Old aircraft maintenance vehicle what is it?
Discussion in 'The Antiquated' started by anthony myrick, Aug 10, 2020.
    looked at this today. Has a 4v Yblock (stuck)
    Aluminum cab and neat tiny service bed.
    The cab has one seat with an air compressor in the other side. The bed has a little storage and what looks to be a large generator.
    It 4x4 with Timken looking axles. Haven’t located the hood.
    Any you guy know what this actually is?
    Okie Pete, 41 GMC K-18 and J.Ukrop like this.
  2. 1930artdeco
    1930artdeco
    from Lynden, Wa
    If you think it is aircraft related it looks like our tow vehicles. Does it have 4 wheel steering?
    Mike
  3. BamaMav
    BamaMav
    from Berry, AL
    By the looks of that light guard on the fender, I’d say military, probably Air Force.
    anthony myrick likes this.
  4. RICH B
    RICH B
    Looks sorta like an NC5 with a cab. The ones we used were open cab, Y block motor, generator for ground power, no compressor tho. Low gear was blocked out to prevent wheel stands. Originally were geared to serve as a tow tractor; but heard that didn't work out so just used as ground power unit.
    Sent from my Nexus 5X using The H.A.M.B. mobile app
  5. rustydusty
    rustydusty
    With a compressor, I think it's a starter for military jets. We had something similar, without a top on the USS Midway. Fighter jets couldn't start themselves...
  6. Don’t think so.
  7. The guy was talking about s****ing it.
    May grab it just cause it old and neat. Who knows.
    The intake and carb won’t hit the s**** yard.
    Has some cool headlights too
    Could toss the cab and bed on a T bucket style frame for a ‘unique’ bobber truck.
    kevinrevin and VANDENPLAS like this.
  8. This 58/59 truck was there as well
    rotted very bad. Will pull the good off of it.
    Has a usable ribbed factory flat bed.
    The truck is a 1.5 ton. The 6cyl should be a 261.
  9. looks like the "tea pot" carb on it so that intake has limited value, if so, still get it. what exhaust manifolds does it have?
  10. jimmy six
    jimmy six
    Might be a little Lincoln Y... Rocker covers a re different..Crazy exhaust manifolds
  11. Crossover. :(
    But they look a little different since ya mentioned it.
    46international likes this.
  12. It has a bracket that attaches to the cover studs.
    the stamping look different than the ones I have seen. Won’t let any odd parts turn into toasters.
  13. Probably need to check the head casting numbers
  14. rusty valley
    rusty valley
    the little marker lights are definitely WW2 style, but some leftovers made it into the post war trucks too. certainly military, all had a data plate on the dash giving make, model #'s, weights, dimensions, etc. some of the oddball things like this were made by coleman, some were fwd's too. most likely not from ford even though its ford powered. cool toy, i'd grab it !
  15. RICH B
    RICH B
    Found a picture of an NC-5 like we used on the flight line at NAS Miramar and Cubi PT. Looks the same other than the cab Screenshot_20200811-125412~2.jpeg
  16. That’s it without the cab. That hood is ugly. Maybe ok that it’s missing.
    There was a similar mesh located under it.
    Had that same looking emblem on the back
  17. donno
    donno
    Called a MA-2, AKA "Ma Deuce". 4wd, no rear steer, DC power, hi / lo air compressor for servicing tires / struts, ac***ulators. Also had a turbine engine to provide starting air for the aircraft engine. Also used for towing aircraft.
    anthony myrick, alanp561 and grumpy32 like this.
