Technical C10 header help needed
Discussion in 'The Hokey Ass Message Board' started by 46poncho, Nov 14, 2020.
  1. 46poncho
    46poncho
    from Indiana
    I have a 66 c10, I put a sbc in it,I had a set of headers on it but in the location the motor mounts bolted up, the p***enger side header hits the a arm. There is not a ton of room due to starter, a arm, and frame. I saw some rear swept headers on computer looked like they might work. Has anybody used them? The photo shows the space on p***enger side, the center drop headers are the ones I pulled off. Thanks Screenshot_20201112-194549_Facebook.jpeg 20201114_120249.jpeg 20201114_133959.jpeg Screenshot_20201114-135602_eBay.jpeg
    Sent from my SM-S367VL using The H.A.M.B. mobile app
  2. Pete Eastwood
    Pete Eastwood
    from california
    Wouldn't it be best to just order a set of headers made for a '66 C-10 ?
  3. squirrel
    you have the engine in the wrong place. The frame brackets for the motor mounts are supposed to be in the rear position. The 67-72 trucks had the engine in the forward position, like yours is set up.
    at least that's what it looks like from what I can see. If you hold the camera back a bit further so we could see more of the engine, frame and firewall, might be easier to see.
  4. Budget36
    Budget36
    Had a set in a 66GMC with SBC, headmans, as I recall. Should be the same?
  5. 46poncho
    46poncho
    from Indiana
    If the engine were in the rear holes only 1 of the lower mount holes line up.
  6. 46poncho
    46poncho
    from Indiana
    It would move the engine back approximately 1.5 to 2 inches
  7. squirrel
    I can't see what brackets you have. There are several different ones, for different engines in different years. The 292 six engine has one mount forward, one back. Both mounts on the 230-250 from 63-72 are back. Both mounts on the V8 in 63-66 are back, but in 67-72 are forward. It's complicated.
  8. 46poncho
    46poncho
    from Indiana
    I bought the aftermarket tube style mounts. The original was a 250
  9. Mr48chev
    When I had the 350 in it I had a set of Patriot headers on my 71 GMC The right side came down like this as viewed from the bottom side
    It's too dark now to go out and get a photo of the header.
  10. jaracer
    jaracer
    I've got Headman headers on my 64 C20. They fit fine with no interference. They don't look anything like your pictures. I went on their web site and it appears they only go back to 1967 now.
  11. bill gruendeman likes this.
  12. squirrel
    through 66 truck used straight drop rams horns, the 67 up trucks used the angled back rams horns to clear the A arm, since they moved the engine forward.
    Truckdoctor Andy and KJSR like this.
  13. Mr48chev
  14. 46poncho
    46poncho
    from Indiana
    It may be. When I put the engine in the aftermarket mounts have 2 holes in top and 2 in bottom, I had it toward the back at first, only 1 hole lined up on the bottom, when I moved it forward both all holes lined up, so that's where I put it.
  15. 46poncho
    46poncho
    from Indiana
    Thanks for all the help, I found a video on YouTube that confirms the forward holes are for 67 and later, the rear holes are for 60-66. You learn something every day. I am glad we have the hamb and great people willing to help!
  16. 46poncho
    46poncho
    from Indiana
    The center dump headers will definitely not work. Moved the engine back to the rear position, headers are setting on the a arm and very close to the starter and trans pan. Not sure any center dump exhaust will work, not sure there is enough room to bend a pipe out???
  17. 46poncho
    46poncho
    from Indiana
  18. squirrel
    Why do you have an aftermarket crossmember for the mounts, instead of the original mount brackets?
  19. 46poncho
    46poncho
    from Indiana
    I bought the one I think it was brothers truck for 6 cyl to v8 swap. Bolt up no drill etc... came with new mounts and all hardware. Did not know old perches would work
  20. squirrel
    do you still have the old perches?
  21. 46poncho
    46poncho
    from Indiana
    Yes, the new one line up ok, they move the engine back
