Hot Rods Schematics
Discussion in 'The Hokey Ass Message Board' started by oldeman, Nov 11, 2020.
  1. oldeman
    oldeman
    from Ms
    Let see some of those wiring schematic that you drew up when you wired the car
  2. seb fontana
    seb fontana
    from ct
    And added to, HAHAHAHAHAHA. Looks like a road map of CT!
  3. goldmountain
    goldmountain
    Don't need a schematic. Just keep a good inventory in your head as to what you have done and label the ends of the wire as you go. Those wiring schematics just drive you batty trying to follow the lines.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    chryslerfan55 and olscrounger like this.
  4. Almostdone
    Almostdone
    I bought a kit from Centech, but I did lay it out before install.
    john
    chryslerfan55 and VANDENPLAS like this.
  5. pprather
    pprather
    olscrounger and VANDENPLAS like this.
  6. lippy
    lippy
    from Ks
    Vandenplas, whats that funny squiggly deal on the lft bottom corner? lol
  7. When I rewired my '50 the wiring diagram was mostly in my head, it's still in there somewhere, I hope. Full disclosure, I did draw up some individual diagrams for circuits that were more complex than what someone else may have designed. I used relays to reduce the load thru my ignition switch and made my interior lights (of all things) more complex than they needed to be. So there is some help for the lucky person who gets this car after I die. :(
  8. Budget36
    Budget36
    Search for Rebel Harness here, I recall a year or so back that the vendor put or linked the diagrams in a thread.
    Anyone else recall that?
  9. Budget36
    Budget36
  10. ClayMart
    ClayMart
    This is my go-to wiring schematic! Headlamps, ignition systems, dome lamps, it works for everything! :rolleyes:
  11. David Gersic
    David Gersic
    from DeKalb, IL
  12. David Gersic
    David Gersic
    from DeKalb, IL
  13. Mimilan
    Mimilan
    Here's one,
    Trying to help a fellow HAMBer 12000 miles away
    wiring a 58 Chevy Truck with a 283 engine swap
    This one is how we wire a race car using a Ford Starter Relay and a low amp switch as a Battery Isolator/Disconnect
    VANDENPLAS likes this.
  14. brading
    brading
    Here is one I done though I have altered it since. The numbers next to the wiring refer to the colour coding and wire size. Think if you break each section of wiring down such engine, lights etc it makes it easier to follow
    David Gersic and VANDENPLAS like this.
  15. Fabber McGee
    Fabber McGee
    Bought another 29 Tudor last year about this time. While everyone was hiding from the "bat bugs" in March and April I was going over my new car. One of the improvements I made was switching to 12 volts and adding circuit protection.
    I rooted around in my jun..., uh, inventory until I found a suitable box to hold the fuse panel and make my terminations. Turns out it was the original on/off switch from my dad's Powermatic table saw that he bought new in 1970. Has sort of an art deco look to the cover. I filled the screw holes and the hole for the toggle and hinged the lid.
    Figured I'd better make a map of what I was doing to fold up and store inside the box. That may save me a lot of hunting around with a flashlight for the problem while parked along side the road some dark and rainy night, haha.
    I used a relay to heat up most of the panel so the ignition switch would turn off everything but the lights and I wouldn't need big amperage right up against my gas tank.
    Flasher and relay are in the cover. Apparently I didn't take a picture with all the wires installed, but here's one that shows most of them. Those are self resetting breakers. 20200525_173944_resized (Small).jpg
  16. brading
    brading
    David Gersic likes this.
  17. Model A Gomez
    Model A Gomez
    Wiring diagram ?? You don't need a wiring diagram, I wired my avatar in the mid 90's with a roll of black wire, simple car just ignition system, starting circuit and lights. Sold the car in the late 90's and sure somebody out there has cussed me ! I used a modern wiring kit on my V8 A and much easier with the color coded wiring.
    and you can't beat the price if you want to color code the circuits.
    Boneyard51 likes this.
  18. 1971BB427
    1971BB427
    from Oregon
    Never drew up a diagram to wire a car yet. And in recent years it's been even less likely since I've switched to buying universal wiring kits that come with a diagram, and most of the circuitry pre wired to just require termination at the ends.
    Back when the kits were $500-$800 I started out with a 8-12 ckt. fuse block, and simply wired everything to that. I sure don't miss using such a base level kit that took me 3 days to wire. With the newer universal kits I can wrap a car up in one day.
    olscrounger likes this.
  19. David Gersic
    David Gersic
    from DeKalb, IL
    I didn’t need the diagram to wire it. I drew it so that when I need to troubleshoot it some day, I don’t have to start from “how the f— was this supposed to work?”
    Fabber McGee, VANDENPLAS and Mimilan like this.
  20. '49 Ford Coupe
    '49 Ford Coupe
  21. Paul
    Paul
    Editor
    'drew this one in CAD
    with the help of the HAMB
    when rewiring a friend's car.
    'tried to make it look "old timey"
    LAROKE, winduptoy, Boneyard51 and 4 others like this.
  22. rustydusty
    rustydusty
    16052141519695968862839677073050.jpg simple lighting system. Power comes from fuse panel, and have since added a relay...
  23. MARKDTN
    MARKDTN
    My 1943 2N tractor with 8BA flathead. It does have a more modern 2-speed fan. wirediaw.jpg
  24. Almostdone
    Almostdone
    wow, you win!
  25. Boneyard51
    Boneyard51
    Could explain to me why you have “ switched” and “ non switched” voltage going to your light switch? Thanks.
    Bones
  26. wraymen
    wraymen
    Here is a pic of me working on the MG’s Lucas wiring.
  27. Mimilan
    Mimilan
    Headlights require Ignition on,
    Parklight/Taillight circuit can be left on with the car locked.
    There are 2 separate power feeds in the switch
    Sometimes the interior Dome light is also powered from the Parklight/Taillight feed [with a dimmer]
  28. TrailerTrashToo
    TrailerTrashToo
    Maybe for the interior lights (aka dome light). The "P" terminal on the light switch is not connected in this diagram. Been a while since I worked on older American stuff (mostly Bluebird school buses and IH light trucks).
    EDIT: I like Mimiam's answer.
  29. Mimilan
    Mimilan
    Thanks!
    I like the fact that somebody can read wiring schematics enough to question this.:D
    TrailerTrashToo and Boneyard51 like this.
