Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    Here we go again!
    "You know you car is low when ..."
    Pulled the valve block completely apart.
    Ultrasonic bath to flush any particles out.
    All bores clearanced and the thing re***embled. Let's see if that works now.
    Phil
  2. TrailerTrashToo
    TrailerTrashToo
    Fingers crossed...
    loudbang and PhilA like this.
  3. PhilA
    PhilA
    It's better. But it's still occasionally sticky.
    I'll try it like this for a while and see. It's all adjusted up. I have 4-3 downshift back so that's a bonus.
    Phil
    chryslerfan55, MUNDSTER and loudbang like this.
  4. PhilA
    PhilA
    Actually, this only happens when the gearbox is hot. I might be seeing problem with the oil being too thin.
    Edit: I'm going to see about getting a pressure gauge to put on and run the tests in the service manual. It'll be interesting to see if it's losing pressure at any point. May well be back down to the pressure regulator.
  5. PhilA
    PhilA
    I need to poke my nose into the book.
    If it doesn't cycle to 4th gear, it hangs in 1st repeatedly then dumps to 3rd.
    Once it's made 4th it's as smooth as can be.
    Phil
  6. PhilA
    PhilA
    Just ordered a gauge, that should be here before the end of the week. I can compare the book values and do a road test then and see if it's within spec.
    Phil
    loudbang, MUNDSTER and 51pontiac like this.
  7. PhilA
    PhilA
    Ought to be able to see that while driving!
    I'll get the fittings for it when I can, needs a downsize and an extension plus a flexible line- I'm thinking a brake pipe.
    Phil
  8. PhilA
    PhilA
    Thing regulates nicely to 60psi. Front oil pump easily sees it to that pressure on the starter motor.
    In gear, stationary it holds pressure.
    Driving, the pressure modulates directly with throttle position, from 60-100psi so the 8-cylinder variant TV valve is working.
    Reverse, the high pressure line is engaged and the valve shuttles giving a wobbly 130-160psi as it should.
    It did act up one time, and the main line pressure was perfect, which narrows the issue down to the 1-2 valve getting stuck.
    That is a bit of a problem as there is no real recovery from that fault other than valve block replacement.
    Thankfully spares are available (not cheap though) and I can try to m***age a few more miles out of this one before I have to stump up for a new one.
    Phil
  9. vtwhead
    vtwhead
    So Phil, where is the 1-2 valve located? How much of a project is that replacement?
  10. loudbang
    After all your work now you can be an expert consultant or re-builder of the transmissions for others. :rolleyes:
  11. PhilA
    PhilA
    The selector valve consists of the two arrowed pieces that go into the valve block (circled).
    Takes about 40 minutes to pull down, stripdown doesn't take long.
    I've got a headband with magnifying loupes on it coming so I can inspect better, the pieces are small and are made to very fine tolerance.
    It was designed with maintenance in mind.
    Phil
  12. PhilA
    PhilA
    I'll p*** on the rebuilding part- one was enough but I'm trying to gain a better understanding of the thing so I can fix it when it inevitably causes problems. I don't mind giving advice though.
    Phil
  13. Johnboy34
    Johnboy34
    from Seattle,Wa
    Does that 1-2 valve have a spring and or check ball in it's path that could be sticking?
  14. PhilA
    PhilA
    No, in the Dr position there's 4 things that dictate the engagement of gear 1 vs gear 2.
    There's:
    42: The governor piston, which has modulated pressure against it based upon road speed
    37: The selector piston, which the governor piston pushes against
    36: The spring, that the governor pressure has to overcome to change the gear
    35: The throttle position piston, which boosts the spring to make the change later if the throttle is pressed down.
    I have s feeling the governor piston is getting stuck at the bottom of the bore when it's warm when the spring pushes it back.
    That can be remedied in the short term but it's an effect of being quite worn, that bore gets the most workout of all of them and it's slightly oval with age.
    I've got some magnifying gl***es coming in the mail, I'll be able to eyeball the parts better with them.
    Phil
  15. tubman
    tubman
    I am constantly amazed at your skill and tenacity. Keep at it; I'm sure you'll get it eventually.:)
  16. Nostrebor
    Nostrebor
    Me too. You are a machine at troubleshooting.
    Sidebar: I lol'ed at the giant pressure gauge. That should get it!
    bchctybob, loudbang and PhilA like this.
  17. PhilA
    PhilA
    The gauge was bought in mind that it would be by my ankle when driving. I wanted something that would be fine enough to see down to 2psi on the graduation but still be large enough to get an at-a-glance easily.
    The more I try to fix it, the better I understand it. "Clean the whole thing and hope" only goes so far, as shown by the last 2 efforts.
    Phil
  18. Gotta give you credit for plinking away at it... Most guys would have swapped in a Chevy by now... LOLOL
    I'm curious... Would it be possible to sleeve that bore to bring it back into spec?
  19. Johnboy34
    Johnboy34
    from Seattle,Wa
    A long time ago my dad helped me rebuild a 60 Pontiac hydramatic that had some sticking valves.
    We used a tiny brake cylinder hone, only spun for a few seconds to clean the bore. It was no doubt the wrong thing to do perhaps losing some seal in the valve, but it worked, no more sticking valve for the few years till it was sold. Good luck, those old trannies are a hoot. Some amazing engineering back then.
  20. PhilA
    PhilA
    Possibly but there's not a large amount of material in the body, that being part the reason for it being temperature sensitive.
    Phil
  21. PhilA
    PhilA
    Yeah, this has done so many miles I think the wrong thing may fix it.
    Phil
    loudbang and Johnboy34 like this.
  22. PhilA
    PhilA
    Did the missing test this afternoon. Got up to 20, dropped the car into N and switched the engine off; then put on the ignition and engaged Dr.
    The rear pump makes about 30psi and is enough to bump start the car reliably.
    Waiting for my microscope lenses to arrive before I take it apart again.
    Phil
  23. PhilA
    PhilA
    Had more to do so finished up the body of the other horn.
    Got a couple coats of paint on it, that can dry overnight and I'll get the other side tomorrow.
    Phil
    Woogeroo, chryslerfan55 and loudbang like this.
  24. PhilA
    PhilA
    Took an hour out tonight to do noisy things.
    120 grit to get rid of the rust.
    Clean enough to see and then beat out the dents.
    220 grit to finish.
    Finally, first coat of black.
    Phil
  25. tubman
    tubman
    I have to ask; what kind (brand) of paint did you use? When I first saw it, I thought it was chrome!
  26. PhilA
    PhilA
    It's a really specialized type of paint, really expensive, imported, made from..
    Wait no
    Rust-Oleum black enamel. $7 from the hardware store.
    I like enamel for jobs like this, it lays on well enough straight out of the can for non-bodywork (slight orange peel) shiny, but rubs down very well with fine grit and polish if you want it a little more smooth.
    It's not a bad black; it's not the deepest ever but it's what I call respectable. You just gotta watch it- it's 66 out here at the moment and about 70% rH- I lay a coat on then give it as gentle waft of hot air from my heat gun to get it to form a skin and seal, which tightens it up a little and stops it from sagging, as enamel is quite runny stuff.
    Good prep, lots of coats and patience, with 600 grit paper between each coat to keep it flat.
    Phil
  27. PhilA
    PhilA
    I am going to pull the gearbox valve block out again. My lenses arrived!
    Phil
  28. vtwhead
    vtwhead
    those right there are some spooky looking gl***es!:rolleyes:
  29. PhilA
    PhilA
    Okay then. Let's eyeball the valves.
    Yup. They've got a lot of miles on. Found a couple burrs and high spots and carefully tried to take them down.
    First drive was good, we'll see if that trend continues.
    Phil
