Technical Make your own steelies? Can’t be this easy.
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Nov 18, 2020.
  1. hotrodA
    hotrodA
    https://www.ebay.com/itm/15-Inch-Wheel-Shell-15-x-8-/133374142903?_trksid=p2349624.m46890.l49292
    I need to make some wider rear steel wheels for my 40 pickup, and looked at all the old threads, then discovered these.
    I have 15”, 5x5 1/2, Ford pickup smooth wheels with center OD measuring 12 5/8” and these shells (rims) from Speedway have an ID of 12 5/8”.
    Drill out the rivets, set the backspacing I need, true up runout and tack and finish weld?
    Sounds TOO easy.
    Am I missing something? Anybody ever use these shells?
    They also come in 10” width, but street tire availability may be an issue.
    Thanks!
  2. Thats it. I have the same hoops and have done a couple others
    31hotrodguy likes this.
  3. Now that's a RIM like some guys have been talking about.
  4. RMR&C
    RMR&C
    from NW Montana
    I use my drill press for the rivets. Takes about 5 minutes a wheel. I'm putting wider hoops on these... 1114201537.jpg
    Dean Lowe, AHotRod, dwollam and 7 others like this.
  5. rusty rocket
    rusty rocket
    Done several sets. Make sure to move around the rim when welding it back together. Did one wheel and had runout dead nuts but welded to much on one side and now the wheel has a wobble. It’s on my singleseater project so it just adds to the charm of the car, looks like it got in a little rubbin incident with another race car. Haha!
    Outback, Greenblade, Deuces and 4 others like this.
  6. Bandit Billy
    Bandit Billy
    I had to do the same thing to mine. Don't forget to drill the hole for the valve stem. :cool:
    Deuces and 31hotrodguy like this.
  7. 31hotrodguy
    31hotrodguy
    And this is why I love the H.A.M.B.! Thanks for the info!! Me thinks I’d like to try this! [emoji3]
    Outback, Deuces and catdad49 like this.
  8. 5window
    5window
    Looks like Speedway won't play that game-it's a "Wheel shell". :)
    Just Gary, Tman and 31hotrodguy like this.
  9. hotrodA
    hotrodA
    Thanks for the help, guys!
    31hotrodguy and Xtrom like this.
  10. gimpyshotrods
    gimpyshotrods
    I have a few 15" wheels to do this to, after I finish a run of Wide 5s.
  11. silent rick
    silent rick
    what's the backside look like? how does it look reversed?
    has anybody chromed it and the center first and then went about ***embling it?
  12. I can get pics of mine, the look good reversed.
    Deuces, LSGUN, 31hotrodguy and 2 others like this.
  13. southcross2631
    southcross2631
    wish was that easy when I was a teenager over 50 years ago using Buick station wagon rims on my 49 Chevy centers.
    Running tubes and having to crawl under the car to put air in the tires.
  14. silent rick
    silent rick
    can you do that for me Tman?
    31hotrodguy and Tman like this.
  15. Here is one side I dug up. I will snap the other side when I get home tomight. [​IMG]
    Just Gary, AHotRod, Deuces and 8 others like this.
  16. hotrodA
    hotrodA
    Thanks, Tman! That looks great.
    Did you clean up the rim’s **** weld before painting?
  17. Those particular ones are not welded yet. That 56 Chevy center is just laying in there if you look closely. Yes, the weld will get touched up a bit before powder.
    Deuces, Elcohaulic and 31hotrodguy like this.
  18. AccurateMike
    AccurateMike
    AHotRod and 31hotrodguy like this.
  19. 31hotrodguy and AccurateMike like this.
  20. AccurateMike
    AccurateMike
    Who does new or custom centers ? It would be cool to see what you could put together.
  21. Several places make centers for LSR, Bonneville etc. But, they are flat and pretty beefy for a street driven car. You can get new wide 5s, I used those on my Bonneville project.
  22. That is about the same as reversing a stock rim. I have even trued them up by spinning them on axle and using a bent coat hanger to locate the rim. I know backyard but when I was starting out i did not have a lathe or a dial indicator. ;)
  23. silent rick
    silent rick
    i have a dial indicator but the magnetic base won't stick to the concrete. my lathe doesn't have enough swing to mount a wheel in it
  24. How big is the bore in your headstock? Can you chuck an axle in it backwards and work off the opposite of the carriage?
    31hotrodguy and Budget36 like this.
  25. silent rick
    silent rick
    not large enough to stick an axle through
  26. Bummer. I would be tempted to cut the flange off an axle and make something that fit OR rig up a fixture with a couple pillow blocks to spin and true em.
  27. silent rick
    silent rick
    or ask a friend if i can use his. that's an offy crankcase getting line bored
    Just Gary likes this.
  28. Tim
    Tim
    from KCMO
    Find a piece of s**** and sit it on the floor. Magnet it to that. Done deal
    Paulz, alanp561, 31hotrodguy and 3 others like this.
  29. WOW!
  30. Budget36
    Budget36
    Along with @Tman s advice of your through hole, if you can source an axle with the same BP, chop it off, face it and bore for a press fit the size your through hole will handle. You could use the wrong end of your lathe then.
    Just Gary, X-cpe and Tman like this.
