Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. Drylake
    Drylake
    I received a beaten up 37 boot lid handle in the post today. It goes well with my beaten up roadster :). 20201111_114345.jpg
  2. They look like British Lucas "King Of The Road" marker lights. There would normally be a small badge in that small round hole on the top edge. Common on lots of vintage British cars.
    Thor1, brEad, chryslerfan55 and 4 others like this.
  3. dsiddons
    dsiddons
    from Indiana
    I just got one of those for my Model A.
  4. Drylake
    Drylake
    I found some time to muck around with the roadster today. Put the template in to the tube benders for the radiator hoses, polished up the fuel pump base and started going through the pumps I have to choose from. I hope to fire this engine up over the Christmas break. I'd really like to switch this oil filter housing out for an old chrome one if I get the chance... 20201113_142708.jpg 20201113_200043.jpg 20201113_201115.jpg
  5. Drylake
    Drylake
    20201211_124142.jpg 20201211_124145.jpg 20201211_124149.jpg 20201211_124221.jpg
    I've had the first radiator tube bent up, I'll trim the upper rubber hose and straighten out the lower hose over the weekend. Thoughts?
  6. waxhead
    waxhead
    from West Oz
    Looks good from here :)
  7. reefer
    reefer
    2x rubber 45’s and a straight tube would look better imo.
    Cosmo49, tomkelly88, greaser and 7 others like this.
  8. Dick Stevens
    Dick Stevens
  9. Runnin shine
    Runnin shine
    Start polishing those heads and them sweet S-pipes.
    Straight radiator tubes do look plenty good but those you’ve made up are more interesting and unique.
  10. Mart
    Mart
    I was thinking it but as someone has already said it, 2X45s and straight in between would look less fussy. Just enough to radius around the end of the dynamo.
    Mart.
  11. RICH B
    RICH B
    I always liked straight up and a 90 forward kinda like the AMT deuce models in the 60's. So many hose variations and they all have their own unique look.
    drylakespeedshop likes this.
  12. Drylake
    Drylake
    My thoughts were to keep the hose low and give 20201113_142713.jpg clearer access and view to the carbs and scoops. The resulting wiggly line of the hose draws too much attention I think?
    rpm56, tomkelly88, brEad and 4 others like this.
  13. dumprat
    dumprat
    from b.c.
    A stock F1 hose has a45 degree bend at bother ends and the rubber parts are straight. It's a nice clean look. You could likely pull off something similar.
    I kinda like asemetrical bends myself but each to their own.
  14. Peanut 1959
    Peanut 1959
    ...Or It could be one of the features that makes your car stand apart from the rest!
    rpm56, chryslerfan55, brEad and 4 others like this.
  15. Speedy Canuck
    Speedy Canuck
  16. Drylake
    Drylake
    If I black the tubes out, and keep them low, expose the view of the carbs and scoops... keeping symmetry on both hoses is also important. 20201218_190707.jpg 20201218_191617.jpg
  17. tub1
    tub1
    from tasmania
    Looks great to me
    drylakespeedshop and Thor1 like this.
  18. brEad
    brEad
    I think blacking out the pipe does the trick. That looks really good there!
  19. Runnin shine
    Runnin shine
    Oooh, that would look good, like stock off some other model.
  20. cfmvw
    cfmvw
    This is really cool! I'm always impressed with the builds from scrounged parts. What are the small auxillary lights mounted on the frame from? Went through the thread, but probably missed the reference to them.
    Thor1 likes this.
  21. milosmith
    milosmith
    Just my opinion, but the combo of rubber and pipe looks a little busy. I used the one piece rubber solution with the 59A-B in my '34 truck...
    These look much nicer than the generic 22" long flexible hoses, and you eliminate four connections that are potential leak points too.
    Third Gen Automotive in Tennessee, USA sells them - part number 40-8262-59A.
    Otherwise, I love your build. You're doing great work!
    Nailhead A-V8, Cosmo49, rpm56 and 8 others like this.
  22. Jeff34
    Jeff34
    Looks familiar [emoji57]. I also think it looks real clean and simple but to each their own. IMG_1388.JPG
    rpm56, Drylake, chryslerfan55 and 2 others like this.
  23. dumprat
    dumprat
    from b.c.
    I think the bent up steel is more hot rod less restoration. Put some big shiny air cleaners on those dual carbs. The rad hose won't even be a thought.
  24. greaser
    greaser
    Hoses are now focal point of engine bay. I say your car, your choice.
  25. Runnin shine
    Runnin shine
  26. Drylake
    Drylake
    I agree the simplicity of the hose looks nice, the problem is they won't fit over my offset generator set up. I'll keep playing and see what I come up with. Thank you for your input! Maybe something like this photo would be more minimalistic than what I have done.
  27. Drylake
    Drylake
  28. Drylake
    Drylake
    The small front lights are an aftermarket light intended to be a reverse light originally. I looked them up in the "Campbell & Co." Catalog a while ago. I like the Mohawk style lens they have. I think they go nicely with guide type (Corocoran & brown) headlights. 20201227_121454.jpg
  29. Drylake
    Drylake
    Still collecting parts for the roadster. Family and renovations have taken priority for a little while. 20210121_190303.jpg
  30. Drylake
    Drylake
