Technical How do I identify different SBC engines
Discussion in 'Traditional Hot Rods' started by HOTRODPRIMER, Nov 10, 2020.
  1. jimmy six
    jimmy six
  2. Deuces
    Deuces
    Drop the 283 crank in the 327 block and build a high winding screamer!....... ;)
  3. squirrel
    I can tell a lot by looking at them. 283 has that old look, script valve covers, canister oil filter or a thick adapter for spin on, draft tube or the fitting for the PCV valve at the back of the block, round crank flange, small damper, early small carb base intake, ram horn manifolds, etc.
    327 has some of the early stuff, abut has different valve covers, bigger damper but not real big, usually a 4bbl but not always.
    350 is a more modern engine, no road draft tube or hole for it, spin on filter built in, log manifolds on most of them, larger carb base, bigger damper, funky shape crank flange, smooth valve covers with holes for PCV and breather.
    If you want to get into numbers, you'll find a 3 letter suffix code on most 350s, one or two on the 1950s-60s engines. I have several books that list codes, but they're not easy to take with me.
  4. Roothawg
    Roothawg
    I'll take all the small journal stuff y'all wanna get rid of. You'll have to deliver them of course....;)
  5. 31hotrodguy
    31hotrodguy
    I like the 283s with the 852 castings Plus I like small journal 327s. I’m just throwing that out there in case people want to s**** them. [emoji6].
    HOTRODPRIMER likes this.
  6. Wow, I thought I had every part of knowledge there was to know about the SBC engine. Then as usual, the H.A.M.B. teaches me something new. Thanks, vinfab & mgtstumpy !
      31.1 KB
  7. 56don
    56don
    A sbc is probably the easiest engine to identify . Try to id a Ford just visually. The numbers cast are not all that helpful on them.
  8. Blues4U
    Blues4U
    from So Cal
    Around here people tend to think these are made out of gold, Craigslist & facebook marketplace ads for 327's especially! But even 283's as well. Wish you were closer I'd take them off your hands.
  9. harpo1313
    harpo1313
    from wareham,ma
    Cant help with I D but dont forget to give them a spin.
    HOTRODPRIMER and Deuces like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    I was not offered the option of pick and choose, all or nothing,take it or leave it.
    I was told if I don't want them someone else will, if not the junk yard will tale them. HRP
    Deuces and 31hotrodguy like this.
  11. 31hotrodguy
    31hotrodguy
  12. 31hotrodguy
    31hotrodguy
    I’ve ended up with Hipo stuff and I’ve ended up with 307’s. But I always take them. Then I can decide what goes to the s**** and what stays.
    alanp561, blue57ford, -Brent- and 6 others like this.
  13. guthriesmith
    guthriesmith
    Yep, I take all the SBC’s I can get especially for free or close. Recently got a free 350 with with a nice set of ported power pack heads and also a set of aluminum aftermarket heads. Also, got a great deal on a rebuilt ‘66 283. The guy that I got the 283 from is supposed to also be giving me a free 400. I’m kinda liking the LS swap fad as long as it makes old small blocks cheap or worthless. :D
    You know you will have to report back on what these 4 are now.
  14. HOTRODPRIMER
    HOTRODPRIMER
    I will report on my findings but there are only 3 engines. HRP
    guthriesmith, Deuces and 31hotrodguy like this.
  15. pitman
    pitman
    Anyone, know the year the side mounts began? I'm guessing '58, could be later. Likely when ****** tailshaft mount came along
  16. redo32
    redo32
  17. Deuces
    Deuces
    307 cranks are worth keeping... You can install those in a 350 block and make a 327.... :cool:
  18. DDDenny
    The "road draft tube" is the late 50's/early 60's system, the 67 Camaro SS 350(only) did have the provision in the block casting to accept a pvc fitting and to my knowledge the California destined cars used a "fresh air tube" style system similar to my 67 Novas' 327.
    alanp561, Deuces, olscrounger and 3 others like this.
  19. Grant Clemens
    Grant Clemens
    from Montana
    265 cubic inch small blocks have no place to mount a starter to the block. They use a different style starter that bolts to the bellhousing.
  20. BigDogSS
    BigDogSS
    from SoCal
    EVERY small block (283, 302, 327, 350) used the "fresh air tube" (aka - Closed PCV system) in California destined 1967 Chevrolet cars.
  21. Budget36
    Budget36
    Well, does piss or get off the pot ring a bell? You never mentioned price but if 150 bucks for 3 SBC engines, you can’t get hurt. If they want 600 for the three, you can.
    Now, real question comes to mind is are you looking to buy low and make a few bucks, or do you have plans to put a SBC in something down the road?
    Personally if I don’t have a use for something, I see no reason to buy it, unless I am sure I can make a buck. But, hauling 3 engines home, storing them and selling them, seems like a h***le.
    I’d say if you were 20 years old, get them. You’d use them. Maybe. Now?
    Beanscoot and BigDogSS like this.
  22. DDDenny
    I'm sure any California resident will agree with you, especially those from back in the day that actually lived it, myself I've learned not to make "sunk in stone" statements here about things I'm not positive about.
    Seems there are plenty of trolls waiting to pounce and correct (anyone) if not entirely accurate.
  23. BigDogSS
    BigDogSS
    from SoCal
    DDDenny, I feel the same way. My apologies for sounding like I was correcting you. I was merely "expanding" on your statement...I've owned 1967 Chevrolets for almost 35 years and the whole emission set up in CA (only) for 1967 is interesting.
    Blues4U likes this.
  24. warhorseracing
    warhorseracing
    from cameron wv
    SBC identification? Easy. If they are orange then from a vette.:cool: If they are black then from a truck.:p And not to mention that everything will interchange no matter what,:confused: unlike a dodge.
    pitman, VANDENPLAS and 31hotrodguy like this.
  25. panhead_pete
    panhead_pete
    Its all about pricing. You can buy a very healthy (+350HP) ready to run engine a LOT cheaper than getting the equivlent built. No need to blame anyone, in fact its an opputunity for those that can build their own engines, especially with all the LS swaps where 500HP seems to be relatively easy to achieve, its just a pity the LS's look like *** :) .
  26. Budget36
    Budget36
    I ***ume you are referring to my post, all good. Not sure what being in California has to do with the price of rice in China.
  27. DDDenny
    Maybe I missed something but I'm not sure why you would ***ume I was referring to your post, I do recall quoting somebody else, and actually I think it was them that originally mentioned California issued cars in regards to pcv system components.
    Yes it definitely is relevent (to those who care) and yes, I know this is a hot rod board where (usually) these type of discussions aren't our core concern, though it has been a pretty common discussion on the HAMB in the past.
    Now that I think about it, my careful wording was in response to the missplaced terminology many people (not referring to you) use, i.e. road draft tube when it is a completely different system ( earlier design).
    As you said, it's all good from my end too.
    Edit
    I see that my quote was not inserted and my post directly followed yours, sorry.
    VANDENPLAS and Budget36 like this.
  28. Budget36
    Budget36
    Copy that, just saw your reply after mine.
    I’ll now go into hibernation;)
  29. 56sedandelivery
    56sedandelivery
    Actually, the 1957, 265 DO have the provision for a block mounted starter motor, as well as the 283's of the same year. Both used the same casting number, and the reason for the block being prepped for a starter motor was because of the optional Turbo-Glide transmission, that was aluminum. The 57, 265 never came with a turbo-Glide however, and all manual trans/Powerglides used bellhousing mounted starters. The 57, 265, 2 barrel was the baseline V-8, but only with a manual transmission. Powerglide, Turbo-Glide, 4 barrel, ALL got the 283 engine. I have a 57, 265 block, and located one just so I could use one of my built aluminum Powerglides, if I ever get around to it.
    I am Butch/56sedandelivery.
    Torkwrench and 31hotrodguy like this.
  30. DDDenny
    Please don't, "we all matter"!
    egads, Deuces and Budget36 like this.
