Projects Almost Funny - AWB Barracuda Funny Car Build
Discussion in 'The Hokey Ass Message Board' started by squirrel, Nov 27, 2017.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    Hemi Squirrel, it's great to see you getting busy on the hemi again. What was wrong with the lifters? What is the plan for improvement?
  2. squirrel
    Actually it's deprovement...going to flat tappet hydraulic lifters, while I sort out some other things with the car. But the lifter bores had been bushed, and need the oil slot and a bit of honing to let them move freely enough, and that requires taking it all apart to clean up the mess. I'll also hone the bores just a tad, and new rings. The main bearings have some interesting wear patterns, probably all normal stuff. I already put different valve springs in the heads.
    I also plan to look into the transmission, hopefully nothing looks amiss. And I have to fix several other things, like the gas pedal position, install the magneto and cable drive tach, and then figure out what to do about the fuel system. I might try some different carbs for now, and pursue the mechanical injection plan at some later time.
  3. If you are doing rings any thought to using hapless. I'm going to use them this year. Gapless second ring.
    Also upgrading to main studs might help out with the funny wear.
    enloe, Runnin shine and loudbang like this.
  4. Hemi Joel
    Hemi Joel
    from Minnesota
    Zooming in on the pic, it looks like main studs are already there.
    loudbang and squirrel like this.
  5. squirrel
    I'll keep the normal rings in it, I'm not really into "tricks" like real racers are. Yes, it has main studs.
    The mains all look like they had some metal to metal contact, yet the rods all look pretty good. No scoring or anything.
    enloe and loudbang like this.
  6. Hemi Joel
    Hemi Joel
    from Minnesota
    Probably stuff you already know, But I would suggest double checking the main bore alignment, mabe have it align honed if it wasn't on the original build, and use p-series bearings.
  7. squirrel
    The block was fully machined before I got it, I think he did a good job. The bearing surfaces are all like that, its not like something is out of line. More like it just takes a while to get oil to the mains? I'll have to get some pictures, I was kind of busy today.
    enloe and Stogy like this.
  8. AmishMike
    AmishMike
    Machinest told me if going to use main studs, install them before align bored.
  9. squirrel
    yeah, that's what was done with this one.
  10. mopacltd
    mopacltd
    Hey Jim, where did you have the lifter bushings installed?
  11. squirrel
    I didn't. The only block I could find to buy, already had a bunch of work done to it.
    kidcampbell71 likes this.
  12. jobbless
    jobbless
    Check out what's sitting next to that wagon... not sure if anyone knew about it or not but just spotted the Crazy Cuda..
  13. squirrel
    where is that?
  14. winduptoy
    winduptoy
    I am guessing that he wanted to give your thread a bump...maybe not
    loudbang, Thor1 and squirrel like this.
  15. BamaMav
    BamaMav
    from Berry, AL
    Well, since it bumped up, any progress on getting it back together Jim?
    loudbang and Thor1 like this.
  16. Lloyd's paint & glass
    Those things that make ya say hmmmm o_O
  17. squirrel
    I'd been meaning to bump the thread anyways, I've been putting the car back together, although not with all the improvements I want. We're going to be moving soon, so the car needs to be in one piece.
    I bought a pair of big Holley carbs for it, and am working on getting the fuel and throttle stuff sorted out. And the mag installed, along with the wiring changes and the mechanical tach.
  18. Lloyd's paint & glass
    Where ya moving to man?
  19. squirrel
    not far, it's a 15 minute drive.
  20. TFoch
    TFoch
    Looks like you have a lot of plans for it.
  21. Lloyd's paint & glass
    Hell Jim, out there in the desert, you'll probably still be able to see your old house from there!
    norms30a, enloe, winduptoy and 2 others like this.
  22. rockable
    rockable
    Are you getting a bigger shop? :D
  23. squirrel
    No, I'm losing some shop/garage space. But its a good excuse to get rid of **** I don't need.
    AHotRod, winduptoy, loudbang and 3 others like this.
  24. squirrel
    this is google street view, looking from the front of the new house, towards the old one, which is about 4 miles away as the crow flies. No way to see it from here.
  25. Lloyd's paint & glass
    I was joking squirrel :p
    seb fontana and loudbang like this.
  26. squirrel
    Hard to tell, the desert around here isn't like they show in the movies :)
  27. lippy
    lippy
    from Ks
    Once a carburetor guy, always a carburetor guy. :D Sorry Jim could'nt help it.
    hendelec, norms30a and loudbang like this.
  28. squirrel
    I want to put injection on it, but I just don't have the gumption to get it done right now.
  29. lippy
    lippy
    from Ks
    I understand. It takes a lot of parts and changing around stuff. Then sending the fuel system off and getting everything flowed ect... If you do send it to Dave Koehler. You will get a flow sheet back with your stuff.Then the learning curve starts all over. Should'nt be a big deal for a guy like you though. ;)
  30. milwscruffy
    milwscruffy
    But now you have gr*** to cut !!!
