Projects 1938,39,40 Sloper Custom
Discussion in 'The Hokey Ass Message Board' started by X38, Nov 4, 2020.
  1. neilswheels
    neilswheels
    from England
    I’m sure I remember seeing this on here before. Love the slower lines, not as ‘hunchback, as the sedan. Looking forward to seeing your progress
  2. mrquickwhip
    mrquickwhip
    Great looking project, will be following with great interest.
  3. WiredSpider
    WiredSpider
    Looks a lot like Mick Ellis,s old one out of Melbourne
  4. X38
    X38
    What makes you say that?
  5. WiredSpider
    WiredSpider
    I know it isn,t his but not many chopped slopers with slanted B pillars around
  6. CadMad
    CadMad
    Come on mate. Show us ya grille.
    kidcampbell71 likes this.
  7. CadMad
    CadMad
    440CBD6C-E4F4-46AD-98A6-CE7309058458.jpeg 5A6A77A3-2C5F-400B-AB74-0249DB422B59.jpeg Spoiler alert....
    I found these pics from back in the late 40s.
  8. @X38 didn't you fabricate the grille out of Stainless?
    Sandgroper and kidcampbell71 like this.
  9. CadMad
    CadMad
    He must be at his kid’s sport carnival. Yes he did fabricate that grille.
    Outback, Jimmy B and kidcampbell71 like this.
  10. X38
    X38
    Oh ****in great...would you like to take over?
  11. manyolcars
    manyolcars
  12. X38
    X38
    Back to our scheduled program...
    First up was to lift the body off and attack the frame. It was pretty grungy after the years had p***ed, but cleaned up okay for now. I rigged up a basic jig to make sure everything is as it should be, plus the frame will be boxed front to rear so the jig should help with that too.
    The plan is for a tail dragger stance, so low in the back, but I still want travel. That meant a C notch was in order.
    I didn't want to loose any more floor area than necessary so worked out a notch that would allow decent travel with minimum floor intrusion. Also, by tail dragger I'm talking 40's/early 50's, not belly on the ground low.;)
    I made good use of cardboard then started with the cutting.
    Next to come will be fishplates of the outside of the notch, as is required here by the powers that be. (This whole rolling ch***is will be inspected in the raw with no welds dressed.)
  13. Dean Lowe
    Dean Lowe
    Color me impressed Tony!
  14. X38
    X38
  15. panhead_pete
    panhead_pete
    Great to see you being able to get back to it mate!
  16. alchemy
    alchemy
    I thought it had to be inspected before you dressed the welds?
  17. X38
    X38
    Yes, that's true, but...I have to weld fish plates on the notch so wanted to clean up the shape so far, while I had access. More welding to come.
    Thing is, there will be more than enough welding left un touched on this frame for the inspectors to ***ess whether the work is good enough. That's my plan anyway.
  18. 48fordnut
    48fordnut
    Nice work. The finish will be amazing.
  19. X38
    X38
    Man, I sure hope so!
  20. X38
    X38
    Here is the c-notch with the fish plate welded on.
    The springs are Holden Rodeo (Isuzu) pickup and I fabbed the mounts to be inboard of the frame for low factor without excessive lowering blocks.
    Rear x-member the hangers attach to is 100x50mm box, which fits perfectly inside the original member. Then full welded at the ends plus a few rosettes as well for good measure. ;)
    You can see how I modified the centre of the X member for the transmission. Transmission crossmember is still in the process of being made in this pic.
    Trans x-member in
    And this is all I'm going to show of the front crossmember
  21. James D
    James D
    Excellent - I really like this car. This shape is what every chopped sedan wishes it looked like.
    kidcampbell71 and X38 like this.
  22. The 39 guy
    The 39 guy
    Wow , that's some really nice well thought out fabrication. This should give your sloper a great foundation!
    chryslerfan55, Hnstray and X38 like this.
  23. BrerHair
    BrerHair
    Subscribed. Love it. Inspiration for those of us in the same Raising A Family boat with a car project on hold.
    chryslerfan55 and X38 like this.
  24. Dean Lowe
    Dean Lowe
    Beautiful fab work Tony!
  25. 4tford
    4tford
    Nice work on the 40.
  26. Roger O'Dell
    Roger O'Dell
  27. The ch***is is looking real good, I like the idea of the inboard leaf springs.
    Do you use Rustbuster on bare metal parts? What is the best way to apply? My ch***is needs a coat to protect it.
  28. X38
    X38
    Thanks guys, appreciate the kind words.
    Jimmy I do use Rustbuster, it's great stuff. Sometimes I'll brush it, but generally I wipe it over with a small piece of cloth. I find it keeps the metal in good condition for a long time, especially if you don't handle it too much with sweaty fingers. Every now and then I might give a patch a wipe if I notice any sign of surface rust developing, usually where I've been working on something.
    chryslerfan55 and Jimmy B like this.
  29. The 39 guy
    The 39 guy
    Just guessing but it looks like humidity could be a problem in Brisbane?
  30. X38
    X38
    Yes, hot and humid from now until March/April. Summer is the wet season. My garage is nice and dry I'm happy to say so my stuff is fairly well protected. And usually cool enough to work. :)
    Winter is really the best roadster weather here because you can get fried in summer: I know from (painful) experience!
    chryslerfan55 and The 39 guy like this.
