Projects Got a little something to put the rocket in.
Discussion in 'The Hokey Ass Message Board' started by J_J2, Feb 24, 2020.
  1. warbird1
    warbird1
    OUCH is right! Wow, that's nasty...
    loudbang, Thor1 and J_J2 like this.
  2. J_J2
    J_J2
    LOL, surprisingly enough I didn’t but I did have to climb down the ladder to get out of the ceiling I remained remarkably calm but the guys I was working with were freaking out a little though.
    loudbang, anothercarguy and Thor1 like this.
  3. J_J2
    J_J2
    Well here’s my engine had a little mishap on the way home but everything appears to be OK, now I’m just gonna need help getting it from the truck into the garage
    loudbang and Thor1 like this.
  4. BJR
    BJR
    It looks like it fell apart! Good luck with your healing. You are now officially the one armed man.... for a while.
  5. J_J2
    J_J2
    Got the block painted, at least I can do that with one hand.
  6. 56sedandelivery
    56sedandelivery
    OUCH!!! Looks like you tried to shake hands with a running chain saw. Interesting it's the 4th of July today. There used to be a pathologist, at the hospital I worked at for 29 years, that had what was "left" of a persons hand in a jar of formaldehyde; he'd bring it out every 4th of July for employees to look at. M-80 blew up in the guys hand, and they amputated what was left of it. Lots of explosions going off as I write this, and the three Chihuahua's are in hiding. I am Butch/56sedandelivery.
  7. J_J2
    J_J2
    It sort of felt like it too! LOL
  8. bchctybob
    bchctybob
    I don’t want to sound like Sammy Safety or something but when I put my 324 Olds on my engine stand like that it really wanted to fall over. I took off the arms and bolted on a 1/2” plate drilled for the Olds. Much more stable, especially with the heads on.
    I hope that hand is healing fast, looking forward to seeing this all come together.
    loudbang, Paul, Thor1 and 1 other person like this.
  9. J_J2
    J_J2
    I understand what you’re talking about, But this is really stable I wasn’t sure if it was going to work out or not, But so far it’s been pretty good. Thank you, the hand is definitely healing up I’m in physical therapy now probably another six weeks or so with the splint (I hope).
  10. J_J2
    J_J2
    Just got new cam for the Olds, Camcraft even had a blank for the 55 324 block!
    triumph 1, loudbang, nochop and 3 others like this.
  11. J_J2
    J_J2
    Started re***embling the Rocket, I can’t seem to find any specs anywhere, torque, etc. Are there any resources that may have them?
  12. Paul
    Paul
    Editor
    scanned from 1956 shop manual
    note: camshaft bearing journal diameters on your '55 will be 1.8724"-1.8729" all else should be the same
  13. J_J2
    J_J2
    loudbang, Thor1 and Paul like this.
  14. vtwhead
    vtwhead
    @J_J2 don't forget the small gasket tabs at the rear main. I f you leave them out you will have a leaker. Secondly, ensure that you put the oil slinger on the front crank snout along with one of the front galley plugs that has the predrilled hole in for oiling the chain. Exhaust bolts go thru to the water jacket so treat them accordingly:D
    Good to see another Rocket getting back together. Guess your hand is back to being healthy(ier):rolleyes:
  15. J_J2
    J_J2
    Thanks Walt! It’s not 100% (probably will never be) but I can start using it now.
  16. J_J2
    J_J2
    A little progress is better than no progress.
  17. vtwhead
    vtwhead
    Jared, good to see ya updating. Did you get the block back together?
  18. Truckedup
    Truckedup
    Those Chevys have nice conservative styling. I like the two piece windshield.
    Will the stock steering box location clear the V8?
    J_J2, Thor1 and loudbang like this.
  19. J_J2
    J_J2
    I haven’t, I’m actually selling the engine to a gentleman who is building a 1955 Olds custom.
  20. vtwhead
    vtwhead
    So, what are you going to use for an engine in the project?
  21. TCATTC
    TCATTC
    Barely
  22. J_J2
    J_J2
    I acquired a 1965 396 that is currently at the machine shop. I was sad to see the Olds go, but it went to a good home.
  23. J_J2
    J_J2
    Made a little more progress today. Mocked up axle location, until it got too hot to work in the garage.
    brEad, loudbang, Thor1 and 1 other person like this.
  24. J_J2
    J_J2
    Got a little more done. Now at a stand still due to a move at the end of the month.
    Thor1, loudbang and 30tudor like this.
