Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    With the float tooling in the hands of the metal spinner... I started designing the fixture to finish the float bowl. Hopefully will have some finished float bowl pics by this weekend
    Stogy and loudbang like this.
  2. Hitchhiker
    Hitchhiker
    Honestly, that tumbled finish has the look of a carb that has lost the factory plating.
    Stogy, tomkelly88 and fauj like this.
  3. willys36
    willys36
    I feel the pain of a dozen aluminum splinters looking at that pile of shavings!!!
    Outback, Stogy and loudbang like this.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    Eventually I’m going to have to decide what to do with the carbs... the 2 that end up on my engine hopefully will be polished then copper plated. Would be pretty cool if they looked like a couple uh new pennies!!
    If I make more carbs than what I need... they will probably get shipped with the tumbled finish...
    The originals were copper plated, but never would have had a bright finish as the carbs were not polished prior to plating. I have a NOS carb, and the plating is in great shape... but really tarnished. When I get around to experimenting with the copper plating, I’ll give the NOS carb a vinegar bath to see how it looked when new...?
    Stogy, Hitchhiker and loudbang like this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    Well... turns out the first one was no accident! Cuz the second one came out real nice
    winr, SS327, Stogy and 17 others like this.
  6. Happydaze
    Happydaze
    I'm searching for something for an intelligent and insightful comment. The best I can come up with right now is wow!! Or ****ing wow!!
    Chris
    Sent from my SM-T515 using The H.A.M.B. mobile app
    Hitchhiker, Stogy, Frankie47 and 6 others like this.
  7. 41 GMC K-18
    41 GMC K-18
    "Perfection cannot be rushed"
    Stogy, Deuces and loudbang like this.
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’ve got 5 float bowl finished to this point now... but unfortunately have to return to the real world to finish up a few other small projects :rolleyes:. Should only be a few days before I can come back to finish these into usable float bowls!
    Should get the new float pieces from the metal spinner this weekend too... maybe I’ll start practicing my soldering...?:D
    Outback, Stogy, Deuces and 3 others like this.
  9. trvguy
    trvguy
    I couldn't make that stuff if I lived to be 150 years old.
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    That’s no reason to give up...!
    Outback, Stogy, fauj and 1 other person like this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Just because the “real world” has me distracted... doesn’t mean I have to stop thinking bout the important things in life!!!
    Spent bout 5 minutes on the buffing wheel, and got to thinkin I should start collecting what I need to try out the copper plating...:cool:
    Outback, Lil'Alb, Stogy and 11 others like this.
  12. stuart in mn
    stuart in mn
    Beautiful work. For reference, here's an original (I wasn't sure what they looked like).
    Outback, Lil'Alb, Stogy and 8 others like this.
  13. Hitchhiker
    Hitchhiker
    I've had 20-25 winfields over the years and only ever had 1 with the original finish.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    I scored a S-B at a swap meet years ago and a SR-C years before that, both were as close to NOS as one could hope for. I made a promise to myself a while back that I would stop collecting other peoples junk, but I’m a few generations removed from buying “used” car parts. Here’s a pic of my B as it sits today, the one shown above has clearly had a vinegar bath to clean it up. The copper plating doesn’t stay bright very long...
    These carbs were plated as raw die castings, and are covered with texture and imperfections. They would have looked a lot like the carb shown above when new, but would have been a long way from the finish of a shiny new penny!
    SS327, Stogy, Deuces and 3 others like this.
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    Note, the carb above is shown with one of my new billet machined choke horns installed. The original choke horns appear to have been supplied as raw die cast, as I have not seen any signs of copper plating on the straight or elbow horns, or any signs of factory polishing.
    I have seen a few pics of carbs that appear to have copper plated choke horns, but the color never matches the carb bodies and I suspect that the “copper color” is actually the zinc base metal tarnishing into a light brown color. Here is one such pic...
    Stogy, Deuces, loudbang and 2 others like this.
  16. Kevin Pharis
    Kevin Pharis
    from Califunny
    The first of many real world distractions...
    A 1916 Overland flywheel with a few less ring gear teeth than intended. Machine off the original integral iron teeth, to make room for a new shrink fit ring gear... DUN!
    236ED73D-7D1E-4927-B73E-DCF5F3498046.jpeg 24A683E6-49F5-4470-8F71-EADD280B7D7D.jpeg
    Outback, Stogy, GordonC and 7 others like this.
  17. 57JoeFoMoPar
    57JoeFoMoPar
    sick workmanship
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Was just cruzin thru some pics and sumthin cought my eye... this is the first choke horn that I have seen that was clearly copper plated! Maybe they were in fact copper plated...?
    Outback, Stogy, winduptoy and 5 others like this.
  19. Kevin Pharis
    Kevin Pharis
    from Califunny
    The wife is at work today... so I took over her kitchen to make up the copper and nickle acetate solutions for plating... shhhhh! ;)
    I haven’t had time to finish a carb bowl yet... but do have a few finished choke horns I can test it out on...:D
    winr, Outback, Stogy and 6 others like this.
  20. Gofannon
    Gofannon
    Make the most of it and run some engine parts through the dishwasher.
    SS327, Stogy, ClayMart and 5 others like this.
  21. Kevin Pharis
    Kevin Pharis
    from Califunny
    A long time ago, I used the oven to cure some paint on a cold day... scarred her for life!!!:rolleyes:
    I have to be pretty incognito these days...
  22. 427designer
    427designer
    from Ohio
    Yes?
    Tod
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    After messin with the plating rig for most of the day... I was successful at plating half of the keys in my pocket, but don’t seem have enough power to plate the larger carb parts...!:rolleyes:
    I got a choke horn to cast a light copper color in just the right light. I’ll try more power... then maybe I’ll seek profess help! Some of the problem could be the aluminum, which is commonly regarded as unplateable. I’ll try some original carb parts some day to confirm if it’s a material, or power issue
  24. 25mercury
    25mercury
    Looking great Kevin. I have a Winfield model S prototype in aluminum. DSC05638.JPG DSC05643.JPG
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    Check that thing out!!! :cool:
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Well... I musta done sumthin right!!!:D
    winr, flathead 37, Lil'Alb and 15 others like this.
  27. Kevin Pharis
    Kevin Pharis
    from Califunny
    Here we are after a few minutes up against the buffing wheel.
    Stogy, TFoch, winduptoy and 8 others like this.
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    Here’s all 5, deburred, tumbled, and cleaned. Now I can plug off the fuel p***age and these ******s are DUN!
    Not sure bout the rest yet... but the 2 polished ones are goin on my car!:cool:
    Outback, Lil'Alb, Stogy and 16 others like this.
  29. Kevin, I've been watching your progress here and on MTFCA- fantastic work!!!... now, on to the throttle bodies :D?
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    I have the S-B throttle barrel modeled up, but am basically at the point of a bare casting. Still have to add in all the holes and the airfoil venturi section. The tricky part is modeling it accurate to the original design... yet tweaked slightly so that it can be machined with my equipment.
    Today is all about the float bowl cover. I finalized the design this morning, and am ready to take the first cuts now. Will post some pics once it starts to take shape
    Outback, Stogy, brjnelson and 6 others like this.
