Close ratio VS. Wide ratio 4-speed tranny...Pros/Cons...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Feb 23, 2012.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    30 years ago I owned a '69 Z/28 with a close ratio Muncie 4-speed. I also owned a '67 Nova with a cast iron Saginaw wide ratio 4-speed. I really don't recall there being a whole lot of difference in the two cars performance.
    What are the benefits of using close ratio over wide ratio? The reason I ask is that one costs about $800 more than the other, and I just don't see a great benefit of using one over the other in a 2500lb hot rod that wouldn't be thrashed on at the drags....your thoughts...
    kidcampbell71 and bowie like this.
  2. Close ratio is good for racing to minimize RPM drop between gears to keep engine in optimium hp range. For street, the wide ratio, with a lower first gear gets you moving faster, than a cose ratio with same rear ratio or can allow a higher rear ratio for better fuel economy, if using the same effective first gear ratio.
  3. Bigcheese327
    Bigcheese327
    I agree with Algoma56. I have a close-ratio Muncie in my Camaro, with 3.42 gears, and I'd like to go to a wide-ratio to get a better launch. I think from the factory you couldn't get a close-ratio four-speed with gears above a certain ratio.
    -Dave
    dirty old man likes this.
  4. 29sportcoupe
    29sportcoupe
    from arizona
    I just switched from an M20 to a close ratio M21 in my 68 camaro. Still ****s on the highway. The close ratio has the same final ratio I believe but the rest of the gears are closer together which is good for racing because it keeps the motor at a higher rpm where the motor makes more power. I am now installing a T56 6 speed. best of both worlds.
  5. Bigcheese327
    Bigcheese327
    Fourth gear is still 1:1; but first gear has less multiplication so you don't have as big a drop 1-2.
    -Dave
  6. Further to my comment above,
    A wide ratio Muncie(2.52) with 3.42 rear would have an effective first gear of 8.6, the same rear with a close ratio Muncie first gear(2.20) would be 7.5. The higher effective first gear gives you better torque multiplication to get moving. On the same thought, to get the same 8.6 effective ratio with the 2.2 first gear of a close ratio, you would have to put in 3.91 in the rear. So, by using the wide Muncie box, you could better gas mileage with the 3.42's. For example, only.
    dirty old man and 55styleliner like this.
  7. Relic Stew
    Relic Stew
    from Wisconsin
    The close ratio also has higher torque capacity. Less multiplication means it can handle more input. On the Fords, 390 or larger engines only came with the close ratio 3 and 4 speeds.
  8. maybelene
    maybelene
    I've used both in my '55 Chevy. The close ratio seemed to work better on the drag strip with the tunnel ram and slicks, but the wide ratio seemed better when it was in street trim.
    pitman, dirty old man and Baron like this.
  9. Tudor
    Tudor
    from GA
    To me, wide ratio is the only way to go. I have a wide ratio with the same straight cut gears as the M22 Rock Crusher and it is awesome. Close ratio is for road racing.
    I've got 29.5" diameter tires and a 3.90 rear. I needed the steeper first gear.
    I can run 100 in second at 7000 rpm. It is the ****
    pitman, dirty old man and 4274SPEED like this.
  10. fms427
    fms427
    I have both in various cars. Agree with most here - close ratio is best for road racing - wide ratio best for anything else. But, 5 or 6 speed even better, and about the same price as a good Muncie these days !
  11. nwbhotrod
    nwbhotrod
    from wash state
    are you sure about that gear ratio in a muncie
  12. Bigcheese327
    Bigcheese327
    Sorry to confuse: That gear ratio is in the 10-bolt behind the Muncie.
    -Dave
  13. Dan MacPherson
    Dan MacPherson
    putting a close ratio behind say a 230 six with 3.08 gears and you will have trouble climbing steep driveways.
  14. Deuces
    Deuces
    My '69 Z had the M-21 and the '69 SS had the M-22 grinder.... :mad::D
  15. DDDenny
    Regardless of the engine, the wide ratio (M-20) will have a slight advantage over the M-21.
  16. southcross2631
    southcross2631
    I have a 2.78 1st gear Liberty geared top loader in my SEGA super stock wagon. I just changed from a 5.29 gear to a 6.00 gear so I can really use 4th gear in the 1/8 th mile. We have a spec 29 x 7 Hoosier slick.
    One of my compe***ors runs a similar engine combo in a Falcon and runs a 2.43 1st gear G Force close ratio with a 6.50 gear. His rational is it is less violent on the hit but makes it up on the big end.
  17. bowie
    bowie
    I’ve always gone by anything with 3.70’s or stiffer , use a close ratio trans. With a numerically lower gear (like 3.08) use a wide ratio trans.
  18. flatheadpete
    flatheadpete
    from Burton, MI
  19. old.hot.rodder
    old.hot.rodder
    I have played the trans. ratio game in many cars. Bowie is right on. A base line for the factory cars was exactly as he said. 3.70 and lower - close ratio. 3.55 and up - wide ratio. But you could order any combination. I found this rule to be very effective.
    bowie likes this.
  20. Hank37
    Hank37
    I now have a wide ratio Muncie with a 3.42 rear , it does move out faster but can't hit 70 in low gear like i could with the close ratio T-10 .
  21. Budget36
    Budget36
    Someone help me out here, a wide ratio has larger rpm changes between gears. If so, why would running a lower numerically geared rearend be better and vice-versa?
    Or is it ***umed with the 3.08 rear and wide ratio transmission, your running a big block with more lower/mid range grunt?
    I can see keeping a higher winding engine in its power band with a close ratio.
  22. ct1932ford
    ct1932ford
    That's it! End of story.
    bowie likes this.
  23. HotRod33
    HotRod33
    Nice to see one of his old threads
  24. jimmy six
    jimmy six
    Nobody has mentioned the clutch. The wide is easier on it with a street gear.
    GlassThamesDoug likes this.
