Technical Chevy 235 cam swap to 216
Discussion in 'The Hokey Ass Message Board' started by wfopossum, Nov 8, 2020.
  1. wfopossum
    wfopossum
    I have a 48 216 with a stuck lifter that I broke trying to free it.I didn't realize they're hollow. I have a later 235 with the cam /lifters still in it. Are the cam/lifters interchangeable as long as they're both solid lifter engines ?
  2. RMONTY
    RMONTY
    I dont know the answer to your question, but I do have a question regarding your question. Why not drop the 235 in and use it instead of the 216?
    anthony myrick and VANDENPLAS like this.
  3. osut362
    osut362
    from East Texas
    there may be a difference in the cams as it relates to the distributor. some are cast steel vs forged or somethin like that. the gear on the dizzy has to match the material of the cam.
    6inarow likes this.
  4. wfopossum
    wfopossum
    The 235 is a parts motor a buddy gave me.About the only good parts left are the cam,lifters.
  5. 302GMC
    302GMC
    from Idaho
    In '54 the journal diameter is changed mid-year, so you'll want to verify the year - early '54 and older has same size as a 216. No idea whether they interchange.
  6. wfopossum
    wfopossum
    That's what I was thinking,the 235 was in a early 60's truck so it won't fit. Thanks for the info.
  7. junkyardjeff
    junkyardjeff
    From what I have read the cams are made from different materials,if the 235 cam would fit the block the 235 distributor would have to be used if it fits.
