Projects 29 pickup build
Discussion in 'Traditional Hot Rods' started by BullittB, Nov 12, 2020.
  1. BullittB
    BullittB
    from Beecher Il
    I suppose its long past due to post up some stuff on my model a pickup build. I has been an extremely long and drawn out process. My everchanging life, low budget, and issues with maintaining attention on really anything for long periods of time have really wreaked havoc on this process but I will get it done.
    Toms Dogs, burl, Outback and 11 others like this.
  2. BullittB
    BullittB
    from Beecher Il
    I slowly continued to collect parts for a while before I even began to work on it. At that point I had absolutely no idea how to weld, I had never done anything this involved before. All I knew was I wanted a hotrod.
  3. BullittB
    BullittB
    from Beecher Il
    I believe this picture was taken in the summer of 2015. This is right when things started to really take shape on the project. I still had a whole pile of parts I needed to acquire, but this is the first time I felt it actually looked like something. I had saved forever to buy that brookville bed.
  4. BullittB
    BullittB
    from Beecher Il
    This pile of parts took a while for me to gain the confidence to put together. I still had no idea what I was doing. 1462140_566771850063080_1783973804_n.jpg
    Toms Dogs, burl, Tman and 9 others like this.
  5. BullittB
    BullittB
    from Beecher Il
    eventually the pile of ch***is parts became this. This is an image from this summer. There was obviously tons of work to get it here. There were things that I did, then re-did later because my skills changed or my taste changed. IMG_2298.jpg
    winr, Toms Dogs, burl and 18 others like this.
  6. BullittB
    BullittB
    from Beecher Il
    my a as of summer 2020.jpg Here is what it looks like all put together... It has a very long way to go. I think about it all the time, but work on it about half as much as I should. I am happy though in a way that it has taken me so long to get to this point. I have gone back and fixed or refined so many things to this point. It's getting there though! It is now chopped 5" and has a 34 Pontiac dash in it. I hand made the floor, firewall, map pockets and many other items. The shocks are all hidden friction shocks. I hope to eventually convert the banjo to a quickchange. I'm not sure when it will be done, but I've enjoyed the experience thus far
  7. Max Gearhead
    Max Gearhead
    from Wisconsin
  8. trollst
    trollst
    BullittB, thats pretty much how most of us put a car together, two steps ahead, one back. THEN, one day you get it on the road, and it all seemed easy, and like it didn't take as long as it did. Keep plugging away, you'll get it, looks good.
    dirt t, Deuces, chessterd5 and 3 others like this.
  9. sko_ford
    sko_ford
    Diggit
    Deuces and BullittB like this.
  10. That is a really neat little hot rod. Keep going. It's going to be a ton of fun.
  11. JB401
    JB401
    You are off to a nice start! I will be following along for sure as I just started a 29 pickup build myself. Did you need to purchase a wood kit or did your cab come with a decent one? That is a step I need to make a move on soon in order to ***emble my cab and have been checking out my options. Keep it up!
    Outback, Deuces and BullittB like this.
  12. BullittB
    BullittB
    from Beecher Il
  13. brady1929
    brady1929
    Cool hot rod.
  14. I dig it. Keep the posts coming
  15. ironandsteele
    ironandsteele
    Shaping up to be a *****in hot rod! Nice job.
  16. 66gmc
    66gmc
    You're doing a great job, the stance and proportions are perfect. Nice roadster on the wall too!
  17. HotRod33
    HotRod33
    How did you do the front end?
  18. Jason Mitchell
    Jason Mitchell
    from Memphis TN
    Looks great. Im doing pretty much the same thing with a Tudor, but it's a real mess right now.
    BullittB likes this.
  19. trey32
    trey32
    Uhhhhhhh what's up with that three window in pic three??!!!!
  20. Buddy Palumbo
    Buddy Palumbo
    It looks great. I've always wanted a 28/29 pick-up. Maybe someday.
  21. This is a sweet build man. No one builds a closed cab pickup. They are my favorite builds. :cool:
  22. BullittB
    BullittB
    from Beecher Il
    I’ll try to get some pictures up tonight.
    Deuces and HotRod33 like this.
  23. BullittB
    BullittB
    from Beecher Il
    That’s my dads. It’s getting a Hemi, quickchange, tko600, and a whole slew of other cool parts. It’ll be a good one.
    Outback, Deuces and Okie Pete like this.
  24. alchemy
    alchemy
  25. BullittB
    BullittB
    from Beecher Il
    Deuces likes this.
  26. BullittB
    BullittB
    from Beecher Il
    I guess I should preface this post by saying, I have no clue if any of my ideas here will work. bouncing things up and down in the garage is one thing but going down the road is another... So my front suspension design is heavily inspired by the rolling bones *****in cars. the spring is mounted to the wishbones behind the axle. Since their cars look *****in without having exposed shocks, I had to think of a way to hide my friction shocks. With the front end sitting pretty low I also had to raise the engine up a bit to keep the oil pan off of the ground. To do this I went with the 2 birds one stone approach. I designed a motor plate that mounted to the front of the block creating an area to mount my friction shocks. I stripped the necessary hardware off of a pair of offenhauser friction shocks from speedway and burned a set of lever shock arms on my plasma table along with some mounts to weld on the wishbones for some dog bone links.
    friction shock arm.jpg front spring mounts.jpg front suspension front view.jpg
    sko_ford, Toms Dogs, Tman and 9 others like this.
  27. HotRod33
    HotRod33
    I like how it looks...
    sko_ford, Deuces and BullittB like this.
  28. Aaron D.
    Aaron D.
    I like the way you made the spring perches, much better than putting a regular perch horizontal.
  29. BullittB
    BullittB
    from Beecher Il
    Thanks. They stick up over and hang below because I plan to add a reinforcement to the outside of the wishbone to try and help the torsional load. When I saw Ben Haag’s beautiful 32 3 window upside down because one of the spring perched had failed I cut those very same spring perches off of my truck and changed them to this design.
