Hot Rods Nature Abhors a Vacuum, Or, The Hemi A Roadster fills a void.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jul 18, 2020.
  1. flynbrian48
    flynbrian48
    My buddy Jeff, from whom I got this Model A body, was disappointed I’d trimmed the wheel wells to fit the ‘32 frame. So, I fixed it. I want to see the frame and the kick up. [emoji6]
    Stogy, brEad and tb33anda3rd like this.
  2. flynbrian48
    flynbrian48
    I fixed it some mor, so the Chicken foot bottoms are finished.
    Stogy, GordonC, AndersF and 4 others like this.
  3. flynbrian48
    flynbrian48
    Todays big project, besides sending another raccoon that had taken up residence in the attic of the garage to a farm in the country where he could run and play (OK, I shot it in the live trap with a .22, but it's my story, I get to tell it however I want), was to separate the DeSoto Hemi from the Turbo-Encabulator unit. I had a spot of trouble getting the malleable amullite transmuter off the spervel vane, but a couple whacks with a BFH and 360 MegaJoules shock from a defibrillator loosened the crust, some reverse polarity thruster through the varble unit and it finally came right off. Now I can put the boring TH350 on it, make some motor and trans mounts and it will be ready for a trip around the block.
    I'm kidding of course... 125865286_10225191570038970_6057068012441611529_o.jpg
    Stogy, GordonC, brEad and 4 others like this.
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    About Rocky? [emoji6][emoji1787][emoji23][emoji1787][emoji23][emoji41]
    Sent from my SM-G973U using The H.A.M.B. mobile app
  5. flynbrian48
    flynbrian48
    Rocky sleeps with the fishes.
    fauj, Chavezk21, bchctybob and 3 others like this.
  6. flynbrian48
    flynbrian48
    I spent all day wrestling with the TH350 transmission for the DeSoto Hemi. I found the stock oil filter will not clear the adapter plate (or the transmission), and ordered a 30 degree offset one fro HotHeads.
    Then I couldn’t get the torque converter to fit in the crank flange adapter. I ended up filing a rusty ring from the hub and bolted it on the flex plate first.
    Then, for the life of me I couldn’t line up the torque converter on the input shaft . I gave up after at least an hour, pushed the trans back, put torque converter on the shaft, carefully got housing against the block on the dowel pins, and one tooth at a time on the ring gear, got everything lined up, seated properly and bolted together.
    For my 66th birthday on 12-1, I’d like to have engine in the chassis and the car setting in wheels.
    Stogy, GordonC, AndersF and 7 others like this.
  7. flynbrian48
    flynbrian48
    Would you look at that, it fits.
    Lil'Alb, Stogy, tb33anda3rd and 12 others like this.
  8. Damn that looks good! Just like a rancher the 3 S'.....shoot, shovel and SHUTUP!
    Chavezk21, loudbang and flynbrian48 like this.
  9. BamaMav
    BamaMav
    from Berry, AL
    I like that see through radiator. Looks like the fan will be close. :p
  10. flynbrian48
    flynbrian48
    Air cooled.
  11. flynbrian48
    flynbrian48
    Snug as a bug in a rug.
    Lil'Alb, Stogy, tb33anda3rd and 7 others like this.
  12. lowrd
    lowrd
    Do you use a day planner or what? I never know what you're working on and await a surprise each day I find a posting from you. Nice job by the way.
    bchctybob, loudbang and flynbrian48 like this.
  13. flynbrian48
    flynbrian48
    Haha! I just go out to the shop and do whatever seems like the most important thing to do. Today I mostly worked on the DeSoto, I have the right side bodywork done, and will start moving around to the left side after the holiday. Actually, I'm about 2/3 the way around, I've got the grill opening almost done, and in the rear the lower pan and taillight mods are almost finished. A little more work with some finer grit paper on the long boards and I'll be ready to blow some Feather-Fil on everything.
    The wagon has to get finished this winter, but I should have enough time to get the Model A at least running and driving, if not finished. To what degree of "finished" the roadster will be is yet to be determined, but it'll be shiny.
    GordonC, loudbang, brEad and 2 others like this.
  14. flynbrian48
    flynbrian48
    My buddy Jeff Miller, from whom I got the body commented that he hated to see radius rod brackets covering the reveal on a '32 frame. Me too. I had those left from the '34 build, they're just there holding the radius rods in mock-up. Never fear, they'll be replaced with some welded on brackets hanging from the bottom of the frame.
  15. flynbrian48
    flynbrian48
    Oh, I ordered one of those "off-shore" made aluminum radiators for a '32. With a trans cooler in the bottom tank. For $189. I'll take a chance on it for that. I've run those cheap radiators in several cars with great results. Since this is a "budget" build, seems appropriate.
    TrailerTrashToo, Tman and loudbang like this.
  16. flynbrian48
    flynbrian48
    I had a brainstorm: Why not use original ‘52 DeSoto gauge panel, along with the complete, NOS linen wrapped wiring harness that came with the wagon? I’ll have to weed a little of the extra stuff not needed in this little car, but it’ll be a nice detail that’ll make it stand out.
    Then I had a momentary anxiety attack: I couldn’t find it, or the wiring! Maybe I threw the stuff out in our spring cleaning dumpster purge! Turns out, I’d stowed all that stuff in the wagons spare tire well. This is why I don’t often put things away...
    tb33anda3rd, Jrs50, charleyw and 5 others like this.
  17. Love the DeSoto gauge panel, fits well.
  18. flynbrian48
    flynbrian48
    I dug out the rest of the new harness that came with the DeSoto wagon, there’ll be plenty to get the roadster wired and have a bunch left over. I found a pair of ‘48 Chevy taillights with LED lenses from the ‘34, do cut holes in the tail pan and put ‘em in.
    Perfect. This is why I can’t throw stuff away!
    tb33anda3rd, GordonC, brEad and 5 others like this.
  19. flynbrian48
    flynbrian48
    Santa came! These are better than a Red Ryder Range Master BB gun with a compass in the stock and thing that tells time!
    tb33anda3rd, GordonC, brEad and 2 others like this.
  20. flynbrian48
    flynbrian48
    That’s the plan. [emoji106][emoji41]
    Nostrebor and loudbang like this.
  21. Looks GREAT. I would change the amp gauge to volts and bypass that sucker.
    Ben
  22. flynbrian48
    flynbrian48
    I now have not one, not two, but FOUR Wilson Welding finned backing plates coming, despite them not being made any longer! Two new ones, which I’ll use in the rear with Buick drums, and a complete set, barely used l, complete with hubs and drums from a guy pulled them from a Troy Ladd built ‘27 for disk brakes. The new ones are machined for a 9”.
    At this point I’ve invested enough that I thought I might as well get a Brookville body, which is what a previous builder decided to do, and I got this one. [emoji23]
  23. flynbrian48
    flynbrian48
    So, this happened.
  24. flynbrian48
    flynbrian48
    130870504_10225346451390907_6109541758337407901_n.jpg 130811148_10225346451990922_4168662958027972178_n.jpg I picked up a sheet of 3/4" plywood to day and got started replacing the floor I'd cut out to be able to set the body on the '32 Frame. I used a little less than half, the rest will make a bulkhead behind the seat. I need to get more matting and resin, I used what little I had, I'll get some more tomorrow. I'll finish that up, mark where the steering column should go and box, mock up a brake pedal, and the body can then come off and get the frame set up for real 130870504_10225346451390907_6109541758337407901_n.jpg 130811148_10225346451990922_4168662958027972178_n.jpg
  25. flynbrian48
    flynbrian48
    I got started bracing the body yesterday afternoon, and Santa brought me some presents!
  26. Guthrie1068
    Guthrie1068
    Man, this car has all the right stuff.
  27. flynbrian48
    flynbrian48
    Not finished with the bracing, but it’s enough to get it off the frame and back on the body dolly. On to the DeSoto!
  28. GordonC
    GordonC
    Pretty cool!
  29. Guthrie1068
    Guthrie1068
    Ok, I got a question, and, it's probably a dumb one because I don't have any experience working on or building one of these. Can the rear mount for the front radius rods be put right on the frame as opposed to hanging it under the frame? I don't think I've seen a car with the rear mount for those on the side of the frame, and I'm guessing there's good reason, but to me it seems like it'd clean up the side view of the car without that hanging under the frame. Is it because that rod needs to be parallel to the frame or it creates some crazy ride quality or steering issues? I get it that it's traditional, I'm just curious.
  30. flynbrian48
    flynbrian48
    I got one door cut, framed, and hung. I'm happy with how this looks, and glad I didn't use the doors in their extended shape. On to the other side. IMG_2436.JPG IMG_2438.JPG IMG_2439.JPG
