad mikey, seb fontana and loudbang like this.
  4. kabinenroller
    kabinenroller
    Good thought. I will have to not wire the starter because I don’t trust the wiring in the car. I will be installing a new harness in the future.
  5. kabinenroller
    kabinenroller
    I have been soaking the studs with “Blaster” and some vintage Walker Manufacturing solvent. ( made when the good stuff was not outlawed) I shoot the studs every time I walk past the car.
  6. X-cpe
    X-cpe
    Or maybe days. Light tapping with a plastic hammer after each application of joy juice may help. Patience squared is your best friend.
    mad mikey and loudbang like this.
  7. inthweedz
    inthweedz
    Is there any where to connect a chain to the head, and use an engine hoist / endless chain to apply lifting pressure??
    VANDENPLAS and loudbang like this.
  8. If you can turn the engine over to top dead center on each cylinder, you fill the cylinders with air one at a time and see if it comes loose. If you don't have a leak down meter, remover the core of a spark plug and weld a air fitting to it. Thread it in the hole and fill with air. Unless it's really rusted to the studs, that should start the removal process.
    loudbang and vtx1800 like this.
  9. indyjps
    indyjps
    Put a few of the head bolts back in before spinning it over. :D
    Bryan G, Tman, VANDENPLAS and 5 others like this.
  10. nunattax
    nunattax
    gentle heat ,heat heat heat
  11. pirate
    pirate
    from Alabama
    A sharp rap with a good sized rawhide mallet or good sized dead blow hammer will often loosen things up. I would be very careful about using any sharp objects trying to wedge it loose
  12. wulf powis
    wulf powis
    dead blow hammer , squirt some oil in the cylinders, plugs back in and spin the engine via starter, should work. Pirates right on.
  13. 427 sleeper
    427 sleeper
    This may sound a little unorthodox but, could you fill a couple of cylinders with oil, with the spark plugs in and the valves closed, GENTLY bar it over by hand while heating around the studs? Kind of a hydraulic bump. EDIT- Wulf beat me to it. :rolleyes:
    Boneyard51 likes this.
  14. jimmy six
    jimmy six
    1/2 acetone and 1/2 ATF always worked for me. Hit the head all around to held what ever you use to wick down.
    48fordnut, loudbang and j-jock like this.
  15. This is a bit drastic, but has worked for me... Put nuts on the ends of the studs and weld them together, then turn the studs out. Give each stud a sharp wack with a dead-blow hammer before turning. You'll have to replace the studs, but it won't damage the head. It's not the head gasket holding it on but the corrosion in the stud holes.
    I did this because I didn't have the required 'puller' the factory specified to pull the head.
  16. larry k
    larry k
    If it's a flat head ? just loosen all the head bolts 3 rounds and start it up . Worked on a 239 ford years back !
    loudbang, vtx1800 and firstinsteele like this.
  17. TCTND
    TCTND
    No surprise it's not metric. In 1937 it could have been any one of several thread standards. Be careful and don't throw anything away.
  18. sdluck
    sdluck
  19. sdluck
    sdluck
    loudbang and warhorseracing like this.
  20. kabinenroller
    kabinenroller
    Thanks guys. These are all great ideas. As for using the engine to force the head loose, I have some concerns because the engine is very small and I believe I could bend a rod very easily. This engine is a four cylinder flathead the size of a loaf of bread and puts out all of 13 hp.
    I have been tapping on the studs with a small nylon mallet to try and shock the solvent into the stud holes.
    The studs only protruded the thickness of a normal hex nut so locking two nuts together won’t work. I could thread one nut onto a stud then weld the nut on, but if the stud refuses to release from the block I’m screwed for sure.
    This car has not run in many years, the engine was stuck when it arrived here. I soaked the cylinders for months, then turned the crankshaft back and forth until it moved. A couple valves were stuck open but with further soaking and tapping on them with a small br*** drift through the spark plug hole I was able to free them. The inside of the combustion chambers look like carbon build up (looking through the plug holes) so I want to pull the head and clean everything and inspect the cylinder walls. ( hopefully the engine will not need to be removed from the car for a rebuild)
    I appreciate all the suggestions and will try some of them. Please feel free to keep the ideas coming, I will report back with any progress.
  21. Marty Strode
    Marty Strode
    If you damage it getting it off, I have an extra to give you. I also have an engine/trans combo, and some spare pieces. IMG_5704.JPG IMG_5705.JPG
  22. kabinenroller
    kabinenroller
    Wow! I will definitely keep that in mind. Hopefully I will not damage anything. Thank You!
    Jim
    Deuces and loudbang like this.
  23. Garpo
    Garpo
    I had this problem with a Ford Flattie. had been sitting for years, and aluminium heads were seriously corroded onto the studs.
    I made a puller out of a piece of 1/2" plate. Drill to math the studs and the spark plug holes.
    Weld about 4" of all thread rod to some old spark plug bodies, and screw into plug holes. Put plate over the studs and use a handfull of about 3/8" bolts with nuts on underside. (see pictures) to line up with the head studs.
    Snug it up gently , Spray liberally with your favorite penetrant. and walk away. Next day gently tighten the nuts a bit more, more lube, and walk away. Slowly is the answer. The idea is to not damage the plug treads. Effectively pulling on spark plug threads, while SDC14356.JPG SDC14358.JPG SDC14361.JPG pushing on studs.
    My Ford head took 3 or 4 days to show any sign of moving. and about 14 days to remove. Undamaged. Second head took 10 days.
  24. oldolds
    oldolds
    Heat can be your friend. Do you have access to a large volume of hot water? Run hot water thru it a while. a couple cycles of hot and cold may work. A friend worked at a place that had steam. He would take stuck water cooled engines and plumb them up. And cycle heat thru them. Stuck air cooled engines went in a box surrounded by steam. A lot of things would free up after a bit of that.
  25. pirate
    pirate
    from Alabama
    I have no idea if this would work or not. But what about dripping some Ospho over the ends of the studs. Ospho main ingredient is diluted phosphoric acid which converts iron oxide (rust) to iron phosphate. It might loosen the rust around the studs which is probably the reason the head won’t come off. Phosphoric acid is used in the anodizing of aluminum process so shouldn’t hurt the cylinder head. Again have no idea if it would work but don’t think it would hurt anything. Just another idea.
  26. Deuces
    Deuces
    Yep! It's about the size of a loaf of Wonder Bread! Damn, I miss that bread.....:(:rolleyes:
    warhorseracing likes this.
  27. Thats nice. Wonder where all the other Topolino engines went to when the Topo,s were built into race cars ?
  28. Marty Strode
    Marty Strode
    I suppose they were s****ped. For those not familiar with the running gear in these little cars, it's a different arrangement. The engine is mounted as far ahead and low as possible. With the slope of the hood, the radiator is placed behind the engine, and the fan is driven off the back side of the generator. IMG_5706.JPG IMG_5709.JPG IMG_3055.JPG
    AHotRod, Tman, vtx1800 and 5 others like this.
  29. Marty
    That doesn't look like the same engine sitting in front of the car, as in the first 2 pictures. Optical illusion?
  30. Marty Strode
    Marty Strode
    Good eye, I thought it would fit, since Fiat and Chrysler are together as a company, but I am going to have to settle for a 215 Buick V-8.
