Projects Hood Scoop Ideas
Discussion in 'The Hokey Ass Message Board' started by ottoparts, Nov 4, 2020.
  1. papajohn
    papajohn
    Maybe just cut a hole and run a polished aluminum surfer scoop.
    scotty t, loudbang and fauj like this.
  2. BamaMav
    BamaMav
    from Berry, AL
    Only way I'd want a hole in a hood would be if there was a blower sticking through it!
    Bandit Billy likes this.
  3. grumpy65
    grumpy65
    True, but not on a cl***ic like that Ranchero. Under hood superchargers give the stop light heros a big surprise.
    Walk softly, but carry a big stick.
    Deuces, Gammz, loudbang and 1 other person like this.
  4. warhorseracing
    warhorseracing
    from cameron wv
    I said this before and this is the last time. If you gotta run that tunnel ram then you don't need no stinkin hood.
    scotty t, egads and Gammz like this.
  5. No hood scoops is best on 57 Fords, don't ruin a pretty car. JW
    Cosmo49 likes this.
  6. swade41
    swade41
    from Buffalo,NY
    These guys don't understand the direction you want to go with the car, if your thread ***le was 57 ranchero g***er nobody would mind a scoop.
    VFN Fibergl*** makes a couple different sizes of them
    http://www.vfnfibergl***.com/Factorystylescoops.htm
    Baron, Fueler38, vtx1800 and 4 others like this.
  7. Jethro
    Jethro
    Found this on another thread. The tunnel ram is covered but you get the picture.
    scotty t, 41 coupe, egads and 5 others like this.
  8. Gammz
    Gammz
    from Lincoln Ne
    [emoji23]
    loudbang, Deuces and kidcampbell71 like this.
  9. I don't know if I'm going towards the g***er style. It just happens that my current engine has a tunnel ram.
    However the quarters are fairly rusty and the easy repair would be to radius them out like a g***er
    Sent from my SM-G950U using The H.A.M.B. mobile app
    swade41, Deuces and loudbang like this.
  10. ekimneirbo
    ekimneirbo
    from Brooks Ky
    First thing I would do is measure the tunnel ram to see just how much room you are going to need. It doesn't matter what scoops you like until you know exactly how tall it has to be. If its not too high, I would consider grafting one of the T bird scoops into the hood as they will keep a nice flowing look rather than a large box.
    My opinion, bolt on scoops almost always look like an afterthought and I never cared for how they look. Its your car though, so my opinion really doesn't matter. To tell the truth, It probably looks best with the tunnel ram just sticking out of the hood. I'd get an extra hood so if you get tired of the tunnel ram, you can switch back.
    Of course you could always look into cutting and welding to make the tunnel ram just tall enough to fit under the hood scoop of your choice...........
    Tunnel rams aren't really well suited for daily driving, as they have lots of opportunity for fuel to attach to the walls and make equal fuel distribution difficult. If it were mine, I'd consider one of those unmentionable systems hidden on the backside of the intake tubes and dummy carbs up top working as air intakes only.
  11. fordflambe
    fordflambe
  12. HJmaniac
    HJmaniac
    Hey a ****** hump
    fordflambe and loudbang like this.
  13. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    In stall the engine in your car. then take some round rod and shape it to the contour of your hood front to back . That way you can see how much the carbs and manifold will extend out of the hood line and how much of a scoop it will take to cover it. although many of the suggestions would be cool if all you wanted was a hood scoop. but there is nothing dumber looking than a hood with a scoop and a hole cut in it for so the carbs clear. and unless the rest of the car resembles a real bad*** drag car a tunnel ram is totally out of place. Just my 2 cents ;) Larry
  14. 56don
    56don
    If you ditch the tunnel ram and get just a high rise intake perhaps a 52-54 Mercury style hood scoop would give you some extra clearance.
  15. Arominus
    Arominus
    I wouldn't touch that hood, if you're not going to fully repaint that thing I don't think its worth it to ruin the patina of the car right now for the tunnel ram. I'd ditch the tunnel ram and get a decent single 4bbl intake on it and run with that.
  16. swade41
    swade41
    from Buffalo,NY
    How about the fomoco tear drop or just the carbs with a Hilborn type scoop for that street brawler look ? Just don't bend to building something for someone else instead of for yourself, tell these guys your not building a custom or a stocker, you want something with some meat and potatoes to it.
    I know these are g***ers but just concentrate on the hood.
    Screenshot_20201111-220812_Google.jpg Screenshot_20201111-221023_Google.jpg Screenshot_20201111-220845_Google.jpg
    Even lawnmowers have scoops
  17. choptop40
    choptop40
    Cal Custom Panther Scoops...have an extra pair is your interested.... image.jpeg image.jpeg
    kidcampbell71, Deuces and aircap like this.
  18. Baron
    Baron
    Here's a few you look at. May give you a better idea of what you like. Good luck. 01009ChargerStevesWildRides017-vi.jpg 57 Ford white gasser.jpg 57 Ford gasser nicex.jpg 57%20Ford%20gasser%201x.jpg 14642423_10154586750393767_2681834421295623601_n.jpg 20663990_1293583320764392_4705800547616387051_n x.jpg 22688049_1352112734898028_5026253795642648381_n.jpg Screenshot_20181110-210706_x.jpg
  19. HJmaniac
    HJmaniac
    This link has a good sampling of '57 Fords. I think only 2 have scoops. Check out the potential of a stock hood.
  20. Deuces likes this.
  21. No real patina to speak of. Just a ****py paint job. However when the quarters get fixed, this paint will be gone.
  22. HJmaniac
    HJmaniac
    NoelC likes this.
  23. RmK57
    RmK57
    Wouldn't be my choice either but it's probably the most functional scoop that's been posted so far.
    That car I've seen at Mission raceway and I'm pretty sure he runs out of Idaho.
    It has a 351 stroked Windsor. Cool car.
  24. Robert Sturgis
    Robert Sturgis
  25. Would user @choptop40 please pick up the red phone
  26. 1971BB427
    1971BB427
    from Oregon
    I dislike all three of those scoops on a '57 Ford. I prefer no scoop at all, but if you really wanted a scoop, I'd get one of the Offenhauser aluminum scoops still made today. They look period, and would fit the car better.
    https://www.summitracing.com/parts/ofy-5285
  27. I never added a scoop to the car. I did however trade it off. Long story short, I now have a 63 Falcon, 2 door sedan delivery.
    NoelC likes this.
