Technical The Supercharger Thread To End All Supercharger Threads
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Sep 30, 2019.
  1. loudbang
  2. I noticed in reading the last 2 pages that maybe some info might be helpful for some of the readers. This page will tell you about the absolute beginning of Roots blowers: https://en.wikipedia.org/wiki/Roots_Blower_Company
    The original version was a 2 lobe rotor. It's design was to move volume and not achieve high amounts of pressure. I have never researched to see who developed the 3 lobe rotor such as the GMC design. The concept of "supercharger" reflects on pushing more than the vacuum pulled air charge into the engine. Hence, supercharge. The terms: blower, huffer, wind pump all reflect to the same principle of compressing the atmosphere to get more air flow into the engine. The guys in the pits call them blowers. Rules makers call them superchargers. Makes no difference if it's a roots, a centrifugal or a turbocharger. They all do the same end result. One other point, all roots design units are also referred to as positive displacement units. They are measured by swept volume of rotation in size. The 4/71 was designed to feed 4 cylinders of 71 cubic inches each. I know that most of you are aware of these facts. This was just meant to help those who are new to this. :)
  3. cheezwiz
    cheezwiz
    Studebaker guru Malcolm Berry just got his supercharged Stude flathead 6 running ! It sounds like an airplane !!
  4. seb fontana
    seb fontana
    from ct
    Here is one I picked up years ago; any one know the application? IMG_0592.JPG
    Number on tag is 2502 13821. Three lobe, about 3.5 long by 3.5 diameter
  5. Seb, non automotive is my guess. You may know this but Bob McCulloch was the inventor of the McCulloch supercharger. His middle name was Paxton and one of his spinoff companies was called Paxton that was later bought by Studebaker. He's responsible for the Mac chainsaw engines used in go kart racing. He started Pueblo West Colorado. He was instrumental in the development of Lake Havasu Az. in which he was responsible for purchasing London bridge and moving it there. He died in 1977 after leaving a tremendous legacy in the high performance world.
    Clark, Hollywood-East, Deuces and 2 others like this.
  6. seb fontana
    seb fontana
    from ct
    wfo, yes not automotive but still ****ed air thru a carb [gasoline I think] and blew to a single cylinder 4cycle air cooled flathead engine and something else.;) Can't think of what to call the ***embly right now, looked military..:confused: Just read about McColloch last night, interesting man. There is a couple of the mac kart engine blocks on e bay.
    loudbang, waxhead and Deuces like this.
  7. loudbang
  8. Deuces
    Deuces
    I love them side draft carbs!!!.... :)
    31hotrodguy and loudbang like this.
  9. DDDenny
    Deuces and exterminator like this.
  10. Mike VV
    Mike VV
    from SoCal
    My Uncles (RIP) car, "Dodie 77" .
    Mike
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    DDD,
    Fins are going the wrong way:p
    loudbang and Speed Gems like this.
  12. DDDenny
    Correctamundo!
  13. seb fontana
    seb fontana
    from ct
    How can volumne cubic inches be found? As simple as blocking off one side and filling with lite oil but I keep thinking it has to be rotated too?
  14. winduptoy
    winduptoy
    Jet96, XXL__, 31hotrodguy and 8 others like this.
  15. DDDenny
  16. loudbang
  17. loudbang
  18. loudbang
  19. j hansen
    j hansen
    Bengtsfors 2016
    Jet96, 31hotrodguy, winduptoy and 4 others like this.
  20. loudbang
  21. loudbang
  22. loudbang
  23. Only other one I have seen for a Caddy. Have had mine since 75.
  24. wrenchbender
    wrenchbender
    Let’s see some pics
    Chrome don’t get ya home
  25. GOT SOME, WILL TRY TO POST SOME.
  26. Speed Gems
    Speed Gems
    Poly block with a Potvin setup. Image stolen from @Deuces in the Potvin hemi builders thread.
    Jet96 and Deuces like this.
  27. 61SuperMonza
    61SuperMonza
  28. loudbang
    Can you figure out if the mixture goes in the side of the case or up and into that "box" above them?
  29. s.e.charles
    s.e.charles
    where would i begin research on something like this? Bangers? thanks
    Jet96, winduptoy, GuyW and 3 others like this.
  30. Seb, your question about measurement: math would be how I would go about it. To use liquid, it would be best to pull and end cover. Grease the rotor lips to seal to the case as best you can an fill with a buret just like checking a cylinder head for volume with the rotor turned to the best position to seal. You will find many places to leak in doing this. :)
    winduptoy and loudbang like this.
