Just wanted to share how i solved music in my Mercury. I did not want to fumble across the seat to glovebox or under seat to change volume or track, and the available radios didnt have the design that matched the rest of instrumentation. The solution i went for was an Retro Sound Zuma that i planned to hide the most of behind original radio face. I found out that it was very easy to open my original radio and use the front half in combination with the new one. Backside of gl*** i tinted with a bit of black film so when radio is off only scale can be seen. Even the original knobs fitted perfect on the new radio. USB and other inputs i have placed in ash-tray. volume, tone and tuning works as original even pre-sets on push ****ons. For speakers i have started with pair of 4" in original position, maybe some additional speakers will be planned for the extra punch
Nice! Do you have more details,such as output , which radio, they have a few selections which did you use etc.
Good job ! Hey, I can hear it from here !! Enjoy them tunes while Crusin' !!! Jonnie www.legends.thewwbc.net
Hi "desotot" i used the Zuma model, but just after finalizing installation they released "model 2" that would have been even better with blutooth...but thats life, always something new to plan for.
I like it. Nothing worse looking than a modern radio chopped into an old dash, this seems like a good solution.
Thanks for the heads up about Zuma. Someone cut the dash in my 58 F100, but the 57-63 Karmman Ghia radia might just fit and look almost appropriate there.
I will have to remember the Zuma when I get another car that needs tunes and has a normal style radio unlike what my 55 Ford has for a radio.
Found some space for eight inch three way 500 W pioneers, really improved the sound. Will try to punch holes in interior panels to get an not so visible opening. Posted using the Full Custom H.A.M.B. App!
I bought one of their units for my 46 Olds a few years ago and will upgrade to i-pod and USB when installed. I'm taking longer than I thought to build this car and haven't used it yet. Can't beat the OEM look in an old ash facia.
Added floating speaker grille in rear, to cover 2-channel speaker Sent from my SM-G973F using The H.A.M.B. mobile app
So It looks like you just used the face plate of your original radio and stuck the new one inside it, is that correct? I would love to figure out how to use my original push ****ons on my 49 Buick as they spell out BUICK. But from their web site the push ****on spacing is too close together. Any Ideas?
I know the pic isn’t the best . But we made a s/s plate to hold the push ****ons and original knobs as a facade. The RH knob turns to allow the face to drop down to access modern tunes, but in reality we don't need to as it all work by a remote anyway. I hind sight we should have gone blue tooth , but a USB works fine. We have had 2 custom auto sound (vintage look) units in our 54 , why 2 because both were faulty junk.
Yes you are correct just front facia was used. I was lucky the knobs was very close in size as original knobs, if your buick knobs can be fitted i dont know.. if you want can check exact dimensions? Sent from my SM-G973F using The H.A.M.B. mobile app
Love your blue knobs! My first retrosound was **** also, shutting down occationaly and more and more often until total nonfuntional but i liked the design so i tested a 2nd unit that have Bluetooth and that one has worked fine. Sent from my SM-G973F using The H.A.M.B. mobile app
