Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    So I was keeping an eye out for a enough parts to piece together a pair of Winfield S-B downdrafts... and basically found nothing worth paying money for. So I started building what I needed... I’ve already made the choke horns and V band clamps, as I figured that was as far as I would go. But after sifting thru a half a dozen cracked, stripped, and broken carbs bowls only to salvage a couple br*** pieces, I decided to go “all the way”! At least I’ll have a matching pair when I’m done!
    Here are a few pics of the progress so far...
    9E822420-CDF3-4A1C-B8C8-DACE07D60902.jpeg 51D5F9E9-A4B1-40AC-B8AD-E58A3C07071F.jpeg CE303324-A612-414A-B349-0C9FD99F16E7.jpeg 50F1CC34-AFF9-4CBC-9790-54BBEDC250AA.jpeg 3C4B0722-153F-4792-93DB-AC3E8810962D.jpeg
    NJ Don, 2devilles, tippa77 and 44 others like this.
  2. Liberty Garage
    Liberty Garage
    Look great Kevin
    steve
    Stogy and loudbang like this.
  3. adam401
    adam401
    Wow very impressive
    Stogy, loudbang and kidcampbell71 like this.
  4. catdad49
    catdad49
    You are a Craftsman!
  5. willys36
    willys36
    Uh may sing!!!!!!!
  6. continentaljohn
    continentaljohn
    Beautiful work and with all that work in the programming,I would make more then just a few they look awesome
    chryslerfan55, Stogy and loudbang like this.
  7. Kevin Pharis
    Kevin Pharis
    from Califunny
    Thanks for the kind words fellas...
    The plan right now is to make a small handful to make sure they work... and then we’ll see.
    chryslerfan55, Outback, Stogy and 4 others like this.
  8. patsurf
    patsurf
    you can sell them as jewelry if people don't want carbs!
    chryslerfan55, Stogy, Hnstray and 4 others like this.
  9. hotrodA
    hotrodA
    WOW!
    That's just magic!
  10. The37Kid
    The37Kid
    NICE! How will the lettering be attached?:rolleyes::rolleyes:
    Bob
  11. Amazing
  12. cadillacoffin
    cadillacoffin
    Casting these the goal?
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Casting these would be great...! Would be a lot less work and could get the engraving just rite too. But have to weigh the cost of tooling against volume, not to mention the tooling charge to set up each run at the foundry... oh yeah, all the different pieces too...
    Billet will just have to work for now... especially with my budget
  14. The37Kid
    The37Kid
    Only CNC stuff I know about is seen on TV, is this piece just a block that gets clamped in a fixture and everything we see is machined away without another setup? Bob
  15. tubman
    tubman
    I am constantly amazed the the talents and skills shown by some of the folks on here!:eek:
    Stogy, Hnstray and loudbang like this.
  16. cadillacoffin
    cadillacoffin
  17. Kevin Pharis
    Kevin Pharis
    from Califunny
    Yup! Here’s an action shot...
    chryslerfan55, Outback, Stogy and 8 others like this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’ve gone down the foundry route many times... iron, aluminum, bronze, sand, loose pattern, match plate, cope/drag, investment, 3D printed investment... it’s all just a h***le! My projects are never big enough to get the foundries attention, and so I end up waiting 6-8 months to get poor quality castings, damaged patterns, and angry customers! I’d rather cut everything from solid and be in control of my own destiny! It takes a bit longer per part, and doesn’t have the “feel” of a cast part, but I get it done!
    Sorry if this sounded like a rant...
  19. kidcampbell71
    kidcampbell71
    @427designer .. .. Tod ****ermore .. courtesy phone, line 1 !!
    Outback and loudbang like this.
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    Tod is certainly doing good work, and clearly has the connections to get priority during development and short production pours. I am not nearly as connected, and so don’t get the same level of service. Also, producing my own patterns has been a handicap as the foundries tend to prioritize their own creations first.
    This is just my reality, and lucky for me... most of my designs do not require hollow cavities and so can usually be made from solid with enough patience.
    chryslerfan55, Outback, Stogy and 6 others like this.
  21. patsurf
    patsurf
    well,enough patience ...AND skills!
  22. loudbang
    That is some NICE WORK. :)
    Stogy, TFoch and The Magic Ratchet like this.
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    Got distracted... and started making the tooling to spin up new br*** fuel floats for the Winfield S and SR carburetors.
    Pics soon...
  24. I suppose you could go over the oblivious areas with a needle scaler to sort of give a somewhat cast appearance and make it less obvious that it was billet. Mr. Bill aka @wstory has used that technique with success on his project.
    Having said all that, I think you are doing amazing work!
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    The carb body will be blended and then tumbled to give a much less billet look... here is a couple shots of the choke horn before and after tumble, and also polished...
    NJ Don, winr, chryslerfan55 and 28 others like this.
  26. I agree, it does look great after the blending and tumble!
    Stogy, weps, loudbang and 1 other person like this.
  27. chryslerfan55, Stogy and loudbang like this.
  28. Hitchhiker
    Hitchhiker
    Holy ****! This is rad!
  29. Kevin Pharis
    Kevin Pharis
    from Califunny
    I want to build up a copper plating system to apply an original type finish.
    The tumbled finish is nice as it is basically 400 grit non directional sanding. Basically ready for painting or polishing... but I suspect would look pretty dull if I were to copper plate at this point. Would no doubt look great if the parts were polished prior to plating... but the originals definitely were plated right after casting. So will take some experimentation before I decide if copper plating is something I want to do for myself... or others.
    chryslerfan55, Stogy, Hnstray and 6 others like this.
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    Just finished the metal spinning fixtures, and should be soldering up new S and SR fuel floats this time next week...
    winr, chryslerfan55, RICH B and 18 others like this.
