Technical Clutch Pedal Hitting Frame
Discussion in 'The Hokey Ass Message Board' started by FatfenderJ, Nov 12, 2020.
  1. FatfenderJ
    FatfenderJ
    Whats the best way to modify the crossmember to get pedal clearance? Its a 47 Ford sedan with a widened x member center section.
  2. badshifter
    badshifter
    You modify the pedal not the crossmember. Bend left, cut off pad mount and weld it back on to the other side. Done. Is the brake pedal going to hit the clutch slave cylinder?
  3. woodiewagon46
    woodiewagon46
    from New York
    I would do it the exact way that bad shifter recommends. Why over complicate things, plus, you can remove the pedal and do all the modifications on the workbench.
    Just Gary likes this.
  4. FOURTYDLX
    FOURTYDLX
    May have to modify hose location
  5. FatfenderJ
    FatfenderJ
    Bend the pedal. Huh, you guys are smart.
    Thanks
    Joel
