Projects Hood Scoop Ideas
Discussion in 'The Hokey Ass Message Board' started by ottoparts, Nov 4, 2020.
  1. Bandit Billy
    Bandit Billy
    @themoose I love ya but an LT-1 scoop belongs only on an LT-1 Vette....and then only on a plastic fantastic internet-tastic site...amatic.
    grumpy65 and loudbang like this.
  2. aircap
    aircap
    Keep it all Ford, and put on a Shaker hood scoop from a Mach 1.
    Deuces and loudbang like this.
  3. nochop
    nochop
    from norcal
    T bird
  4. If you really feel that you must install a hood scoop, the Ford heavy duty truck scoop is the only way to go on a car like yours... 002.JPG
  5. fortynut
    fortynut
    The most traditional alteration to the '57 Ranchero hood is to add louvers. Back in the day a friend had a '58 that he retrofitted with a '57 hood that was louvered. I thought it was perfect back then, and if I ever get my hands on a '57 or '58 I'm going to do the same. A mailbox on the hood is as out of place as a turd in a punch bowl, in my opinion; not only is it unsanitary, it changes the appeal of the restrained styling that went into it.
    X38, kidcampbell71, grumpy65 and 2 others like this.
  6. Deuces
    Deuces
    Thunderbolt tear drop!.....;)
    scotty t, warhorseracing and loudbang like this.
  7. egads
    egads
    ^^^^^^^^^^^^^^:):) DSC00010.JPG [​IMG]
  8. HJmaniac
    HJmaniac
    Maybe a stock Kaiser hood scoop. Hood contour looks close.
    brEad, dana barlow, Squablow and 6 others like this.
  9. catdad49
    catdad49
    What build style are you going with? Research that style ( hopefully from original builds) and then decide!
    hotrodjack33 and loudbang like this.
  10. As for style, I don't know yet. I'm trying to get that "a ha" moment.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    TrailerTrashToo and loudbang like this.
  11. catdad49
    catdad49
    Plenty of pics on the web, but stick with originals ( not someone else’s idea of a style/era).
  12. catdad49
    catdad49
    Otto, check out “George Kl*** Remembers”. Set aside plenty of time if you go there, I still haven’t seen it All!
    ottoparts and loudbang like this.
  13. chopolds
    chopolds
    from howell, nj
    I put a GTO scoop on a 56 Ford for a customer. Didn't look bad. 100_2078.JPG
    Fueler38, fauj, Deuces and 5 others like this.
  14. Boodlum
    Boodlum
    Mebbe the scoop from a 2002-2005 Thunderbird complete with recessed front section
  15. RmK57
    RmK57
    None of the scoops mentioned are going to work with a tunnel ram, except the one fabricated out of cardboard. I doubt the Boss 429 scoop would even be tall enough. If it were mine I wouldn't even use a scoop. Whack a big hole in the hood and use a couple velocity stacks or a Cobra style 2-4 air cleaner setup.
  16. Mike VV
    Mike VV
    from SoCal
    I know that this may not be the easiest thing to do...but try to find a second hood..!
    Then just cut a hole in the second hood to clear everything.
    Forget the scoop altogether (rain, what rain).
    Mike
    Bandit Billy, Boodlum and catdad49 like this.
  17. Jethro
    Jethro
    I agree with Mike , if it's got a tunnel ram I want to see the tunnel ram!
    Kinda like covering up some nice cleavage with a sweater.......just my thoughtso_O
    scotty t, Callmaker, loudbang and 2 others like this.
  18. catdad49
    catdad49
    Sweaters are great if it's a little Nippy out!
  19. Boodlum
    Boodlum
    Why cover the most attractive feature?
  20. I was thinking along this same path. There is a local folk selling parts and believes he might have a 58 hood and let me know.
  21. brEad, wraymen, loudbang and 4 others like this.
  22. Jethro
    Jethro
    SHWING!!!!!
    loudbang and Deuces like this.
  23. aircap
    aircap
    For a little more height (and more stealth) put on one from an AMX....
  24. Deuces
    Deuces
    That was an idea I had in mind... :)
  25. 1971BB427
    1971BB427
    from Oregon
    My personal choice with a tunnel ram engine would be a Hilborn type scoop on the carbs, or a pair of air cleaners, or velocity stacks. None of those scoops looks good on that clean '57 hood.
  26. 56don
    56don
    That body style needs the lowest profile hood scoop that will work for you. I agree, the TBird or a GTO scoop.
  27. papajohn
    papajohn
    I'm going with a 63 Tbird scoop on my 60 Olds wagon. Hope it clears my 3 deuces!
  28. Budget36
    Budget36
    A few things I recall from reading HRM in the 70’s, that cowl hoods actually made cars faster that a scoop did, had to do with the low pressure (as I recall) area allowing the carb to bring in more air.
    Anyways, if you go with a hole in the hood, do it cl***y, make something that has like a ridge around it, like a belt line so to speak.
    Just a hole looks quick and dirty when I see one in a hood
    Just my thoughts
    Also, there is a Ford SD scoop in the cl***ifieds here as well if that’s your thinking
    Gammz likes this.
  29. Hotrodmyk
    Hotrodmyk
    Please, NO scoop.
    Cosmo49 likes this.
  30. grumpy65
    grumpy65
    I did not post a reply until I mulled this over properly, and this is my opinion only.
    Lose the tunnel ram and have no scoop.
    I love a good tunnel rammed car, but in your case, I think form should outweigh function.
    And let's be honest here, how many street cars really run a tunnel ram for the performance gain?
    Jibs, Cosmo49, Gammz and 2 others like this.
