Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. dumprat
    dumprat
    from b.c.
    And this is why I have a brush painted truck. I hit the body not once but twice with the nut on the grinder while zipping the ends of the bolts on my box. If I had a $20,000 paint job I would freak. In this case I just sanded it and will slobber more paint on. With a smile on my face the whole time! IMG_0085.jpg
  2. Six Ball
    Six Ball
    from Nevada
    Probably still cussed when you did it.
    Woogeroo, patmanta, guitarguy and 5 others like this.
  3. dumprat
    dumprat
    from b.c.
  4. J. A. Miller
    J. A. Miller
    from Central NY
    I bet the first time was "son of a *****" and the second time was "mother ****er". Am I close?:mad:
    Stogy, Woogeroo, dumprat and 2 others like this.
  5. guitarguy
    guitarguy
    The 20 foot paint job for the win in this case. Sorry you hit, but glad the fix is so easy.
    Stogy and loudbang like this.
  6. dumprat
    dumprat
    from b.c.
    Because the shop wasn't dusty enough I decided to break out the table saw and finish up the wood on the back of the cab. IMG_0088.jpg
  7. desotot
    desotot
    looking good. I should have brush painted my T
  8. dumprat
    dumprat
    from b.c.
    Thanks Jack!
  9. Six Ball
    Six Ball
    from Nevada
    I like that! it. The wood adds a lot.
  10. Tim
    Tim
    from KCMO
    Wonder how much road/vibration noise that wood soaks up. Bet it’s noticeable
  11. Been a while since I checked your thread out. Truck looks great!
  12. dumprat
    dumprat
    from b.c.
    I am shocked how much oil can the wood takes out. I had modify how it fits to get the seat base back another 2" but it all clears now.
    Stogy, Six Ball, BradinNC and 4 others like this.
  13. Runnin shine
    Runnin shine
  14. dumprat
    dumprat
    from b.c.
    That kid looks like me waiting for spring!
  15. dumprat
    dumprat
    from b.c.
    IMG_0112.jpg IMG_0114.jpg Put the rear gl*** in today. My daughter had to help me get the nuts and washers on the screws.
    And I clocked all the screws at 45 degrees just for Wyatt! Mwahahahaha!
    Tim, Jeff34, patmanta and 9 others like this.
  16. tb33anda3rd
    tb33anda3rd
    usually carriage bolts are used with the heads on the out side and the nuts inside a countersunk hole.
  17. dumprat
    dumprat
    from b.c.
    That is correct, and I thought it looks dumb with painted over carriage bolts. I like the stainless acorns better. I used them on all the box bolts, suspension brackets, and they will be on the engine and a few other spots as well. Kinda 50's show car style.
    Stogy, Woogeroo, loudbang and 3 others like this.
  18. dumprat
    dumprat
    from b.c.
    IMG_0123.jpg Windshield and back window in! I need to get the lower tracks made and into the doors so I can get the sides cut. But I am getting pretty excited to see it looking more complete every day!
  19. Duke
    Duke
    How close are you to starting it? The finish line is near. Looks good!
  20. Runnin shine
    Runnin shine
  21. dumprat
    dumprat
    from b.c.
    It's getting close. Needs wiring, fuel line hooked up, plug wires, gauges and some fooling with rad hoses. Easy stuff but it all takes time.
    Stogy, Tim, Woogeroo and 2 others like this.
  22. Gnater
    Gnater
    Looking good!
  23. dumprat
    dumprat
    from b.c.
    62951714438__D4455F73-B220-47B5-A343-80CA2F695C98.jpg Hacking and hammering at trans tunnel today. No solid plan going in, just winging it. I needs to fit tight, it has 3/16 clearance to the ****tershield as a minimum.
    Stogy, Tim, brEad and 8 others like this.
  24. Runnin shine
    Runnin shine
    It’s gotta hurt sacrificing any available space inside a PU cab even a 33-34. Hopefully that killer engine and trans make it all worth it. Certainly looks good.
    We feel your pain and can’t wait to see this one finished Matt.
    Jeff34 likes this.
  25. dumprat
    dumprat
    from b.c.
    Thanks Wyatt. If I was 5'8" and 100 lbs everything would be easy. As it is I need every 1/4" of extra space. The tunnel is an odd shape to add extra foot rom so I can actually get a foot on the s**** gas pedal.
  26. Six Ball
    Six Ball
    from Nevada
    People were smaller then, at least the ones who designed the cars. If they had't all worn big hats we could never fit in these things. :rolleyes:
  27. dumprat
    dumprat
    from b.c.
    IMG_0211.jpg Picking my way through the endless list of little **** that seems to take forever! Fitting e brake cables, mounting stuff to the firewall, making plug wires, steering column bolted in, driveshaft and trans seals, and finished up the trans tunnel.
    Primer over "green lead" but it's smooth enough for carpet. It will get painted before I go back to work.
    Stogy, Woogeroo, Six Ball and 4 others like this.
  28. sloppy jalopies
    sloppy jalopies
    I see the small gaps both sides of the tunnel...
    time is right to use some of the tunnel to fit your "lead" foot...
    I hammered a sheetmetal half tube that matched the side of my foot... cut and trimmed to have it fit me and fit the '33's tunnel...
    worked great... the upholsterer wanted me to fill it so it would look better? ... easier for him was the real story...
    I am in prosses of designing a step pad size brace that will swing out from under the seat and support the side of my right calf...
    Stogy, loudbang and kidcampbell71 like this.
  29. Tim
    Tim
    from KCMO
    Looking good man
  30. dumprat
    dumprat
    from b.c.
    Once the tunnel is bolted down there are no gaps.
    Getting carpet on the is good no to be a challenge. It might just get painted.
